Samsung PN51E550 ... why does it show 720x480 screen resolution and not 1080p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-07-2012, 12:28 PM - Thread Starter
PalmettoTom's Avatar
I am a newby ... forgive the basic question.
I just purchased the Samsung PN51E550 and I am very pleased with it.
My question is:
Why does my source information reflect HDMI1/DV1, 720x480p/60p? I was expecting 1080p.
PalmettoTom is offline
post #2 of 4 Old 10-07-2012, 12:40 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally Posted by PalmettoTom View Post
I am a newby ... forgive the basic question. I just purchased the Samsung PN51E550 and I am very pleased with it.
My question is: Why does my source information reflect HDMI1/DV1, 720x480p/60p? I was expecting 1080p.
That's apparently the TV reporting the actual signal that you are sending to the TV from your source (is it a DVD player or a cable box of some sort?).
The TV then takes that 480p signal and scales it to 1080p so that it can be displayed on your screen.
If your source device(s) are capable of being set to output a 1080i or 1080p signal then do that. I set my Tivo and cable DVR and my upconverting DVD Player to output everything at 1080i Fixed and that looks best.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 4 Old 10-07-2012, 04:09 PM - Thread Starter
OK ... thanks.
I guess my cable provider, Time Warner, sends the signal at 480p.
I don't think I can change that.
Thanks again.
post #4 of 4 Old 10-08-2012, 09:55 AM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1275
OK ... thanks.
Thanks again.
If this is happening with all of the channels you receive with your cablebox (including the HD channels), then you should be able to change the settings on your cablebox to 720p or 1080i. You should review the manual for the cablebox you're using to make sure it's set up correctly...most cable TV installers never bother to set up the boxes.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is online now
Samsung Pn51e550 51 Inch 3d Slim Plasma Hdtv
