Newbie question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-12-2012, 08:38 PM - Thread Starter
MAGRACER's Avatar
I am getting my panasonic 65GT50 next week. What is a break in disk that I read on the forum? I am not clear what Ian supposed to do.Any help would be appreciated.
MAGRACER is offline
post #2 of 6 Old 10-12-2012, 10:20 PM
Straybeat's Avatar
Breaking in a plasma has always been a 50/50 thing. Half the people say you absolutely must do it and the other half say you don't, it's not necessary.
Here is a CNET writer's take on it, he too says that you don't need to;
http://reviews.cnet.com/8301-33199_7-57480003-221/do-i-need-to-break-in-a-new-plasma-tv-morrisons-mailbag/
Personally, I have a plasma I bought 5 years ago that I never broke in, I didn't know about it then? I pulled it out of the box, set it up and proceeded to play about 4 hours of Xbox on it, the absolute worst thing you can supposedly do to a new plasma. 5 years later it's my daughter's gaming and Roku TV and looks as good as the day I bought it.
Straybeat is offline
post #3 of 6 Old 10-13-2012, 05:00 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Just to add, the panel aging process that some call breakin is for people that need a tv professionally calibrated asap. So they run slides continuously for a hundred hours or so then call a pro in for a cal. You can get similar results just watching tv but it can take longer and it tends to age the center of the screen a little more. I see no value to wasting the tv on this unless you are needing a cal pronto.
The plasmas tend to color shift the most in the early hours and people tend to see pic quality improvements in the first 100-200 hours whether watching tv or running slides. So it's up to you if you need to do this. If you do I recommend putting slides on a usb drive or sd card and letting them run from the slot in the tv. If you need the slides here they are. Unzip and add to a clean formatted drive with a windows PC.
BreakIn_Images.zip 8k .zip file
whipit is offline
post #4 of 6 Old 11-12-2012, 07:38 PM - Thread Starter
MAGRACER's Avatar
Shat di I do with the slides, how long to show each as an example?
MAGRACER is offline
post #5 of 6 Old 11-13-2012, 08:04 AM
gamingzone6912's Avatar
i have the same question what is the time recommendation for each slide?
gamingzone6912 is offline
post #6 of 6 Old 11-13-2012, 09:03 AM
Ph8te's Avatar
Quoted: 4572 Post(s)
Liked: 4028
Take a look through this thread, you can also do a search within this forum for Dnice's slides (its not on this forum, thus cannot post link)
There are a number of threads on this subject, what most people do is load the slides on a USB stick\SD card put it in the TV and run them in rotation for the 1st 1-200 hours.......
Ph8te is offline
