U50 same exact image quality as UT50 but without 3d? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-03-2012, 11:56 AM - Thread Starter
ilike2eatcheese's Avatar
Would the Panasonic U50 have the same exact image quality as the UT50 but just no 3d? It seems like it is the same panel right?
ilike2eatcheese is offline
post #2 of 9 Old 10-03-2012, 09:05 PM
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
I know the answer but since I don't like cheese I won't give it to you.
PathofNeo is offline
post #3 of 9 Old 10-04-2012, 12:43 AM
BriscoCountyJr's Avatar
Quoted: 33 Post(s)
Liked: 42
Not so, its been reported that the UT50 and above have significantly better picture quality than the models below that which use a different type of panel.
The extra stuff in the tech for 3D adds to the 2D picture quality, such as being capable of higher refresh rate.
5thdimension likes this.
BriscoCountyJr is offline
post #4 of 9 Old 10-04-2012, 01:21 PM
Steve S's Avatar
Liked: 46
iirc the 3D model panels have a faster decay rate on the pixels--they take less time to change for each frame of video so there's less overlap between the two pictures in 3D mode. In other words faster pixel response time, not higher refresh rate.
Steve S.
Steve S is offline
post #5 of 9 Old 10-04-2012, 01:38 PM
tylerSC's Avatar
Quoted: 736 Post(s)
Liked: 168
I was told it was the same basic panel with similar specs minus the 3D and internet apps. Having seen them side by side, they appear very similar. Even if the UT has slightly better specs, I do think it is the same basic panel and the pic quality is very similar.
tylerSC is offline
post #6 of 9 Old 11-30-2012, 10:46 PM
mailiang's Avatar
Quoted: 852 Post(s)
Liked: 588
BINGO!
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #7 of 9 Old 12-01-2012, 12:46 AM
5thdimension's Avatar
U50 specifications: http://panasonic.net/avc/viera/us/u_plasma_spec.html
UT50 specifications: http://panasonic.net/avc/viera/us/ut_plasma_spec.html
The differences are numerous and worth every penny.
5thdimension is offline
post #8 of 9 Old 12-01-2012, 07:32 AM
gopromiller's Avatar
yeah,i think so, good info to m e, I do think it is the same basic panel and the pic quality is very similar.
gopromiller is offline
post #9 of 9 Old 12-01-2012, 09:33 AM
mailiang's Avatar
Quoted: 852 Post(s)
Liked: 588
I've seen the specs. The most important ones like grey scale, black levels and resolution are pretty much the same. I'm not saying that there aren't differences, including panel brightness, but some of of that is marketing hype and doesn't necessary translate into a better picture. I should know, I use to rep for some of these companies.biggrin.gif See comments from CNET:
http://reviews.cnet.com/flat-panel-tvs/panasonic-tc-p50u50/4505-6482_7-35149658.html
http://reviews.cnet.com/flat-panel-tvs/panasonic-tc-p50ut50/4505-6482_7-35153392.html
I agree.
Ian
mailiang is offline
