VT50 yellow-ish blob on display - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 1025 Old 01-01-2013, 01:50 PM - Thread Starter
newfinator's Avatar
I have a VT50 which I've been enjoying since the summer but recently noticed that, while watching Hockey, I can see two small regions on the right and left edges of the screen that have a slight yellow or green tint to them. I probably would never have picked up on it if it weren't for that predominant white of the ice on the screen. It's actually fairly subtle and probably wouldn't translate in a photo but is hard to un-see once noticed. It somewhat reminds me of what my old projection TV looked like when it was on it's last legs. It certainly doesn't bother me as is but am concerned that it may be an indicator of things to come. Any ideas of what that might be?
newfinator is offline
post #2 of 1025 Old 01-01-2013, 02:09 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
There is a GT50 owner on that thread having same issue I believe.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 1025 Old 01-02-2013, 05:46 PM - Thread Starter
newfinator's Avatar
Thanks for the reply. What thread is that in?
Also, I noticed that I don't see this when viewing the break in slides. Odd.
post #4 of 1025 Old 01-03-2013, 08:50 AM
fcwdev's Avatar
Quoted: 47 Post(s)
I believe you are seeing something similar to the "green blob" issue widely reported on panasonic plasmas. I can tell you from my experience with the VT30 that it does not worsen. It does improve slightly after the first few hundred hours. I was never able to get a clear explanation of the issue and I just accept it as a limitation of plasma tech. I find cranking up the contrast reduces issue, but increases temporary IR.
fcwdev is offline
post #5 of 1025 Old 01-03-2013, 11:36 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
^Maybe Panasonic's implementation of Plasma, but it's not inherent to Plasma itself (I'm saying this as a blob-less Kuro owner).
vinnie97 is offline
post #6 of 1025 Old 01-03-2013, 02:39 PM - Thread Starter
newfinator's Avatar
I also have a Kuro and don't see this on it.
I still can't figure out why I don't see the blobs when viewing the slides. It would, seemingly, make sense that the solid colours would highlight the blobs if it were inherent in the tv. Could it be a by-product of the image processing required for rendering the hockey ice? It's a bit confusing.
post #7 of 1025 Old 01-04-2013, 07:48 AM
fcwdev's Avatar
Quoted: 47 Post(s)
What color are your slides? I can see my blobs on grey slides (with low contrast), but not on red, blue or green ones. Your contrast settings may be different between slides and TV. Also, my blobs are less visible when I first power on the TV.
I have an older 2009 panasonic plasma and it also does not have this problem. So more specifically it is a recent (2011, 2012, 2013?) panasonic plasma problem...
fcwdev is offline
post #8 of 1025 Old 01-04-2013, 09:21 AM - Thread Starter
newfinator's Avatar
I'm using the brake-in slides so they cover various shades of basic colours including white, grey, red, green and blue.
It's interesting though that you said that the effect is less obvious when you first power up as that's when I checked it with the slides. I'll have to do that again once it's warmed up for a while. I wonder if it's related to the panel over heating or something along that line.
Again, in my case the effect is very subtle but, apparently, noticeable in very specific circumstances. If it doesn't worsen I'm not concerned. I just wish my wife hadn't pointed it out to me because I would likely have never picked up on it otherwise.
post #9 of 1025 Old 01-10-2013, 09:31 AM - Thread Starter
newfinator's Avatar
So, am I the only one to report anything like this on a VT50?
post #10 of 1025 Old 03-18-2013, 10:58 PM
Amillennialist's Avatar
Nope, mine too.
(Also noticing a slight buzz when the screen is white.)
Amillennialist is offline
post #11 of 1025 Old 04-30-2013, 09:08 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Watching playoff hockey, I'm noticing it too
Is it IR? Can I run the scrolling bar to get it to go away
Will a professional calibrator be able to lessen these?
I am like the original poster it only seems to be during hockey games is when I notice it
billmich is offline
post #12 of 1025 Old 04-30-2013, 11:30 PM
Quoted: 1392 Post(s)
Liked: 587
Just something to double check.
There are some ventilation holes on the back that will sometimes allow light to enter from the back and cause some weird looking blobs on the image on the front side.
If you're using a back light or have light otherwise behind the display, it may be causing this event.
I had a Pioneer plasma for several years before getting the 65VT50. Since I don't like distortion, on occasion I'd run a program in 4:3 aspect ratio. I guess it was the accumulated hours in doing that where the far left and far right areas where the black bars were located would be more blue than the center area. (not yellow). So now, with the 65VT50, I'm careful to zoom in or use the lit side panel feature on my bluray player.
Something else that I recall. During the first few hundred hours, it seems that the outside edge had something of a lighter shade than the rest of the screen. It eventually went away.
When did you get your display and was it new when you got it?
JimP is offline
post #13 of 1025 Old 05-01-2013, 05:37 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
I got my display in August 2012 from Cleveland plasma, it was brand new
I have it wall mounted and there is no back lighting.....
As I said, it's only during hockey games, but I wonder if there is a way to tweak it away
billmich is offline
post #14 of 1025 Old 05-01-2013, 06:01 AM
Liked: 587
billmich,
Is the center mass of the screen during your hockey games greenish or bluish?
Reason I'm asking is if the center mass is a touch greenish, you could add blue and cancel some of the yellow and make the center mass look better to boot.
If it's bluish, you're screwed. If you add blue, you would cancel the yellow on the outside but make center mass too blue. This would be in your grayscale adjustments.
JimP is offline
post #15 of 1025 Old 05-01-2013, 06:58 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Define "center mass" please
billmich is offline
post #16 of 1025 Old 05-01-2013, 07:20 AM
Liked: 587
I'd consider that the 70% of the picture that excludes the extreme sides, top and bottom.
JimP is offline
post #17 of 1025 Old 05-01-2013, 07:42 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
To me it doesn't have any type of tint at all,
Certainly not green
billmich is offline
post #18 of 1025 Old 05-01-2013, 07:49 AM
chunon's Avatar
Liked: 1772
Certainly not green
If you have blobs and they are noticeable during normal content I would be calling Panasonic, imo just playing around with the white balance controls blindly could just make things worse
65C6 OLED
post #19 of 1025 Old 05-01-2013, 08:18 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Had anyone else had this issue and Panasonic came out and it was fixed?
I only see it during hockey games....
billmich is offline
post #20 of 1025 Old 05-01-2013, 08:21 AM
chunon's Avatar
Liked: 1772
Don't know, sadly the likely result would be they wouldn't do anything, what kind of settings are you using ?
65C6 OLED
post #21 of 1025 Old 05-01-2013, 09:28 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
D-nice in custom slot
billmich is offline
post #22 of 1025 Old 05-01-2013, 09:29 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
I was planning on having Chad B calibrate my set sometime in July or August but this may not be a calibration type of fix
billmich is offline
post #23 of 1025 Old 05-01-2013, 09:29 AM
chunon's Avatar
Liked: 1772
Could be abl rearing its ugly head
65C6 OLED
post #24 of 1025 Old 05-01-2013, 09:30 AM
chunon's Avatar
Liked: 1772
He is a master might be able to reduce it somewhat
65C6 OLED
post #25 of 1025 Old 05-01-2013, 09:47 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Abl?
I actually noticed first back in November
billmich is offline
post #26 of 1025 Old 05-01-2013, 09:51 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
I've heard he is top notch
billmich is offline
post #27 of 1025 Old 05-02-2013, 08:46 AM
djn2004's Avatar
I too have this yellowish green blob on the right side of my 55vt50. It's very noticeable in commercials with solid white backgrounds such as apple and others. I did notice it in a hockey game last night as well. Has anyone determined the cause and how the issue can be resolved?
I bought from best buy last September and my tv is mounted on the wall.
djn2004 is offline
post #28 of 1025 Old 05-03-2013, 03:47 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Is there anything a calibrator can do to minimize this?
billmich is offline
post #29 of 1025 Old 05-12-2013, 01:19 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 155
I believe I'm seeing it as well, hence my search for VT50 yellow blob that sent me to this thread. I'm seeing in during all-white or near white images. Mine is located along the left side of the panel, above the horizontal mid line. Not noticing it right now while I'm watching the PGA championship but I've seen it during commercials and if I run white or grey slides. My set is professionally calibrated and I'm currently running ISF Day.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #30 of 1025 Old 05-12-2013, 10:37 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
For me, I only notice it during hockey games
Which for all practical purposes is like running a white slide
billmich is offline
Panasonic Viera Tc P55vt50 , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv
