Pioneer Plasma Pro Elite 50"*****Problem*** - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-06-2012, 05:00 PM - Thread Starter
MDTROUP's Avatar
Suddenly half the screen is dead w/o picture. 50% of the screen horizontally is missing. Has anyone had this problem? Is it repairable?
MDTROUP is offline
post #2 of 5 Old 10-07-2012, 07:00 PM
DarkVenture's Avatar
It is probably your Y-sustain board and maybe the y-driver board. Chances are you'll have to replace both at about $500.
DarkVenture is offline
post #3 of 5 Old 10-08-2012, 09:09 AM - Thread Starter
MDTROUP's Avatar
Thank you. This is great information. Are you aware if I can purchase these components on-line?
MDTROUP is offline
post #4 of 5 Old 10-11-2012, 09:50 PM
Try ebay
post #5 of 5 Old 10-14-2012, 06:33 AM
cjq
cjq's Avatar
Hi Dark Venture, if your somewhat skilled you can tackle the repair,,there is enough information and help all over the net. Replacement boards are available used and new. Manuals are available inexpensively, A little common sense goes a long way. Do some research and determine if the repair using your own invested time and board cost makes sense. I'm a tinkerer and mess with electronic units as a hobby and challange,I have no formal electronic schooling.
Hope you take on the project.
Can you tell me how you have your PRO unit connected
CLIFFORD.
cjq is offline
