Life expectancy for a Pioneer PDP-5010FD? Should I extend the warranty? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-15-2012, 09:11 AM - Thread Starter
shadestreet's Avatar
I am trying to decide if I should spend $360 to extend the warranty on my TV from Best Buy for another 2 years...
I got the TV as a floor model back in late 2008, and it gets quite a bit of use - have had no problems whatsoever.
This TV was a replacement for a Philips 42" TV, which also had the Best Buy warranty - it had died and Best Buy gave me full purchase price of original TV to apply to new TV - nevermind that prices had dropped tremendously between 2005 and 2008, they still allowed me to choose a TV that was $2,500 which is how I went from philips to pioneer.
I will probably skip the warranty, enjoy the TV for whatever life it has left, but if there is high chance with so many hours put on this TV I will run into problems, would be nice to pay $360 with chance of recouping $2500 later..
Any thoughts?
shadestreet is offline
post #2 of 7 Old 11-15-2012, 10:46 AM
tazz3's Avatar
Quoted: 26 Post(s)
well if you wanna pay 360 dollars and have peace of mind then do it. just make sure you get every thing in writeing
tazz3 is offline
post #3 of 7 Old 11-15-2012, 11:10 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Something else to consider: Best Buy might not even be around by the time your Pioneer goes belly up.
vinnie97 is offline
post #4 of 7 Old 11-15-2012, 11:40 AM - Thread Starter
Good point Vinnie. Very good point.
Can someone educate me on how to check hours and/or get to service menu on this model? Google not being as helpful as I expected...see links on how to do with newer Pioneers but not the 5010FD
post #5 of 7 Old 11-15-2012, 01:48 PM
seabreeze82's Avatar
@shadestreet, I have a 6010FD and was looking to see if there was a way to check the hours as well. I know there is
a way, as I read it somewhere, just cannot find it myself, will be glad to know if someone on these forums can tell us.
seabreeze82 is offline
post #6 of 7 Old 11-16-2012, 10:25 AM
adupree's Avatar
All of their plans are backed by an insurance company. So even if they to close you'll get your money.
Ignorance is a choice
adupree is offline
post #7 of 7 Old 02-15-2013, 08:47 PM
boca rat's Avatar
Mine still running fine, bought around the same time. Only issue I have is at some point a year ro so ago, this started: when I turn on the Bluray/receiver/tv with everything off using a Harmony, the screen stays dark and I have to unplug the TV to reset. If I start with 'watch TV' as in Dish, then 'watch bluray', all works OK. I suspect some HDMI issue though.
HTH
boca rat is offline
