VT50 yellow-ish blob on display - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #91 of 1025 Old 06-20-2013, 04:55 PM
chadwick537's Avatar
Sorry - i switched from low to high, not high to low.
chadwick537 is offline
post #92 of 1025 Old 06-20-2013, 05:25 PM
avsDD's Avatar
Originally Posted by tom669 View Post
It's in the service menu. VSUS HIGH or LOW.
How do I get into this service menu ?
avsDD is offline
post #93 of 1025 Old 06-20-2013, 05:30 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
Ok, that makes sense now. Wondering how this affects my calibration, if at all.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #94 of 1025 Old 06-20-2013, 06:18 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
So I've been playing with this in the service menu (very carefully) and it has a very obvious effect on the blobs to the left and right of the panel. I'm not sure yet if I've correctly confirmed the change from Low to High as there may be one more step. Would the term "Write" be the same as Save? Each time I go back into the service menu without doing anything other than toggling to High, it appears to be back to Low.
There is potential here, but I'm not yet sure I've made a permanent change. And of course I'd need Chad B to come back and double-check my calibration to see if this has thrown anything off. There certainly isn't anything obvious.
Update: I did have to put it in "Write" mode, then OK to make change permanent. Going to watch for blobs for a while and see what I see. If this works, may be time for another calibration!
scirica is offline
post #95 of 1025 Old 06-23-2013, 12:21 PM
tool2010's Avatar
What must i do in the service menu to change this option ?
Wich keys ?
tool2010 is offline
post #96 of 1025 Old 06-23-2013, 04:18 PM
avsDD's Avatar
Every time I change VSUS from low to high, the picture mode is changing from custom to vivid. How do I change VSUS specifically for custom picture mode ?
avsDD is offline
post #97 of 1025 Old 06-23-2013, 04:22 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Anyone else try this,
If this "solution" forces me into vivid mode,
Then I may just have to live with this discoloration for the few times that I watch hockey
Vivid is by far the worst looking of all the possible modes out there
billmich is offline
post #98 of 1025 Old 06-23-2013, 04:24 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
The service mode temporarily puts the panel into Vivid mode, but that should revert and VSUS bit will stay high once service mode is exited.
mo949 likes this.
tom669 is offline
post #99 of 1025 Old 06-23-2013, 04:34 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Thank you
billmich is offline
post #100 of 1025 Old 06-23-2013, 04:41 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
By using the number 9 key, you will toggle through modes until you get to Custom. When you first get to VSUS it's on Vivid...you need to get to Custom.
scirica is offline
post #101 of 1025 Old 06-23-2013, 04:59 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
What exactly is being changed ? Voltage? Is it safe ?
I have no existing issues just curious what the change actually does
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #102 of 1025 Old 06-23-2013, 05:00 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Does this void any extended warranty?
billmich is offline
post #103 of 1025 Old 06-23-2013, 05:10 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
It's an available service menu adjustment and can be changed back to low. Will not void a warranty.
scirica is offline
post #104 of 1025 Old 06-23-2013, 06:11 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 846
Just curious, how do you know for sure that playing in the service menu "Will not void a warranty". Or are you assuming that everybody will know exactly what they changed in the service menu and be able to reset any and all changed settings back to what they were if something goes wrong.
Also, what if any are the long term effects of just changing "VSUS from low to high".
Remember there is no reset button in the service menu. And as far as I know the reset to factor setting button in the user menu will not make any changes to the service menu.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #105 of 1025 Old 06-23-2013, 07:46 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Which begs the question what exactly does this VSUS DO in the first place? what are the long-term effects of switching it to high?
billmich is offline
post #106 of 1025 Old 06-24-2013, 12:27 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
VSUS is the Sustain voltage.
Increasing it puts a little more energy into the panel, reducing efficiency slightly, but improving the chance of a successful gas discharge.
It only voids the warranty if they find out, which they won't, as the service menu doesn't record access.
mo949 likes this.
tom669 is offline
post #107 of 1025 Old 06-24-2013, 03:59 AM
chunon's Avatar
Liked: 1772
A
And the blobs are a side effect of gas not discharging ? What are some of the other effects ?
65C6 OLED
post #108 of 1025 Old 06-24-2013, 04:03 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Originally Posted by chunon View Post
A
Flickering or stuck dead pixels, pink/purple diffuse tint (esp. on bright images), cyan maldischarge in middle of display (esp. on full white/bright images), yellow blobs, or dim red tinted display. From most common to least common.
tom669 is offline
post #109 of 1025 Old 06-24-2013, 07:36 AM
chunon's Avatar
Liked: 1772
Thank for that info Tom
65C6 OLED
post #110 of 1025 Old 06-24-2013, 07:57 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
ss
SS: You are correct, I don't know for certain that this will not void the warranty, but I was assuming that one a) Did not mistakenly reset anything else in the service menu and b) that there is no tracking of consumer activity in the service menu. I shouldn't have been so bold as to make that absolute statement, and I thank Tom669 for the additional information on Sustain Voltage.
Sounds to me that the lower voltage may be a compromise between panel effectiveness and energy efficiency. Given the efforts to maintain "green" or "eco" standards this lower sustain voltage may be part of that compromise. Based on Tom's information, it sounds like a calibration re-check would be in order when changing to VSUS High.
I wonder if this will have a negative effect on panel life as well.
scirica is offline
post #111 of 1025 Old 06-24-2013, 08:00 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
I've run a 195V (VSUS) Panasonic plasma on 210V. The picture quality improved considerably, because I could lower the VAD (from -140V to -120V), and subsequently lower the black level by a large amount. No lifetime problems noticed so far; the panel does run a bit brighter though.
tom669 is offline
post #112 of 1025 Old 06-24-2013, 08:24 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
What is VAD?
billmich is offline
post #113 of 1025 Old 06-24-2013, 08:42 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
What is VAD?
Not applicable to newer panels (mine was 2008) but it is the voltage used to both select the rows of the panel in the addressing portion, and also for the negative portion of the initialisation ramp, which is the main source of panel black glow. Dropping VAD decreases the probability of a successful gas discharge, so you have to increase VSUS to provide more energy to the panel and get the panel to the point where you have minimal black level and maximum discharge performance. I ended up with a few dead pixels, because I could tolerate them on a 42" screen from a 6ft distance (increasing VAD got rid of dead pixels but black level rose.)
tom669 is offline
post #114 of 1025 Old 06-24-2013, 10:42 AM
avsDD's Avatar
When I reach into VSUS sub-menu(by key 1or 2), key 9 is not available (only 1,2 and 5) and based on background image - panel is clearly switching to VIVID mode.
Is this VSUS value shared between all picture modes(custom, vivid, standard) ?
avsDD is offline
post #115 of 1025 Old 06-24-2013, 11:01 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
After activating Service Mode (Vol Down on set + Info 3x) you will then hit "2". This will come up in "Vivid" mode and then you will see 9 available to toggle through the modes. Toggle to Custom, and THEN Use "2" to get you to VSUS. I think you are out of sequence.
scirica is offline
post #116 of 1025 Old 06-24-2013, 11:09 AM
Just wanted to leave an update -- I had switched my VSUS about a week ago now -- I haven't noticed any negative side effects from the switch -- the yellow blobs are completely gone. My panel isn't under warranty, so I guess I'm alright with the risk. Panasonic basically said that if they send out a tech and the panel needs to be replaced, they aren't going to be doing a whole lot for me anyways. At this point, I guess I'll enjoy my set and hope there aren't any long term side effects!
post #117 of 1025 Old 06-24-2013, 11:12 AM
avsDD's Avatar
Again, I can switch mode to Custom outside of VSUS submenu (key "9"). But as soon as I reach VSUS submenu (by "2" or "1") - panel is going back to VIVID.
avsDD is offline
post #118 of 1025 Old 06-24-2013, 11:18 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
Ok, for some reason you are getting different results than me as I walk through the menus. Once I toggle to Custom with the 9 key, I hit 2 until VSUS comes up and I can Test and make my change.
Sorry I couldn't help.
SC
scirica is offline
post #119 of 1025 Old 06-24-2013, 11:40 AM
avsDD's Avatar
And question remains - is VSUS setting value shared by all picture modes or could it be set _differently_ for vivid/custom/standard ?
avsDD is offline
post #120 of 1025 Old 06-24-2013, 12:16 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
I'd be interested to know this as well. I'm seeing positive results (no more blobs) in my ISF Day and ISF Night modes even though all I could touch with VSUS was Custom. Perhaps they share VSUS settings, perhaps it's universal. Very important detail!
billmich likes this.
scirica is offline
Panasonic Viera Tc P55vt50 , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
