Flash Panasonic TC-P55ST50 into Panasonic TC-P55VT50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-13-2012, 12:57 PM - Thread Starter
knightmare777's Avatar
Does anyone recall the flash for a Samsung from two years back, to upgrade it from a 7000 to an 8000? It basically enabled menu features previously unavailable and reserved for the more expensive top end model.
I am wondering if it is possible to do the same with the new Panasonic plasmas as I have an ST50 and would like the added features like 10 point grey scale (vs 2) and 96hz, etc. etc. (although I am not sure I would use all that)
Thoughts?
knightmare777 is offline
post #2 of 4 Old 11-13-2012, 01:21 PM
adupree's Avatar
Even if you modified the software to do it, the limiting factor would be that they use different panels.
Ignorance is a choice
adupree is offline
post #3 of 4 Old 11-14-2012, 12:48 PM - Thread Starter
I see, so you are saying, the ST50 doesn't physically support ICFF or 96hz or 10-point grey scale changes, etc etc.?
I thought they were basically the same panel. (except a slightly better black level config on the VT)
post #4 of 4 Old 11-15-2012, 05:05 PM
weedeater's Avatar
ST is a single processor. VT is a dual processor.
I think the panels are the same but the boards are not. I don't think the drive is the same (just guessing), and the interface is different (more ports on the VT).
You might get closer with a GT rather than an ST, if it were possible at all.
weedeater is offline
Panasonic Viera Tc P55vt50 , Panasonic Viera Tc P55st50 55 Inch Plasma Tv
