P50S30 Color Temp SM Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-24-2012, 11:04 PM - Thread Starter
rzimmerman30's Avatar
Could anyone please post their settings for Cool, Normal, and Warm in the SM? Somehow no matter what I choose Cool 2, Cool 1, Normal, Warm 1, or Warm 2 it all stays the same. And when I look in the SM, all the settings are exactly the same. I'm hoping someone could possibly go in and list all the different settings for Cool, Normal, and Warm so I can see exactly what is wrong? Any help would greatly, greatly be appreciated!
rzimmerman30 is offline
post #2 of 2 Old 11-25-2012, 02:13 PM
iBrad's Avatar
So you messed up the Service Menu settings without saving a backup to the SD card first or written down first?
The are 2 screenmodes SM adjustments, for SD and HD.
For SD: put on a (SD) tv channel and enter here into the Service Menu.
For HD: connect HDMI with a HD signal 720p/1080p and enter into SM.
The CORRECT input settings SEQUENCE for WB ADj. (both SD/HD have same values) is FROM:
1) COOL
ALL CUT 80
ALL DRV FF
R CUT 80
G CUT 80
B CUT 80
R DRV E2
G DRV FF
B DRV D4
2) NORMAL
ALL CUT 80
ALL DRV FF
R CUT 80
G CUT 80
B CUT 80
R DRV EA
G DRV FF
B DRV 9C
3) WARM
ALL CUT 80
ALL DRV FF
R CUT 80
G CUT 80
B CUT 80
R DRV F5
G DRV FF
B DRV 81
You may try my own calibrated COOL WB for superb true/pure white/black, lifelike vibrant colors SPECIAL for PC/PS3/BR video/graphics use!:
1) COOL
ALL CUT 7F
ALL DRV EB
R CUT 6C
G CUT 76
B CUT 7F
R DRV D3
G DRV EB
B DRV CA
I only use my COOL WB as all the factory WBs are too red/orange/yellowish, not lifelike!
iBrad is offline
Panasonic Viera Tc P50s30 50 Inch Plasma Hdtv
