VT50 yellow-ish blob on display - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
Old 02-07-2014, 09:14 PM
mysammy64's Avatar
Had my screen replaced...looked great until now..I have the blinking red light of death..anyone seen this before? When you try to turn it on the screen flashes for a second then shuts off and the bottom red light flashes indefinitely
mysammy64 is offline
Old 02-07-2014, 09:48 PM
mo949's Avatar
Liked: 1114
Never heard of that for years. Post a short clip of it happening?
mo949 is offline
Old 02-07-2014, 10:26 PM
mysammy64's Avatar
http://m.youtube.com/watch?v=G-9uThE2lxs
Hope this works let me know
Old 02-08-2014, 01:13 AM
mo949's Avatar
Liked: 1114
Works great! How long will it flash? Previously it would be 7 time and would be from a failed circuit on one of the boards.
mo949 is offline
Old 02-08-2014, 07:44 AM
mysammy64's Avatar
It blinks 8 times... I ha e all kinds of issues with Panasonic.they have no record of the service done and screen replacement.. Had my name and address misspelled also wrong zip code. To top it off the case I used is tied to someone else..thus mine shows only the original complaint of the blobs..the photos i sent and any correspondence after does not exist
Old 02-08-2014, 08:41 AM
mysammy64's Avatar
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS P-Board
3 blinks 3.3v SOS D-Board / DN-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS P-Board / D-Board / DN-Board
6 blinks Driver SOS 1 SC-Board
7 blinks Driver SOS 2 SC-Board / SU-Board / SD-Board
8 blinks Driver SOS 3 SS-Board / SS2-Board
9 blinks Panel Config. SOS D-Board / DN-Board
10 blinks Communication Error btwn Terminal Board / DS-Board
Panel MPU & SCW4-MPU
11 blinks Fan SOS PB-Board / Fan
12 blinks DN Config SOS DN-Board
13 blinks 3.5 / 2.5 / 1.8v SOS DN-Board
Old 02-08-2014, 08:42 AM
mysammy64's Avatar
Guess mySOS 3 SS-Board / SS2-Board is bad
Old 02-08-2014, 10:41 AM
mo949's Avatar
Liked: 1114
I think you are right. Although vt50 codes (which I can't find for you-sorry) are probably similar to the vt20 ones. One things for sure is that a technician should know exactly what that means. frown.gif
mo949 is offline
Old 02-08-2014, 10:47 AM
mysammy64's Avatar
I wonder if I can get a vt60 out of Panasonic for this hassle... If it goes into service again who knows what else will break since now the only warranty left is the 30 or 90 days they give after the repair..
Old 02-08-2014, 05:28 PM
mo949's Avatar
Liked: 1114
That's the big hope.
mo949 is offline
Old 02-08-2014, 08:05 PM
Donat76's Avatar
Liked: 32
Could be a loose or damaged ribbon cable, damaged SS / SS2 board ribbon cable connector, damaged panel connectors (would need to replace whole panel), damaged SS / SS2 board. This is for the VT60 but the wiring is pretty similar. If there is damage to the SS or SS2 boards it may be ESD (electro static discharge) damage which won't be physically noticeable and sometimes takes time to show up. I am amazed that many of these technicians don't take ESD precautions when working on these sets. Grounded wrist strap and ground the TV or at the very least touching metal parts on the TV often to equalize any charge. Those small ICs are very fragile when it comes to ESD.
I am hoping for a loose ribbon cable.
Top right schematic. You can download and zoom.
Donat76 is offline
Old 02-10-2014, 05:30 PM
mysammy64's Avatar
Thanks for the info..i hope i dont need to dig into it since there is still a warranty after the repair.. Not sure for how long servce guy said 30 days i thought it was 90...this is day 29
Old 02-10-2014, 05:41 PM
Donat76's Avatar
Liked: 32
If you report the issue before the end of the warranty, it doesn't matter when the technician shows up. If you already have a new Panasonic case number, i wouldn't worry just because it may be the last day of the warranty.
Donat76 is offline
Old 02-10-2014, 07:21 PM
mysammy64's Avatar
I called but they couldnt process the complaint because the panel replacement was not attached to my old case# and the original warranty has lapsed.. Still waiting for the tech who serviced it to call me with the case# he used...
Donat76 likes this.
Old 02-11-2014, 05:48 PM
mysammy64's Avatar
Well because i called today day 31 panasonic said its out of warranty but he made a note about me calling in on the 28th day. Thwy escalated the case and i will hear something back in the next 24-48 hours....
Old 02-13-2014, 06:05 PM
mysammy64's Avatar
Panasonic will not help And Refers Me Back To The Servicer Who Will Not Return my calls.... They say i am responsible for the repairs and since it failed within days of the repair its the servicer who is responsible.... then i asked for another servicer and they gave me the same guy... the next closest is over 100miles away.....
Old 02-17-2014, 07:41 PM
Dave_O's Avatar
Some measurements of screen temperature and the effect of fans. As expected, driving the screen with brighter settings increases the temperatures. Upper left and right locations correspond to visual blobs.
TV Panasonic TC-P65VT50
3 Fans NOCTUA FAN NF-P12-1300 NINE - Ultra low noise resistors
Video Source Disney WOW Pixel Flipper
Room temp 67 degrees (F)
Thermometer Craftsman IR Model 50455
Donat76 and mo949 like this.
Dave_O is offline
Old 02-17-2014, 08:35 PM
mysammy64's Avatar
I have purchased 4 of thoses fans and a controller...how are you attaching these to the tv? Are there any vents that the fans are sitting on?
Old 02-17-2014, 08:55 PM
Dave_O's Avatar
I use Velcro tape with adhesive backing, and each fan is centered on the perforated vent behind the circuit boards.
Dave_O is offline
Old 02-17-2014, 09:50 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
No concerns of drawing dust into the panel? Are the fans filtered in some way?
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
Old 02-17-2014, 09:57 PM
Dave_O's Avatar
Fans blow air out, no filters. Worried more about panel damage than dust. Even at the lowest speed, fans do make noise that might bother some people.
Dave_O is offline
Old 02-18-2014, 12:43 AM
mo949's Avatar
Liked: 1114
There were already fans on the tv before we added any. If you get a good enough seal around the fans ( i used real hvac tape) and run it with the medium resistor you can get a lot cooler. In my night mode I can have them switch off.also som blob pics had one at top center so I stuck my 3rd fan there (smaller noctua). Don't hear them over the sound system personally but when the tv is off and they are running I can. Still running 100 percent blob free.
Good measurements.
mo949 is offline
Old 02-21-2014, 09:57 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
Open heart surgery on my beloved 65VT50. I think I'm going to be sick!!
scirica is offline
Old 02-21-2014, 01:39 PM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1774
Yikes !!!
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
Old 02-21-2014, 01:41 PM
merccrazy's Avatar
Do they reset the software to new for breakin when they replace a panel?
merccrazy is offline
Old 02-21-2014, 02:11 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
Nope...all the boards transfer over to the new panel. I still have my ISF Mode calibrations and everything. Still need to have Chad come back out to calibrate the new panel as soon as I put some hours on it. In the meantime, THX Cinema is my friend cool.gif
scirica is offline
Old 02-21-2014, 02:30 PM
Dave_O's Avatar
And THX Cinema looks pretty much as it did?
Dave_O is offline
Old 02-21-2014, 03:26 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
To my eye, yes. Looks good.
scirica is offline
Old 02-25-2014, 06:39 PM
irisservice's Avatar
tagging along
irisservice is offline
Old 02-25-2014, 10:06 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
5 days with the new panel. So far so good. I was really hoping for a VT60 but this panel is a keeper. I'll report back after 500 hours or so.
scirica is offline
Panasonic Viera Tc P55vt50 , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
