Is this normal on Panasonic Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2012, 04:39 PM - Thread Starter
cpandrewschmidt's Avatar
Hi all,
Just got my plasma turned on. Running the slides for breakin. I noticed on both a dvd and slides, even when on zoom, there's a thin black edge of pixels that don't line up around the border of the TV. (see picture) It's about 3/8" on the top and bottom and 1/4" on the other two sides. Almost like the screen isn't totally centered. Shouldnt the image go all the way to the plastic border or is this normal? I don't want to continue breaking in if I'm burning in a black edge. Thanks!
screen 1317k .JPG file
Andrew
cpandrewschmidt is offline
post #2 of 3 Old 10-02-2012, 06:20 PM
Dierkdr's Avatar
Liked: 54
Normal.
Try a Search & you will find a bunch of posts on this topic from earlier in the year.
Dierkdr is offline
post #3 of 3 Old 10-02-2012, 06:43 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 506 Post(s)
Liked: 770
Originally Posted by cpandrewschmidt View Post
Hi all,
It's a border of black masking surrounding the active area of the panel. It's there to hide the edge of the panel where it meets the bezel. There is no image below that mask - the image ends right at the edge of the mask.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
