Plasma plugged/set in 24 hours? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-29-2012, 04:59 PM - Thread Starter
ConfusedAndLost's Avatar
Hello I have heard a lot of conflicting arguments on wether a plasma should be standing up for 24 hours after delivery if it was not vertical (mine was at a 45 degree angle). It sort of seems like a myth, but whatever it has been 24 hours. Now what confused was that the delivery man said it needed to be in room temperature for 24 hours because it was transported from my parents house to mine and it is pretty cold. I assumed this had to do with gasses, but I don't know. My main concern though is that should my tv have been plugged in to perhaps get a current and warm up the gasses or all of this just wrong? I really am at a loss, thanks.
ConfusedAndLost is offline
post #2 of 4 Old 11-29-2012, 05:39 PM
stevel's Avatar
The gases are fine - but did you have the dealer exchange the summer gas with winter gas? tongue.gif
The set just needs to come to room temperature, I would think. That said, flatscreen TVs of any larger size don't like being tilted or laid flat, as the screen can warp subtly due to weight of the glass.
Steve
stevel is offline
post #3 of 4 Old 11-29-2012, 08:33 PM
jdcrox's Avatar
Quoted: 80 Post(s)
Liked: 107
After any electronic item is brought from extended cold to a warm room, it should be allowed to reach room temp before being turned on. It has to do with condensation forming on the circuits, which can be a bad thing.
jdcrox is offline
post #4 of 4 Old 11-30-2012, 06:01 AM
Ph8te's Avatar
Quoted: 4810 Post(s)
Liked: 4359
+1 to This
Ph8te is offline
