TC-P42U2 Solid Color Noise Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-08-2012, 06:34 PM - Thread Starter
Jurai's Avatar
Hey guys, I've had this set for a couple years and recently started noticing some strange noise occuring in certain color ranges of output, more evident when playing a game with a solid color on screen. Basically I start seeing what I would describe as 'noise' in certain colors, which will clear up / get worse given slight changes to the brightness settings. The set only recently started exhibiting this behavior and I'm wondering if it's something anyone else has seen and if there is a fix / I should just tweak my brightness and live on. I broke the set in and calibrated after initial purchase,. below are some screens where it's evident in the upper light green area, I've also uploaded a video of the issue where you can see the noise shift itself on screen as the brightness setting is moved up / down a tad
If anyone has experienced this / knows what causes it, appreciate any info smile.gif
Jurai is offline
