Panasonic TC-P42C2 Red and Blue Lines - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-22-2012, 08:12 AM - Thread Starter
toy4x4's Avatar
Attached is a picture of the problem I have with a Panasonic TC-P42C2. There is a band of red and blue lines across the screen.
Does anyone know which board causes this problem?
Anyone have a repair manual?
toy4x4 is offline
post #2 of 5 Old 09-22-2012, 11:36 AM
iBrad's Avatar
Don't know which board, have no experience with this model
Here is the service manual with troubleshooting etc.
http://elektrotanya.com/panasonic_gph13du_chassis_tc-p42c2_plasma_tv_sm.pdf/download.html
iBrad is offline
post #3 of 5 Old 09-23-2012, 03:08 PM
maddigital's Avatar
Fixed 2 42x3 which was the 2011 cousin to this 2010 model with similar stripe issue. An A board replacement fixed both. It was something with the image processor . The a board is the one with all the inputs. This issue should be on all inputs.
maddigital is offline
post #4 of 5 Old 11-12-2012, 06:30 PM
pinchio's Avatar
Hi, I have the exact same issue as you on my panasonic TCP58vt25 plasma. Just start yesterday. The set is barely 2 years old.
Did you get yours fixed? What was the solution to the problem? How much for the repair? Just need to know what I'm up against.
Rob
pinchio is offline
post #5 of 5 Old 08-28-2013, 11:57 AM
Diesel935's Avatar
Same exact thing JUST happened to my Panasonic. Did you ever get your fixed? What was the issue and how much was the repair? Thank you!
Diesel935 is offline
Panasonic 42 Inch Plasma Hdtv Tc P42c2
