Twinkling pixels on LG 42PX5R-ZB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-02-2013, 05:06 AM - Thread Starter
Bst1337's Avatar
Hello
I just got myself a used LG plasma TV, model 42PX5R-ZB. But already the first time I turned it on I noticed something that really bothers me.
When an area of the screen switches to black after displaying light colors (such as the TV menu or something in a movie), pixels in that area flickers most in red and green before they fade to black after one or two seconds.
Also grey colors are very grainy in general (eg in the menu of my cable box) even though in receiving a digital HD signal through hdmi.
Any help is much appreciated. It is much too bright in my room to take pictures of the TV now, but I will try to supply pictures later.
Happy new year :-)
EDIT:
This is first image is when the TV menu is open;
http://imgur.com/y4QDj,XU3sC#0
Now when the menu is closed, it leaves the pixels in random colors which then fade to black over the next couples of seconds:
http://imgur.com/y4QDj,XU3sC#1
I should mention that this has nothing to do with cables as it appears with the TV menu itself and both when using HDMI and scart cables from different sources.
Bst1337 is offline
post #2 of 6 Old 01-02-2013, 10:28 AM
Otto Pylot's Avatar
Quoted: 1356 Post(s)
Liked: 852
I'd check your HDMI cables first. You should be using Certified High Speed HDMI cables from someone like Monoprice, MediaBridge, BlueJeans, etc. If the cables are fine on your used plasma (works ok on another tv for example) then "used" may be your problem. You may have to get a calibration disk like the free AVS HD709 disk and set the basics (brightness, contrast, sharpness, aspect, and color). And plasma tv's don't usually do very good in bright rooms but that's probably not your issue.
Otto Pylot is online now
post #3 of 6 Old 01-02-2013, 10:53 AM
fallengt's Avatar
Probally, dither
fallengt is offline
post #4 of 6 Old 01-02-2013, 06:27 PM - Thread Starter
Bst1337's Avatar
Is there any way to fix this?
Bst1337 is offline
post #5 of 6 Old 01-02-2013, 06:29 PM - Thread Starter
Bst1337's Avatar
I forgot to mention that this has nothing to do with cables as it appears with the TV menu itself and both when using HDMI and scart cables from different sources.
Bst1337 is offline
post #6 of 6 Old 01-02-2013, 06:43 PM
Otto Pylot's Avatar
Liked: 852
Call for service.
