Official Panasonic TC-PxxST60 Series thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 156Likes
post #6211 of 13883 Old 06-14-2013, 11:01 AM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Originally Posted by ThatDocB View Post
I plan on doing a mix of viewing and slides. I was going to do D-nice's settings but if there are prefered alternatives point me to em! smile.gif
There are other settings available, You should try as many as you like, but there are no preferred settings. wink.gif
htwaits is offline
post #6212 of 13883 Old 06-14-2013, 11:04 AM
Bob_Collins's Avatar
Quoted: 17 Post(s)
Liked: 31
Originally Posted by wattheF View Post
I just picked up a Harmony 600 remote for $40! Only issue I am having is the buttons seem to be double clicking when I control the ST60 with it. Even when I quickly tap the button it moves 2 spots on the menu. I am not having this issue with any other devices.
Is there a fix for this? Maybe a sensitivity setting or soomething?
I've noticed the same thing with the Panasonic remote that came with the set, it seems to overshoot the choice I am trying to make as though the button were pressed twice, so it may not be the remote.
Bob_Collins is offline
post #6213 of 13883 Old 06-14-2013, 11:15 AM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Is your Harmony new or second hand? If it's new you can get help from Harmony for 90 days. Bond's advise is right, and should work with a little tinkering.
If you are still having problems contact Harmony support. Our problem was with the older Harmony 1000 and no matter what adjustments I made it still didn't work right. It took the third level of Harmony support to get a patch that corrected the problem in the 1000. The 1100 has worked fine almost all the time. wink.gif
htwaits is offline
post #6214 of 13883 Old 06-14-2013, 11:17 AM
alfa1's Avatar
Quoted: 24 Post(s)
Liked: 26
New ST60 owner here. So far, love the PQ in 2d, great black level, using Dnice settings with low red in 2 point WB reduced to -3 as this seems to get rid of the red push some have commented on. As to 3d, when I played 3d blu-rays I noticed weird motion, and even putting motion smoother to high didn't totally fix it, and it introduced a noticeable "soap-opera" effect. Changing the refresh rates didn't really help much, and I was strongly considering returning the TV b/c of the poor 3d. Well, just playing with various settings I tried turning off 24p playback in my blu-ray player, and this made a HUGE difference! With motion smoothing set to mid and 96HZ refresh rate, there is almost zero cross-talk, and I cannot see virtually any soap-opera effect. Also, the motion in 3d looks normal again. I am curious if anyone else has experienced weird motion handling in 3d, and if anyone has tried turning off 24p playback and if it improved 3d playback?
alfa1 is offline
post #6215 of 13883 Old 06-14-2013, 11:30 AM
sawfish's Avatar
Quoted: 145 Post(s)
Liked: 145
Try the supplied remote. If your ST60 is like the two 50ST60s I've had, it will double-click maybe 20% of the time. The S60 I had did not exhibit this problem. Also, the ST60 menus are laggy compared to the S60.
As for universal remotes, I use a Sony RM-VL610, and it behaves just like the supplied remote. If your Harmony is doing it on every press, there is probably hope of getting it to the 20% baseline, but if it's only doing it occasionally, I don't think there's anything you can do.
sawfish is offline
post #6216 of 13883 Old 06-14-2013, 11:46 AM
sealteamz6's Avatar
Originally Posted by cadett View Post
What happens when you notice it?
If you notice it during normal viewing its an issue. If you don't its not an issue.
sealteamz6 is offline
post #6217 of 13883 Old 06-14-2013, 11:55 AM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
It does it on every click!
I have never noticed any double click issues with my ST60 and supplied remote.
wattheF is offline
post #6218 of 13883 Old 06-14-2013, 12:01 PM
cadett's Avatar
Quoted: 45 Post(s)
Liked: 102
If you get image retention & it doesn't come off, to me that is an issue, even if it's not visible during moving images, but to each his own.
cadett is offline
post #6219 of 13883 Old 06-14-2013, 12:09 PM
sawfish's Avatar
Quoted: 145 Post(s)
Liked: 145
Good, then it may be fixable.
Have you spent much time in the picture settings like the 10 point white balance? The longer you use the menus, the more likely you are to notice it. I know I'm not the only one to have commented on this over the last few months.
sawfish is offline
post #6220 of 13883 Old 06-14-2013, 12:13 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
Originally Posted by lueastside View Post
It almost looks like someone was handling it from the inside just left a small mark or something, ...
A small worker may have been trapped during the manufacturing process. This could be serious.
Greg Lee
GregLee is offline
post #6221 of 13883 Old 06-14-2013, 12:23 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Hope so or I mite have to return it.
Yeah I have been in the advanced menus many times. If it happens it doesn't bother me.
wattheF is offline
post #6222 of 13883 Old 06-14-2013, 01:22 PM
thuchien's Avatar
For 2D to 3D I use Sony S790 to do the conversion( use Optional button on player to increase the depth.) It looks a lot a better compare to using ST60 to do 2D to 3D.
thuchien is offline
post #6223 of 13883 Old 06-14-2013, 02:30 PM
Bond 007's Avatar
Quoted: 2649 Post(s)
Liked: 2102
lol
Licence to Kill
Bond 007 is offline
post #6224 of 13883 Old 06-14-2013, 02:31 PM
Bond 007's Avatar
Liked: 2102
Thats good. Now I know that fix will work.
Licence to Kill
Bond 007 is offline
post #6225 of 13883 Old 06-14-2013, 02:52 PM
Blind Broccoli's Avatar
Have you been smoking some of that fabled Maui wowee?? Heheh email me some wink.gif
Blind Broccoli is offline
post #6226 of 13883 Old 06-14-2013, 02:59 PM
BruceOrlando's Avatar
good one! Mahalo!
BruceOrlando is offline
post #6227 of 13883 Old 06-14-2013, 03:09 PM
micah bjj's Avatar
please post an update on this thread once you install and get the tv set. I probably will buy this tv, just found out not carried in Costco stores. Just want to make sure it fits your tv and everything is fine before ordering
also, how are you guys going about running the wires when you wall mount? I just noticed that if you want to run them in the wall you need to have an outlet placed hidden behind the tv, Cant have power cords going into the wall, I guess.
One advantage of running them down the wall in the concealed wire holder painted to watch the wall
micah bjj is offline
post #6228 of 13883 Old 06-14-2013, 03:37 PM
ThatDocB's Avatar
Ok. TV delivered looks great! Running slides now.
So what should I look for to make sure I dont have a bad panel?
ThatDocB is offline
post #6229 of 13883 Old 06-14-2013, 03:55 PM
enigma7820's Avatar
I would also like to know more about this please
mdanderson likes this.
enigma7820 is offline
post #6230 of 13883 Old 06-14-2013, 04:16 PM
micah bjj's Avatar
Does $500 to calibrate both 2d and 3d seem too much? Found someone local from the calibrators thread, but not sure if that is the going rate or not
post #6231 of 13883 Old 06-14-2013, 04:32 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
I just answered the same question for another poster in the Sharp Elite thread.
That depends on who is doing it, if they are local or on tour, and how much you are asking them to do. For an anonymous calibrator, almost anything might be too much. wink.gif
Defining what "full" means in your situation would help. How many modes -- 2D, 3D, audio?
Have you checked out other well known calibrators that do tours. It never hurts to do price comparisons.
Where is local? It seems a little high for an anonymous calibrator who isn't charging for the travel costs of a tour. Is he driving a long distance?
Have you checked the link in the signature section of my post to see if there have been any reports about the calibrator's work. Check post number two for flat panel displays. You should look for him in any plasma list.
htwaits is offline
post #6232 of 13883 Old 06-14-2013, 07:13 PM
micah bjj's Avatar
Thanks for the reply!!!
I live in Phoenix, AZ. It is too far for Chad to travel. I had my previous set calibrated years ago (70" sony xbr 720p) I think by Avical when he was on tour through Phoenix. Have emailed him with no response (only been a couple days).
The local person is from the thread in the calibration section. His name is Lee Galagher. I dont know who the big names are in calibration so he could be the best , or could just be 'some guy'
The $500 is for the tv in 2d and 3d. $100 of that is the extra cost for 3d. No audio
post #6233 of 13883 Old 06-14-2013, 07:25 PM
HD2Blu's Avatar
Liked: 27
Originally Posted by joedog000 View Post
Most people??? To each his own.
I think D-Nice's settings are the most accurate for a realistic film experience. I used his setting and did some minor tweaking of my own. Assuming you ran his slides it's a great place to start.
Edit - for dark rooms - i.e. nighttime film viewing. I don't use his setting in the daytime.
HD2Blu, your advise to ThatDoc is fine, but your comments about D-Nice's settings is gratuitous crap. wink.gif
Due to the variation from sample to sample there is no way that "borrowed" settings from anyone are equivalent to having a display professionally calibrated. Second, D-Nice's settings, if you followed his instructions exactly, will, in D-Nice's words, generally get you to a good starting point for further adjustments.
I have nothing against trying D-Nice's settings without exactly following his instructions, or understanding that they are a starting point, unless the person doing it makes comments like you did. There are people who have posted that D-Nice's settings are too dark and too red, but you have no basis to speak for most people. None of us do. smile.gif
Geez guys....I write "one" word wrong and everyone jumps all over it. Change "most" to "many/some/a few". First off I am a HUGE fan of Dnice and what he does here. I have read every single page of the ST50, this ST60 thread, and the Panny settings thread by Dnice. I've watched him lead discussions during the Value Electronics shootout (via YouTube) and if you paid attention to this thread at all I have posted like 200 times in here. I was trying to save the guy alot of reading which he would most likely end up coming to the same conclusion that I did - try Dnice, try Cadett's, try Cnet, try home theater magazine, etc. etc...decide to calibrate it professionally. Just trying to help. Sorry I said "most".
EDIT: now looking over my comments - I'm thinking you all are gonna jump all over the "everyone" word now wink.gif so...correction - 2 people smile.gif
HD2Blu is offline
post #6234 of 13883 Old 06-14-2013, 07:57 PM
edgeh2o's Avatar
Quoted: 46 Post(s)
Liked: 35
Originally Posted by HD2Blu View Post
Geez guys....
What settings did you settle on, or did you get yours calibrated professionally? So far I've only tried CNET and Dnice, and I prefered Dnice's way more, but I only evaluated them both for about an hour worth of Uverse. I paused some commercial though which had a whitish background with these dots, and Dnice's settings brought out the most detail out of it, while CNET and Standard/Home crushed the whites. I still want to try cadetts in the next couple of days.
Office - Onkyo 506, AV123 X-LS Encore Monitors
Living Room - Panasonic 60ST60, Onkyo 707, Ascend Acoustics Sierra-1 LCR
Car - Focal Flax 3-ways; Arc Audio KS 2500.1, 300.4, 300.2; Audison BitOne; Digital Designs 3515
edgeh2o is offline
post #6235 of 13883 Old 06-14-2013, 08:09 PM
mdanderson's Avatar
Quoted: 82 Post(s)
Liked: 91
Maybe I haven't seen sets with better 3D, but from an avid movie fan's perspective I think it works great with the right content. Movies that were shot in 3D look great with the right settings (I prefer medium smoothing and 120 hz). I find the experience more enjoyable than watching 3D in the theatre.
The 2D to 3D conversion looks awful, of course, because 2D to 3D conversion is impossible to do right. As always - content is king. Good stuff in = good stuff out.
Unless 3D is the main reason you are buying a TV, in my humble opinon you should have no problem with this set.
The picture is gorgeous and the price (for 60" and below) is quite frankly a steal.
Sincerely,
A happy 60ST60 owner
Thanks for the input. Yes, the price on the 60" ST60 is a really good deal but I am planning on getting the 65" which is bit more expensive but still a good deal. This will be my first plasma and 3D tv. Thanks again for your thoughts on this/
Paradigm Studio 20v5-fronts
Paradigm Studio CC-490v5-center
Paradigm Studio 10v5- side surrounds,Monitor surround 3v7-bck surr
Oppo UDP-205/LG 65C6 OLED
Marantz SR-5010(as preamp) Emotiva BasX A-700amp
PSA 15S sub
mdanderson is offline
post #6236 of 13883 Old 06-14-2013, 11:45 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Lee Galagher is well known. He's not just some guy, so I think you are in good hands. Avical is the name of David Abrams' company,and he is out of Los Angeles. He's also well known. dave@avical.com
You will find reports from their customers under their AVS user names. I don't know Lee's AVS user name, but David Abrams uses his own name at AVS.
Be sure to have over 300 hours on your set before you have a professional calibration done.
Enjoy.
htwaits is offline
post #6237 of 13883 Old 06-15-2013, 12:34 AM
Chere's Avatar
Quoted: 358 Post(s)
Liked: 187
Is everyone mostly satisfied with their OTA Channels and the de-interlacing capabilities of the ST60? I own the 65ST50 which is last year's model and is very very soft on cable/ OTA channels. I've heard that Panasonic has used a different processor on this year's models and this problem is no longer an issue. If that's the case- I might buy the 50ST60 for my bedroom set.
Any feedback is greatly appreciated especially from owners that have experience with last year's models for comparison purposes.
Chere is offline
post #6238 of 13883 Old 06-15-2013, 02:23 AM
HD2Blu's Avatar
Liked: 27
I eventually had mine professionally calibrated but before that Cadett's looked the best on my set. But during calibration, I found out that Cadett's were pretty much spot on for MY set (since individual panels need to be taken into consideration). The calibrator did before and after charts and both Cadett and I were pretty impressed how close they were.
HD2Blu is offline
post #6239 of 13883 Old 06-15-2013, 07:07 AM
Augiestyle's Avatar
I'm new to the plasma world. I just got my new st60 last night.
After hooking it up it looked great for about 3 hours. After that, I got a horizontal line about 3/4th across the top of the screen.
I did make some changes to the picture settings but reset to factory settings and the line is still present.
Any ideas what is causing it?
2013-06-14_22-45-40_243.jpg 491k .jpg file
Augiestyle is offline
post #6240 of 13883 Old 06-15-2013, 07:16 AM
Blu_One's Avatar
Liked: 62
65" Panasonic ST60 | Onkyo 809 | Oppo 103 | Apple TV4 | Darbee Darblet | 5.2 system - 5x Arx A2 + 2x SVS SB12-NSD
Blu_One is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
