42st50 hdd for recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2012, 03:32 PM - Thread Starter
Doddibyggir's Avatar
Is there a minimum size limit of the hdd you can use? please help:)
Doddibyggir is offline
post #2 of 2 Old 10-06-2012, 11:28 PM
has7738's Avatar
Liked: 24
What are you recording? How much time do you wish to be able to record? What quality?
Generally bigger is better, getting the largest HDD you can afford isn't a bad idea.
You might consider a more detailed post, and put it into the right forum area.
has7738 is offline
