Optical to analog converter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2012, 07:43 AM - Thread Starter
donaudio's Avatar
Quoted: 14 Post(s)
I just purchased a plasma TV that only has an optical audio output. My integrated amp only has RCA inputs. Can you recommend a good converter for the audio? Thanks. Don
Donald S Konicoff
donaudio is offline
post #2 of 5 Old 11-13-2012, 07:52 AM
tackytiger's Avatar
The Fiio D03 is a reasonably priced, good sounding DAC
http://www.fiio.com.cn/product/index.aspx?ID=43&MenuID=020302
tackytiger is offline
post #3 of 5 Old 11-13-2012, 07:57 AM
iBrad's Avatar
Yeah, or some from ebay:
http://www.ebay.nl/itm/Digital-Optic-Coaxial-RCA-Toslink-Signal-to-Analog-Audio-Converter-Adapter-DVD-/261126567315?pt=US_Video_Cables_Adapters&hash=item3ccc5b3593
If your tv has headphone output, you can use a 3.5mm jack to stereo RCA cable too, is cheaper.
iBrad is offline
post #4 of 5 Old 11-13-2012, 08:14 AM
tomwil's Avatar
Liked: 26
Just be careful. Most of the converters only handle 2-channel conversions, not Dolby Digital.
My solution was finding a used cheap AV receiver.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #5 of 5 Old 11-13-2012, 09:26 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
You may not need a "good" DAC depending on your usage. Since your amp has only RCA inputs then i presume it's just a regular 2-ch stereo unit and not surround sound, in which case the cheap $20 Monoprice DAC would be sufficient (it only does 2-ch stereo).
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
