HDMI 1 or HDMI 2 - AVS Forum | Home Theater Discussions And Reviews
Old 11-09-2012, 04:52 PM - Thread Starter
jeep05's Avatar
Quoted: 105 Post(s)
Liked: 155
On most Samsung TV's with only these two inputs, is there any major advantage or disadvantage in using one or the other for a Satellite box? I have a PN60E530.
jeep05 is online now
Old 11-09-2012, 06:31 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 505 Post(s)
Liked: 769
Does one of those HDMI input do anything different than the other? (like ARC for instance or some other function)?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 11-09-2012, 08:48 PM - Thread Starter
jeep05's Avatar
Quoted: 105 Post(s)
Liked: 155
Negative Randy, only difference is HDMI 1 is labeled HDMI/DVI.
Old 11-10-2012, 09:05 AM
"Don't PM Me Bro"
Quoted: 505 Post(s)
Liked: 769
Then there should be no advantage to using one over the other for an HDMI satellite receiver. The DVI one simply gives you the added option of using it with DVI sources such as an older cable box or computer etc. and getting audio from one of the analog inputs.
Randy
Old 11-10-2012, 09:29 AM - Thread Starter
jeep05's Avatar
Quoted: 105 Post(s)
Liked: 155
