Panasonic st30 Plasma Picture settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-09-2012, 02:58 PM - Thread Starter
cjdmotocross's Avatar
On just watching satelite/cable I am using D-nices setting but it seems a little dark and washed out. Is there any improvements I can make for that?
And for video games I am using "Game Mode" with some tweaks
Contrast: 80
Brightness: 50
Color:50
Tint: 0
Sharpness: 30
Color temp: normal
Color mgmt.: on
CATS: off
video nr: off
Advanced picture:
Block NR: off
Mosquito NR: off
Motion smoother: off
Black level: light
Any recommendations on tweaks I need to make for either of them?
Please resond, thanks.
cjdmotocross is offline
post #2 of 8 Old 11-09-2012, 06:27 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1773
The best combination is custom mode panel brightness mid and hdmi type set to "graphics'" contrast in high 70's brightness mid 50's color mid 40's.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #3 of 8 Old 11-09-2012, 07:34 PM - Thread Starter
For video games or watching tv?
post #4 of 8 Old 11-10-2012, 06:49 AM
chunon's Avatar
Liked: 1773
I am not a gamer perhaps someone can weigh in on that but for TV and Bluray go with what I suggested above. Also check out the St30 diy thread for some settings ideas.
65C6 OLED
chunon is offline
post #5 of 8 Old 11-12-2012, 05:06 PM - Thread Starter
ok also the black level: dark looks way better and less washed out than "light" but everyone including d-nice have it set to "light". Is there any specific reason?
post #6 of 8 Old 11-13-2012, 05:26 AM
chunon's Avatar
Liked: 1773
You don't want to use the "dark" setting that will result cause black crushing and you will use lots of shadow detail. If you set the brightness control correctly the blacks are just fine.
Try these settings
Contrast 78
Brightness 56
Color 46
Color Temp Warm2
Panel Brightness Mid
Gamma 2.2
3;2 Pulldown "On"
HDMI content type-"Graphics"
65C6 OLED
chunon is offline
post #7 of 8 Old 11-13-2012, 06:31 PM - Thread Starter
What does "graphic" setting do?
post #8 of 8 Old 11-14-2012, 10:12 AM
chunon's Avatar
Liked: 1773
It tames the color(more accurate) on Mid Panel brightness, colors appear too saturated without that setting.
65C6 OLED
chunon is offline
