What is the correct device name for the T50GT50 and the Harmony One Remote. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-18-2012, 02:13 PM - Thread Starter
QlOMD's Avatar
Hi.
I reviewed the posts on universal remotes here, and (aside from the debate on the overall value of the remotes) they SEEM to note that Logitech supports the PC-T50GT50.
Yet, no matter what name variation I input at Logitch, it suggests i 'mate' the two remotes and program that way.
Is that the best method, or has anyone found the key to linking the GT50 and the Harmony series without that?
Regards
QlOMD is offline
post #2 of 4 Old 11-18-2012, 02:22 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
Try just Panasonic GT50 or TC-P50GT50. I did mine no problems, good luck.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 4 Old 11-18-2012, 02:41 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Originally Posted by QlOMD View Post
Hi.
I reviewed the posts on universal remotes here, and (aside from the debate on the overall value of the remotes) they SEEM to note that Logitech supports the PC-T50GT50. Yet, no matter what name variation I input at Logitch, it suggests i 'mate' the two remotes and program that way.
Regards
It could be because you have the model number completely wrong. It's TC-P50GT50, not PC-T50GT50.
If you can't get GT50 to work, ST50 or VT50 should work.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 4 Old 11-18-2012, 07:00 PM - Thread Starter
QlOMD's Avatar
You are exactly correct. Thanks for the pointer.
QlOMD is offline
