Panasonic st50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-07-2012, 08:27 PM - Thread Starter
gamingzone6912's Avatar
I am really liking this tv and have some questions about breaking it in....can i leave the tv on for a few days to speed up the proceess or do you recommend doing it in sessions?
another question is how much does it help with image retention and burn in?
also has anyone tried this for breaking in there plasma?
http://youtu.be/BlzN3voxAXA
gamingzone6912 is offline
post #2 of 9 Old 10-07-2012, 09:50 PM
adone36's Avatar
Liked: 37
Plasmas do not require "break in" other than not using torch mode for the first couple hundred hours.
Tony
adone36 is offline
post #3 of 9 Old 10-07-2012, 10:38 PM - Thread Starter
okay thanks for the reply, really now? do you think it would be okay to game on it pretty soon after i get it?
post #4 of 9 Old 10-08-2012, 01:01 PM - Thread Starter
bump
post #5 of 9 Old 10-08-2012, 01:37 PM
Dierkdr's Avatar
Liked: 54
FWIW, our 60ST50 was prone to Quick Onset / Medium-to-Long Duration IR until some point past 400 hours usage.
Beyond the 400 hour mark, IR onset became progressively slower, and duration progressively shorter.
Personal preference would be to keep Static Images - and especially Bright Ones - to a small percentage of screen usage for at least the first several hundred hours.
(And/or until you've determined how prone YOUR panel is to IR: there have certainly been posts from people who claim to have gamed from Day One with No Visible IR. However, would rather err on the side of safety, as opposed to Immediately launching into an 8 hour marathon....)
Currently, panel appears no more prone to IR than either of our older Panasonics: that is, could DEMONSTRATE it for someone, but it simply no longer appears to be an issue under normal usage.
Note that we do not game, nor use the panel as a Super Large Computer Monitor - YMMV Accordingly....
Dierkdr is offline
post #6 of 9 Old 10-09-2012, 08:36 AM - Thread Starter
thanks yeah im still doing research i dont game much during the week but i can play during the weekend for 7+ hours and dont want that to harm anything,
post #7 of 9 Old 10-09-2012, 10:21 AM - Thread Starter
i just called best buy and they said they cant get the st50 anymore and however they have the UT50(for 850) and the gt50 (which i cant afford right now) , How much better is the st50 in terms of the UT50 for picture display and 3d? he said the major difference is the ut 50 has 1 less hdmi port.
post #8 of 9 Old 10-09-2012, 10:32 AM
chunon's Avatar
Quoted: 2015 Post(s)
Liked: 1774
The ST50 has an ar filter for brighter rooms, some like it some don't. ST50 is more adjustable in custom mode althought white balance can be adjusted in the SM on UT50. Blacks are essentially a wash.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #9 of 9 Old 10-11-2012, 07:11 AM
homerging's Avatar
Quoted: 31 Post(s)
ar meaning anti-reflection filter. The UT50 is inappropriate for a typical lighted room. But if it is a dark room the UT50 will be fine.
Image retention varies from one individual TV to another. It's possible you may have problems with image retention from gaming or you may have none.
homerging is offline
