No longer getting over the air tv guide info on Pioneer PDP 5070HD TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-15-2012, 04:45 PM - Thread Starter
djbuening's Avatar
About a week ago the tv guide info disappeared on my tv. I only have over the air antenna input. I reset it by changing zip code, but it did not reload the info after several overnight off cycles. I then cycled power and went through complete setup, but still am not getting any tv guide information. I wondered if this information was no longer being broadcast in the Indianapolis, IN area but can't find any information to support that thought. Just looking for help at this point on how to get it back. The clock also does not pick up the correct time - I had to change it to manual to set the correct time.
djbuening is offline
post #2 of 4 Old 11-15-2012, 05:30 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
This OTA TV Guide service has apparently been discontinued:
http://www.avsforum.com/t/1439331/way-to-disable-tvguide-onscreen-on-pdp-4280hd
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 4 Old 04-13-2013, 02:34 PM
TheNit's Avatar
I have a PDP4280 with the same problem, no TV Guide (EPG). How do you set the time manually? THe on;y plave that I've found that the time is updated is through the downloaded guide. It's annoying not having the correct time displayed on an expensize TV.
TheNit is offline
post #4 of 4 Old 04-13-2013, 03:20 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Yeah it does seem kinda stupid that you can't manually set the TV's clock, but i just realized that i never use my TV's clock function so is having it on your TV very useful? Since the TV Guide service is no longer available i would think that you don't need the TV to keep time any more.
Randy
