Panasonic TC-P55GT30 SD Card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-01-2012, 05:30 PM - Thread Starter
Irvinraw's Avatar
I have the Panasonic Plasma TV model TC-P55GT30. I just purchased the largest SD card I could so I can use it for the TV. I purchased a 128GB SD Card and noticed it didn't work with the TV. I inserted the card and TV indicated that no card was inserted. So I pulled out the manual and it says the TV can handle a max of 64gb SD card. I know, I know...I should have read the manual before buying the card. Anyway, does anyone know if there is a way I can coax the TV in using this SD card? I would hate to have to buy another 64GB card.
Irvinraw is offline
post #2 of 2 Old 12-02-2012, 12:09 AM
iBrad's Avatar
Very simple, just use an USB SD/multicard reader, search on ebay.
128GB? (are they fake?) will be slow as turtle to fill it up, slow read/write speeds.
Btw, you can use microSD cards with a SDcard adapter too.
iBrad is offline
Panasonic Viera Tc P55gt30 55 Inch 1080p 3d Plasma Hdtv
