HELP: Picking a new 60 inch +/- HDTV for room with (1) Glare and (2) a need for Wide Viewing Angles - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-18-2012, 02:34 PM - Thread Starter
mkerdman's Avatar
I have a family room with tons of window glare and seating at both sides of the fireplace over which the HDTV must be mounted.
So, I need a 60 inch +/- HDTV that (1) deals well with glare (a superior glare filter) and (2) has superior wide viewing angles.
Thanks in advance for your help in this regard.
Murray Kerdman
mkerdman is offline
post #2 of 10 Old 11-18-2012, 03:22 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Viewing angles on LCDs and LED LCDs is nowhere near as wide as they are on Plasma TVs.
These Plasmas have a good AR Filter:
Panasonic: ST50 or GT50 series.
Samsung: PNE6500 or PNE7000 series.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 10 Old 11-18-2012, 03:27 PM - Thread Starter
mkerdman's Avatar
(1) Would I need to go for the VT50 Series, or are the AR Filters better or good enough on the ST50 and GT50 series?
(2) Would I need to go for the PNE8000 Series, or are the AR Filters better or good enough on the PNE6500 or PNE7000 series?
Murray Kerdman
mkerdman is offline
post #4 of 10 Old 11-19-2012, 10:04 AM - Thread Starter
mkerdman's Avatar
Bump
Murray Kerdman
mkerdman is offline
post #5 of 10 Old 11-19-2012, 02:06 PM
Dierkdr's Avatar
Liked: 54
Originally Posted by mkerdman View Post
Bump
Am guessing that the ST50, Or Up, in the Panasonic line - or the E6500, Or Up, in the Samsung line - ought to work pretty well.
What do the Reviews You've Read have to say about Bright Room viewing? Often gets mentioned in a review, even if only briefly.
If seriously concerned about glare, could also opt for the top 2012 LG plasma (9700, per memory), as it has a Matte finish screen....
Dierkdr is offline
post #6 of 10 Old 11-20-2012, 03:38 PM - Thread Starter
mkerdman's Avatar
Originally Posted by chambery View Post
Stay away from the Samsungs, here is mine after less than a year. And Samsung says they will not fix it under warranty. No explanation given, no ability to escalate my request upwards, nada. Service tech tells me Samsung has been denying warranty claims left and right the last few months compared to before. Samsung is more concerned with big profits than consumer satisfaction.
Yikes!!!!
Maybe I should look closely at the GT & VT Panasonic Plasmas.
Have they also been tougher on Warranty Claims of late?
Murray Kerdman
mkerdman is offline
post #7 of 10 Old 11-21-2012, 09:30 AM - Thread Starter
mkerdman's Avatar
Samsung and Panasonic Plasma's both seem to have equal amounts of fans and detractors here.
Glare is not often mentioned.
I saw the LG locally and it had poor PQ to my eye.
Murray Kerdman
mkerdman is offline
post #8 of 10 Old 11-21-2012, 10:13 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
If the VT50 is in your budget get that.
/thread
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #9 of 10 Old 11-21-2012, 10:16 AM - Thread Starter
mkerdman's Avatar
/thread
Aside from 3D, which I do not care about, is there much difference between the VT50, GT50 and the ST50 for family room (not dedicated primary home theater) viewing?
Murray Kerdman
mkerdman is offline
post #10 of 10 Old 11-21-2012, 10:54 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
I haven't compared all three side by side (by side...) so I can't tell you for sure. But, if I remember correctly the ST and GT have the same AR filter. Only real way to tell is to get them in your home and mounted. It also depends on how picky the viewing audience is. My wife & kids probably wouldn't care b/t the sets but I may.
UGAd13 is offline
