Sharp Aquos lc45gd6u E202 error (failed to receive broadcast)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-12-2012, 01:18 PM - Thread Starter
heismanwatch's Avatar
Sharp Aquos lc45gd6u E202 signal error (no signal received)???
Upon installing a used Sharp above referenced an error E202 came across the flat screen. I'm not able to view any channels even the the previous old non HD TV that was connected to the cable box was working fine.
I did try connecting the coaxial cable in both the Digital and Analog inputs to see if they was an issue without success.
The TV is set Air (Analog A, Analog B, Digital) and the channels ran their setup on EZ setup as well without success.
It is as if the Sharp isn't receiving a signal E202 even though the cable box has a green light.
Please advise solution. Thanks in advance.
heismanwatch is offline
