Samsung Tech Adjusted Voltage - Could This Be Problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-11-2012, 07:37 PM - Thread Starter
bearzfan1963's Avatar
I had Samsung Tech come today to fix my panel because of red tint appearing in white backgrounds- he adjusted the voltage but it didn't help.
Next step is to replace the panel but I am wondering if the tech by adjusting the voltage would cause problems with the new panel that will be installed ? And/or by adjusting the voltage will this cause long term damage to panel ? Can he reset the voltage to optimal settings or factory settings ?
bearzfan1963 is offline
post #2 of 4 Old 10-12-2012, 04:54 AM
EG3
EG3's Avatar
The red tint was the result of normal use on a cheaply made panel. It is kind of like 'burn in'.
I have seen these lower end panels have a red tint especially in the center (4:3) area where the panel gets the most use. A new panel will fix the problem temporarily. The tech should adjust the voltages according to the label on the new panel.
EG3 is offline
post #3 of 4 Old 10-12-2012, 04:56 PM - Thread Starter
thank you for the response!
the panel was brand new had had 0 hours of use- noticed the red tint during break in with slides.
post #4 of 4 Old 10-14-2012, 03:24 PM
Straybeat's Avatar
Sounds like a Panny fanboy, ignore him. I have heard of some Samsungs doing this? Either red or blue. Never had the problem on any of mine though? Where did you buy it? I would return it for another. which model do you have?
Straybeat is offline
