Way to DISABLE TVGuide OnScreen on PDP-4280HD? - AVS Forum | Home Theater Discussions And Reviews
Old 11-15-2012, 09:13 AM - Thread Starter
donottosmeok's Avatar
Apparently, Rovi Corporation is discontinuing support for TVGuide OnScreen as it applies to OTA signals, which means my PDP-4280HD (using antenna for signal). So, the set's integral TVGOS system will no longer work.
Is there a way to DISABLE TVGuide OnScreen from functioning and/or trying to get updates while the set is either off or on? I want to clear ALL TVGOS DATA and get back to "square one." (And because it won't function, to DISABLE it seems the logical alternative.) Thank you.
Carver HR752 ~ Carver TFM35 ~ Sony XBR55X850C pretty soon (with Terk HDTVa OTA) ~ OPPO BDP103 ~ AQ Cinnamon HDMI video & Diamondback analog audio ~ Monster Z2 biwire ~ Polk Audio LSi15
Waste not, want not. Well, except maybe 4K OLED...that, I want.
(RIP, Sony KDL55W900A. Bought it brand new--the TV wasn't even 22 months old. Golly, what a great deal THAT was, Sony...)
donottosmeok is offline
