Problems with Panasonic GT50 Picture Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-07-2012, 08:58 PM - Thread Starter
Manuel Pedraza's Avatar
I´ve just bought a 50 inch Panasonic GT50 Plasma TV, I was about to calibrate it using the same picture settings used by CNET, when I started the Picture mode needed was the "Custom" one but when looked for it on the TV menu it wasn´t there. I really want to have the best experience possible with the TV. So I need to know if someone else has had the same isues and if solution for it.
Thanks for your help!
Manuel Pedraza is offline
post #2 of 3 Old 10-08-2012, 07:39 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
CNet (and this forum) covers the North American models. Since your GT50 doesn't have Custom mode then you must be in some other country so any settings you find on CNet or AVS Forum don't apply. European and Asian versions are very different TVs and have completely different settings menus. Does your GT50 have "Pro" modes?
What country are you in? If you're in Europe, try the UK Based AVForums Plasma forum:
http://www.avforums.com/forums/search.php?searchid=18097312
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 3 Old 10-08-2012, 02:03 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
Manuel Pedraza, i'm from Perú if you're latin american and you buy tv on colombia, mexico or another latin country...i could give you my settings...are very good. Greetings
Our Menu it's a little diferent from US models...but basically the image it's the same
agkss is offline
