Help me decide! Panasonic 55UT50 or LG 60PA6550? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-09-2012, 06:20 AM - Thread Starter
timatraw's Avatar
Quoted: 24 Post(s)
I am looking to buy the best plasma for under a grand.
Costco is selling these plasmas for the same price.
Im having trouble deciding on which one to buy.
Which one do you think has the better picture?
Is bigger always better?
The panny is 55" and the LG is 60"
Which one would you buy? (My primary tv is the famed 60" Kuro).
I will be using this in a patio room that gets a lot of outside light although the room is in the shade.
Mostly sports and movies.
Thanks for your opinion.
Tim
timatraw is offline
post #2 of 11 Old 12-09-2012, 06:28 AM
chunon's Avatar
Quoted: 2017 Post(s)
Liked: 1775
Tim
The blacks are better on the UT50 for sure, it has no AR coating tho so glare may be an issue.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 11 Old 12-09-2012, 09:23 AM - Thread Starter
timatraw's Avatar
Quoted: 24 Post(s)
Do I go for the LG because it has the larger screen?
timatraw is offline
post #4 of 11 Old 12-09-2012, 09:59 AM
chunon's Avatar
Liked: 1775
You might have a glare problem either way. Do you want 3d ? If not might want to take a look at the 60 U50/54
65C6 OLED
post #5 of 11 Old 12-09-2012, 10:13 AM - Thread Starter
timatraw's Avatar
Quoted: 24 Post(s)
3d not necessary but the 55UT50 has 3d capability which is a nice option for the price.
The LG is 60 " but I wonder if 5" in screen size is that significant.
From what I'm reading the panny generally has the better picture.
timatraw is offline
post #6 of 11 Old 12-09-2012, 11:29 AM
MechanicalMan's Avatar
The LG should be capable of a brighter image and possibly better color accuracy if properly calibrated, but the contrast ratio will be much worse. LGs also have bad color banding, and I'm not sure about the newest models, but they've had bad dithering in the past. Pick your poison. I personally would rather spend extra for the ST50, but choosing between the two, I would pick the UT50. I own an older LG, so I already know how much some the LG issues bother me.
As chunon said, if you are interested in the UT50 and don't care about 3D, then it would make more sense to buy the 60" U50/U54. It's very inexpensive -- probably the same or less than the 55" UT50.
MechanicalMan is offline
post #7 of 11 Old 12-09-2012, 08:02 PM
Websniper's Avatar
I happen to be in a very similar situation myself. I currently have had the LG model listed above for about 3 weeks. The display replaced 2 edge lit LED models that had terrible bleed through, horrible motion/judder and overall crummy picture.
The LG has a decent display, but I'm by no means an expert. Mine is in a daylight basement, but is watched largely with the lights off at night.
I'd like to add that I think the 60 seems a smidge too big for me when sitting at 11 feet. I'm wondering if the 55" would make any difference at that distance...
Also, if the general concensus is that the Panny is superior picture-wise, I'd be willing to give up 5" of display for it and having the option of 3D.
Websniper is offline
post #8 of 11 Old 12-09-2012, 09:09 PM
From what I've read, the major issue with the UT50 (and U50) is that color accuracy is poor in all picture modes except cinema, and max luminance is low in cinema. Many of us like to target 40 fL (or close to it) even in a dark room, and both CNET reviews mention that the U models can't reach that -- at least one of the displays reviewed could only hit 33 fL in cinema mode with contrast maxed. The ST50 can achieve pretty accurate color in other picture modes (it also has a gamma setting and white balance controls in the user menu), so you can achieve both a bright image and accurate color, whereas the U models force you to choose between a dim image with decent color or a brighter image with poor color. For me, that makes the UT50 an unattractive option, considering the relatively small price difference between the UT50 and the ST50. All of the Panasonics will be better in some areas, like contrast ratio, than the LG.
post #9 of 11 Old 12-11-2012, 02:38 PM
Websniper's Avatar
I hate to say it, but that is a discouraging bit of info. I like to limit my large electronic purchases to Costco for the extended warranties.
I'm no videophile, but I like quality, and I can tell you that I hated the PQ on two edge-lit LED's that I purchased. Would you guys say the UT is still superior to most budget edge lit LED sets?
post #10 of 11 Old 12-11-2012, 02:57 PM
chunon's Avatar
Liked: 1775
I would say yes Plasma almost always beats LED unless you are talking flagship models.
65C6 OLED
post #11 of 11 Old 12-11-2012, 04:15 PM
hotskins's Avatar
Quoted: 60 Post(s)
Liked: 68
get the panny plasma. much better picture quality
hotskins is offline
Panasonic Viera Tc P55ut50 Plasma Tv , Lg 60 Inch Plasma 60pa550c
