HELP Vertical black line Panasonic 50" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2012, 01:04 PM - Thread Starter
Huntj's Avatar
I have a TC-P50G10. It has about a 2" vertical line just left of center running from top to bottom. It started off intermittently but now it's there all the time. If the TV is off for awhile its not as bad but gets worse the longer the TV stays on and eventually it will go completely black. I have done a little research and if I understand the information that I read this problem is probably the panel and its not worth fixing. I'm just trying to get a second opinion before I trash this one and buy another.
Thanks for any advice
Huntj is offline
post #2 of 3 Old 10-02-2012, 01:08 PM
tomwil's Avatar
Liked: 26
Originally Posted by Huntj View Post
I have a TC-P50G10. It has about a 2" vertical line just left of center running from top to bottom. I have done a little research and if I understand the information that I read this problem is probably the panel and its not worth fixing.
It might be worth the chance to replace the C-board. They usually are inexpensive.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #3 of 3 Old 10-02-2012, 01:12 PM - Thread Starter
Huntj's Avatar
Here's a picture of what it looks like
Huntj is offline
