Help updating me on brand quality? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 12-24-2012, 08:21 PM
761-honda's Avatar
Its been a couple of years since I bought Plasmas.
In 2010 I got a
65 Panasonic S2
58 Samsung C8000
I feel the highly rated C8000 has that CRT look to it if that makes sense. I bump up that cell light and gamma rather high to get it to be anywhere bright.
The lower rated S2 is plenty bright for a plasma and its almost LED bright.
While I would not buy the higher priced LG plasma the low and mid level ones look pretty much split between dim and bright. Its important to get a bright plasma as I had a dim one before and took a bath to unload it on CL.
761-honda is offline
post #32 of 39 Old 12-24-2012, 09:45 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
^Sure, if yer gonna' watch it in a sunroom.
vinnie97 is offline
post #33 of 39 Old 12-25-2012, 09:48 AM
adone36's Avatar
Liked: 37
It doesn't matter if somebody has had an LG for 20 years "and nuttin' broke"
It doesn't matter if your Uncle Louie and 12 of his friends think LG is the bestest Tv in the whole wide world.
The answer to the op's question was my answering post.
While many can go by what they "think", I'll take the data anytime.
Tony
adone36 is offline
post #34 of 39 Old 12-25-2012, 10:02 AM
mailiang's Avatar
Quoted: 860 Post(s)
Liked: 590
I read the reviews, look at the data, look at the TV, and then decide if it's the right set for me.
Seems simple enough, don't you agree?
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #35 of 39 Old 12-25-2012, 03:32 PM
Hamerdown's Avatar
All due respects...maybe you'll take the "data"...because you can't believe your eyes are seeing anything good! rolleyes.gif
Example...decades ago I wanted and researched Audio speakers till my eyes blead and head pounded...then... frustrated and burned-out I put down all the review papers and ignored what 'meters/data' said.
I turned my back to a line-up of speakers, had a friend hit the switchblade buttons and I picked out what sounded the BEST to me.
Turns out I saved a lot of $$$ and 23 years later I couldn't have done it a BETTER way. Ended up with JBL LT100T3 > and still amazing to 'me' cool.gif
Moral of this story...sometimes 'you' have to trust and believe what you see, and hear. wink.gif
Hamerdown is offline
post #36 of 39 Old 12-25-2012, 04:07 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Vic12345 is offline
post #37 of 39 Old 12-25-2012, 06:43 PM
chunon's Avatar
Quoted: 2196 Post(s)
Liked: 1903
Imo
Panny first samsung a close second and then lg a distant third
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #38 of 39 Old 12-25-2012, 08:56 PM
remodeler's Avatar
I have to say I did not want Plasma when I needed a new TV. (You can see some of my other posts about this I have relayed this story a couple of times.) I was convinced by several salesmen at different stores telling me pretty much the same thing, to buy a Panasonic Plasma which I did. I love the set. (tcp 60UT50) We later bought a new set for the Bedroom and we went with an LCD as we only wanted a 40"and you cannot get a 1080p set in that size. I couldn't stand the picture. I ended up going to the 43" Samsung from Sams and it smoked the LCD we had purchased and It holds it's own with the Panasonic if not beating it outright. I will never go back to an LCD If I have the choice.
remodeler is offline
post #39 of 39 Old 12-26-2012, 02:38 PM
PCD
PCD's Avatar
Just another point to remember (no matter which brand is chosen), IF you are on a budget, keep in mind that your 3D TV (if you go that route) will cost you a few more bucks later. My set uses active glasses and I purchased the same brand as the TV, so $150.00 there for 2 pair, then i got the same brand 3D BD Player which was on sale for $100. (reg $169). All prices before tax.
So AFTER the set was purchased, I spent 20%+ of what I spent on the set itself.
Just something to keep in mind....
Pete
Evil Sysadmin
PCD is offline
