Quick wall mount question for 65" Panasonic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-23-2012, 10:21 PM - Thread Starter
SeamusMc's Avatar
I'm going to hang my new Panasonic TC-P65VT 50 on the wall. I was on Amazon and some commented that both Sanus mounts (LT 25 and VMPLA 50 A) would not fit the TV properly.
I also looked at the OMNI FPK200FT. Will that mount work well with the 65"? I like the feature of the Sanus that let's you adjust for level after hanging but if I have to get the Omni so be it.
SeamusMc is offline
post #2 of 3 Old 11-23-2012, 11:27 PM
ttnuagmada's Avatar
Quoted: 122 Post(s)
Liked: 113
I got this one over a year ago and have had no problems with my 65 inch ST30.
ttnuagmada is offline
post #3 of 3 Old 11-24-2012, 07:01 AM - Thread Starter
SeamusMc's Avatar
Thanks a lot! Checking out the Cheetah.
Went with the Sanus. Perfect.
SeamusMc is offline
