Pio 151-FD and Oppo - AVS Forum | Home Theater Discussions And Reviews
Old 11-13-2012, 07:35 AM - Thread Starter
G.M.'s Avatar
For anyone who is using an Oppo BDP-93 or BDP-103 with the the Kuro, could you tell me if you chose "source direct" or "1080p" on the Oppo menu when playing Standard Definition DVD's?
-George
G.M. is offline
Old 11-14-2012, 03:54 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 294 Post(s)
Liked: 4324
I would just leave it in source direct unless you see problems. If 1080p is 1080p60 you won't switch to 72hz mode with 1080p24 BDs.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
Old 11-15-2012, 06:51 AM - Thread Starter
G.M.'s Avatar
Larry, thanks for your reply and I understand your comment. What prompted my question was a discussion (probably on an Oppo forum a long time ago) about upscaling when the majority opinion then suggested using the device (TV or DVD Player) that would best display standard DVD content. If I recall correctly, I thought that the general consensus was to not use the Source Direct or Auto option on the Oppo setup menu. I'll try Source Direct for while and see if I notice any differences...
-G
G.M. is offline
