HDMI Booster - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-10-2012, 10:06 AM - Thread Starter
mystik610's Avatar
Any thoughts on these?
Noticing a lot of graininess and artifacts and sparkles on all video sources (including blu-ray). I've got a long distance HDMI run (pre-installed with the house) and am suspecting that the signal may be less than perfect.
mystik610 is offline
post #2 of 3 Old 10-10-2012, 02:51 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
How long are the runs? Even If you are using quality CL2 certified cable and it' over 50ft, then you will probably need a booster.
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #3 of 3 Old 10-10-2012, 02:57 PM
BriscoCountyJr's Avatar
Quoted: 33 Post(s)
Liked: 42
Monoprice.com has some nice HDMI amplifiers for longer cables, also ones with splitters for driving more than one TV.
BriscoCountyJr is offline
