Panasonic TH-42BT300U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-08-2012, 08:25 PM - Thread Starter
Prodeje79's Avatar
Any info and comparison on this model? It appears to be a commercial model. What consumer model would you compare it to? Would it be usable for normal viewing?
It is used and seems to good to be true. How can I test it and confirm the low hours advised?
Prodeje
Prodeje79 is offline
post #2 of 4 Old 10-13-2012, 07:08 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
I remember D-nice saying that these suffer from Image Retention a bit more than the consumer displays but then again that environment may have more static images. These should have a few more color controls available. Should have better parts inside. You will need a tuner to display video on a pro unit, it should come with an HDMI input. There's a consumer hours post here somewhere but I don't have a link. Over at high def junkies in the plasma section there's a sticky thread on checking hours and may work on this unit. I have no experience with these but hope this helps. personally I think it would be cool to try one of these out and you should be able to recoup your cost if you decide to sell it.
http://www.panasonic.com/business/plasma/th-42bt300u.asp
whipit is online now
post #3 of 4 Old 10-13-2012, 10:56 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
More Info about this unit:
http://www.hdtvexpert.com/?p=1487
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 4 Old 10-13-2012, 05:56 PM
Gizmogadget's Avatar
I picked one of these up almost a year ago. I use it for video production work, and it produces a very clean image. Image retention does happen quicker than with a consumer plasma display, but it's not permanent. This display produces some of the best shadow detail i've seen in a panel. It only has one HDMI port, and no tuner or built in speakers. This really is a production grade monitor. It isn't terribly bright, but color accuracy seems pretty decent. I should also note that it doesn't come with a base, and must be mounted to the wall with an optional wall mount. Any mount designed for a 42' panel will work.
Gizmogadget is offline
