Basic A/V Connection Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-13-2012, 08:30 AM - Thread Starter
kitjv's Avatar
I want to connect a laptop to a Panasonic Viera plasma TV for a slideshow presentation. My laptop (MacBook Pro) is connected with a DVI-HDMI cable. The video plays fine; but no audio. Question: Can a DVI-HDMI cable transfer an audio signal?
Thank you.
kitjv is offline
post #2 of 4 Old 12-13-2012, 08:59 AM
adone36's Avatar
Liked: 37
DVI does not carry audio. You either have to run audio out on the computer to a sound system, or connect via dvi to vga to the tv and then connect an audio cable from the computer to the audio ins on the tv corresponding to the vga port to get sound from the tv's speakers.
Tony
adone36 is offline
post #3 of 4 Old 12-13-2012, 09:28 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Thank you.
It would be helpful if you'd provide the model number of your particular Panasonic, but if you check your owner's manual there should be instructions on getting audio from a DVI source connected to an HDMI input. On my GT50, i'd have to connect an audio cable from the laptop's headphone/speaker jack output to the analog audio input on my TV's Component/Composite Video input, then go into the audio menu and associate audio on that HDMI input to the Component/Composite Video input. Hopefully your TV has the same method available.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 4 Old 12-13-2012, 02:33 PM - Thread Starter
kitjv's Avatar
Thank you for the responses. So I resolved my problem by using a DVI-HDMI cable to carry the video & another cable from the laptop's headphone jack to the audio input connectors on the back of the TV.
Thanks again.
kitjv is offline
