Are there any HD channels without logos? - AVS Forum | Home Theater Discussions And Reviews
Old 11-15-2012, 01:46 PM - Thread Starter
seabreeze82's Avatar
7 years ago I broke in my Pioneer TV with just playing HD Discovery Channel.
Today the 65" VT50 arrived and I started to look for HD channels without any
Logos.... Can anyone tell me which HD Channel is good for breaking in the TV?
I cannot play slides as I don't have a DVD Player attached to the TV....
Also would anyone know if there is a way to check if there are any pixels that are
burnt out? I know one has to have plain colors on the TV, can this be done through
the TV?
seabreeze82 is offline
Old 11-15-2012, 01:59 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
You don't need a DVD/Blu-Ray player to play the slides. You can download them to your computer and put them on a thumb drive then plug that into the USB port of the TV. Play the slides through the photo viewer from the media player in Vierra Tools.
HLdan is offline
Old 11-15-2012, 02:41 PM - Thread Starter
Okay great thanks a lot, where would I download the slides from?
Old 11-15-2012, 09:18 PM
Straybeat's Avatar
Break-in slides;
BreakIn_Images.zip 8k .zip file
eggwardo likes this.
Straybeat is offline
Old 11-16-2012, 10:30 AM
gheffty93's Avatar
So these slides break in the TV? And are you supposed to play them for 100 hours straight? Seems like a long time....and is it really all that necessary anymore? From what I've read it sounds like using the TV normally from day 1 is fine at this point.
gheffty93 is offline
Old 11-16-2012, 12:29 PM
adone36's Avatar
Liked: 37
Slides are for aging a tv prematurely to allow people to have them calibrated. They were never "necessary".
Tony
adone36 is offline
Old 11-16-2012, 12:38 PM
gheffty93's Avatar
Oh, ok. Thanks for clarifying that.
Old 11-18-2012, 08:06 AM - Thread Starter
Originally Posted by Straybeat View Post
Break-in slides;
Thank-you for that download, much appreciated ..... Going to get a USB to put them on, thanks again....
Old 11-18-2012, 08:16 AM
Trackman's Avatar
Quoted: 114 Post(s)
Liked: 98
You don't have to use slides. Other options are HDNET Movies channnel (just watch the aspect ratio - use stretch mode if need be), or long dvds that are 1.85:1 (Das Boot, Walking with Dinosaurs, etc.)
Go Duke !
Trackman is offline
Old 11-18-2012, 05:04 PM
Dierkdr's Avatar
Liked: 54
Don't know about other "cable" providers, but the Uverse STB will SHUT ITSELF OFF after a number of hours without receiving any command inputs.
This is one reason why we prefer using slides - on a SD card - for times when no one is Actively Watching the set: seems the "safest" option in terms of minimal failure possibilities...
Dierkdr is offline
Old 11-18-2012, 05:12 PM
gregzoll's Avatar
Liked: 33
Just hook it up, adjuust the settings for the picture and start watching tv. In six months to a year, rerun the calibration Blu-ray to adjust for any changes.
gregzoll is offline
Old 11-18-2012, 11:32 PM
Trackman's Avatar
Quoted: 114 Post(s)
Liked: 98
Yes, my Dish STB will do the same but I would never use any method when nobody's around - too much needless risk. Just turn the set off and resume when you return from wherever.
Go Duke !
Trackman is offline
Old 11-27-2012, 06:58 PM - Thread Starter
Hello... I broke the TV in by leaving HBO HD on, turned the sound down and let it play... 150 hours done...
TV looked awful out of the box, with some custom adjustments, it looked better and slowly it improved over
the days so much so that the picture is now amazing.... Still not watching anything like CNN ..... How much
longer do you think it will be safe to watch channels with logos? It's really silly that these people put these
bright logos on in the first place....
I also set it on a picture jogger mode, it's called something else, just can't recall now... Except it was explained
as shifting the picture slightly.... don't even notice it working, thinking of leaving it on all the time.....
I also HATE THE RED power light on this TV.... they should have put it to one side... Just bad design is all I
can say......
Old 11-27-2012, 07:04 PM
derek533's Avatar
Agree. With today's prevalence of plasma displays, it's just asinine to have these giant logs at the bottom of the screens all the time.
derek533 is offline
