55 panasonic st50 breakin question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-02-2013, 11:56 PM - Thread Starter
blazer7932's Avatar
I just received my set from amazon and was wanting to know how to break it in. This is my first plasma so i want to know if I could just leave the tv on for a few days on a hd channel or with slides on an sd card to break it in or is it recommended to do shorter time periods. I also game and was wanting to know if turning the brightness down would help with image retention?
blazer7932 is offline
post #2 of 3 Old 01-03-2013, 02:46 AM
fallengt's Avatar
- If you want to use D-nice's settings then do exactly what he said.
- If you want to prevent IR then break-in is unnecessary.
fallengt is offline
post #3 of 3 Old 01-03-2013, 06:33 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
The Brightness setting increases/decreases black level, it doesn't actually adjust screen brightness. The Contrast setting adjusts screen brightness but it's effect on IR seems to be hit or miss as some panels seem to be prone to persistent IR while others are very resistant to IR. I typically use Custom mode with Contrast set around 85% on my GT50 and i'm not having any IR problem despite watching lots of news and Speedchannel with bright logos. Others aren't so lucky.
There are several existing/redundant threads about "break in" you should be reading, here's one of the more recent ones:
http://www.avsforum.com/t/1447246/break-in
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
