What do you think about "Pixel Shift/Orbiter?" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-02-2012, 01:23 AM - Thread Starter
Yomaster's Avatar
I recently had a defective Samsung PN51D550 exchanged by the warranty service for a brand-new PN51E550, and I've noticed that enabling the "Screen Fit" aspect setting still disables the anti-burn Pixel Shift feature, as the ratio must be set to 16:9 for it to work.
My dilemma is that I use my PC to watch movies and play games on my TV, and leaving it in 16:9 causes overscan/scaling issues that can only be resolved by setting the input's name to "PC" or otherwise setting the view to "Screen Fit." I don't really like PC mode because, while the pixel shift works as 16:9 becomes Screen Fit, you lose some settings and the PQ looks a little diminished. The set does get some console gaming time in, too, so I'm worried about potential burn-in.
My question is, what do you guys think of turning it off/leaving it on? Is it really that effective? Is the loss in picture worth the benefit of a precautionary measure? Thanks for your input!
Yomaster is offline
post #2 of 6 Old 10-02-2012, 01:34 AM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
I think the pixel orbiter is just there to make people feel better. To me it doesn't seem to do much. It only shifts the image slightly, a small number of pixels worth, so rather than prevent burn in or image retention it will just blur the edges of a burned in image. I leave my Panasonic in THX mode which completely disables the pixel orbiter feature and haven't had a problem. Then again, I don't game or use the TV as a monitor. I'd say just be aware of your usage, and running some full-screen content with a lot of action after a gaming session will do more to prevent IR than a pixel shift feature.
mailiang and Yomaster like this.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
post #3 of 6 Old 10-02-2012, 12:00 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
+1
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #4 of 6 Old 10-09-2012, 09:17 AM
seabass666's Avatar
I use the pixel orbiter, daily. I dont really notice it because its so subtle, so subtle infact that i doubt it truley works:)--may just be for peace of mind. At any rate, I have not dealt with any extensive IR at all. The only time being, is when I had DIRECTV installed, and the reciever calibrater had a bright "static" image for a good while. However, a few minutes with the scroll bar and is was a non-issue. But, like fatuglyguy, I also do not use mine (Panasonic 55ST50) as a monitor. Ultimately just be careful and dont abuse the television and you should be fine. By the way mine has a september build date, so that could be why I experience next to no IR!?!
seabass666 is offline
post #5 of 6 Old 10-09-2012, 09:18 AM
seabass666's Avatar
Oh and I use mine on cinema mode with the contrast at about 86 for all my viewing, and game mode with contrast dialed back to 86 when I play my Xbox.
post #6 of 6 Old 10-11-2012, 10:29 AM
Joseph4469's Avatar
Depending on your video card, if its AMD or nvidia, you can reduce the overscan or underscan usimg their respective control panels.
Joseph4469 is offline
