my pnd7000 keeps changing picture settings on its own - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-27-2012, 04:21 PM - Thread Starter
lanthanidedude's Avatar
any help here? my pnd7000 keeps changing the setting from relax to dynamic on its own. also, i cant fix the brightness pops, my version is a more updated version than the firmware with brightness pop fix and it doesn't let me go down.
lanthanidedude is offline
post #2 of 6 Old 11-27-2012, 07:54 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
What, it changes from relax to dynamic right in the middle of watching something? How do you have your tv setup? Single hdmi input from an avr or separate inputs or what? Sorry to hear about your pops, not a problem experienced with my d8000
lovinthehd is offline
post #3 of 6 Old 11-28-2012, 09:57 PM
Straybeat's Avatar
Have you recently done a firmware upgrade? I did one a few weeks ago that kept doing that (going to Dynamic on it's own, etc.) and a reset fixed it.
Straybeat is offline
post #4 of 6 Old 12-03-2012, 09:02 PM - Thread Starter
how do i do a reset?
i think its in Demo mode. how do i get it off demo mode, could this be causing the problem? also the tv is not saving my settings its driving me mad!
loveinthehd- single hdmi, and yes right in the middle of watching something.
straybeat- i did a firmware update AFTER i started having this problem in hopes it would fix it, it didn't
thanks guys
post #5 of 6 Old 12-03-2012, 09:12 PM
Maglin's Avatar
You can reset it by holding exit for 30 seconds. Also you can downgrade the firmware over the net with samgo or something like that. I just downgraded mine today and was able to use an app to get into th SM and apply the FBR fix. I'll post links latter but all of this can be found on this forum
Sent from my Amazon Kindle Fire using Tapatalk 2
Maglin is offline
post #6 of 6 Old 12-06-2012, 07:55 AM - Thread Starter
The reset helped with the auto pic change problem (prob because it was on demo mode)
