Official Panasonic TC-PxxST60 Series thread - Page 232 - AVS Forum | Home Theater Discussions And Reviews
 135Likes
Old 07-13-2013, 11:56 AM
blueguy2's Avatar
I've got the 55ST60, and am ready to wall mount it. I already have a mount from the TV it replaced, which is a "low profile" mount that only puts the TV 1.25" from the wall. I now see in the owner's manual (page 6 CAUTION) that the TV should have at minimum 2 3/4" space at the rear. I've never owned a plasma before, and I guess I don't remember checking on this when I used the mount for my old LCD - is this a warning/guideline that I need to honor or should I be perfectly fine with 1.25" space in the back?
blueguy2 is offline
Old 07-13-2013, 11:59 AM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Originally Posted by sn1ffb0 View Post
what are your settings?
As I tried and probably failed to explain clearly enough, those screenshots were taken after setting Brightness, Contrast, and Gamma to what they would be when starting a calibration, while leaving everything else at their defaults. The intent was to determine the baseline behavior of Cinema and Custom modes and choose the "better" one as the basis for calibration. All settings I've seen have been for Custom mode, except I think Cnet used Cinema, and as I explained, I think Custom is the better starting point, and it's what I use. I haven't posted my real settings yet. Maybe later. smile.gif Given the varying results people have plugging in settings from different TVs, I started a file explaining what I see with various test patterns and real material, so that I can say, "If this is what you see, then these settings might work for you. If this is not what you see, then these settings definitely don't work for your TV." I want to finish that before posting anything.
Getting back to what the OP was asking about, whether Cinema and Custom look the same with the same settings, they don't. As I mentioned a couple posts ago, Cinema clips whites much earlier than Custom for my Brightness/Contrast settings, and the near reference whites are much lighter. Visually, when I plug my Custom settings into Cinema, Cinema looks a little washed out, and skin tones can have a greenish tint.
sawfish is offline
Old 07-13-2013, 03:39 PM
HD2Blu's Avatar
Liked: 27
Originally Posted by Cleveland Plasma View Post
What movie was it and what aspect ratio ? Your unit is 16:9 aspect ratio. The director of films decide what aspect ratio they would like to use. In the end you can have bars on the top and bottom and everything be ok. You could also have your format wrong as well, the "format" button is on your remote. Remember where you started wink.gif
I'm not sure if this is what the OP is talking about, but I just tried to change the "format" while watching Netflix and for some reason, the button won't work with Netflix (sourced from the TV) so to the OP - just make sure that when you are NOT in Netflix - press the "format" button at the top right of the remote and set it to "Full". Maybe your black bars were due to this. I'm shocked if you have never seen black bars before unless your bluray player or where're you were streaming content from before was not displaying the Netflix content in true form. Like others have posted, if the movie was created in 1.85:1 it will fill the entire screen. If it was filmed in 2.39:1 there will be black bars at the top and bottom of the image. Whatever the reason for your previous viewing experience, if the TV is set to "Full" you will be watching content the way it was intended.
HD2Blu is offline
Old 07-13-2013, 04:03 PM
ryansebiz's Avatar
Originally Posted by areyou4real View Post
Running in 96 Hz with the smoother set to "weak" or running in 60 Hz with the smoother off, will likely result in a similar picture for 24 fps sources on the ST60. People are using the term "judder" to mean multiple things; however, there are only 2 types of judder.
Any chance you know of some popular Blu rays that can noticeably demonstrate both types of judder?
Panasonic tc-p60st60 | Onkyo tx-nr626 | Paradigm CT 110 | HTPC | PS3 Slim | Xbox 360 Slim
ryansebiz is offline
Old 07-13-2013, 06:23 PM
cyberbri's Avatar
Liked: 53
You can change the Netflix aspect/format if you view it through PS3 or another device.
cyberbri is offline
Old 07-13-2013, 08:24 PM
fester99's Avatar
Liked: 25
I know the power plug protrudes from the back of the tv but other than that I don't see anything physically that needs 2 3/4" inch clearing, however it may be for ventilation.
| Panasonic TC-P60ST60 | Pioneer Elite SC-81 | Sony PlayStation 3 | Sony PlayStation 4 | DirecTV HR44 Genie |
fester99 is offline
Old 07-13-2013, 09:39 PM
fahrenheit's Avatar
Quoted: 12 Post(s)
Liked: 30
The same distance is mentioned for all the models but its there for the benefit of the VT/ZT series which feature active cooling.
The ST series doesn't have fans pushing hot air out the back, so it can be mounted much closer to the wall quite safely.
Panasonic probably can't be bothered differentiating as they'd have to make an entirely new line-art illustration for each manual, costing them billions.biggrin.gif
fahrenheit is offline
Old 07-14-2013, 04:11 AM
Jack25's Avatar
Originally Posted by cyberbri View Post
Video Settings
BD/DVD Cinema Conversion: "Automatic"
BD/DVD Upscaler: "Normal"
BD/DVD Video Output Format (HDMI): "Y Pb/Cb Pr/Cr"
BD 1080p 24Hz Output: "Off" --> On this TV, outputting 24Hz seems to cause strange artifacts whether the TV does 48fps / 60fps / 96fps, but you can always try on your own
Display Settings
RGB Full Range (HDMI): "Limited"
Y Pb/Cb Pr/Cr Super-White (HDMI): "On"
Jack25 is offline
Old 07-14-2013, 11:30 AM
aurora85's Avatar
Random request but can anyone post some daylight shots with the st60 on at home? Trying to get a feel for how it looks outside of a showroom. I realize pics wont show it full justice. Thanks!
aurora85 is offline
Old 07-14-2013, 12:42 PM
tripleM's Avatar
Question about sound & Smart TV Hub:
Current setup:
ST60 connected to AVR via HDMI (in from out).
TiVo connected to ST60 via HDMI (out to in)
TiVo to AVR via optical (out to in) - so I can have sound for the TiVo via Receiver or TV independently.
Question:
How do I connect the AVR to the ST60 so I can watch streaming content from Amazon, etc. with Dolby sound coming out of my AVR?
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
Old 07-14-2013, 02:45 PM
wiggindude's Avatar
Here are some afternoon shots of my 60st60.
wiggindude is offline
Old 07-14-2013, 04:24 PM
tripleM's Avatar
Hubba!
Are you single? Cause that's the only way I can think you would get away with that nice setup.
All that out in the open stuff got nixed when I got married. LOL!
tripleM is offline
Old 07-14-2013, 10:55 PM
snidely's Avatar
Quoted: 135 Post(s)
Liked: 32
I've only been around here less than a month, an owner for less than 3 weeks. Have gone back and read hundreds of thread while watching a couple baseball games. (A's beat Boston again!!)
Have several questions - will start with two.
1. Seems like half the posts deal w. calibrations. Exactly what do these guys do and how do they do it? Do they use a "machine" that reads colors? What is the "goal"? I have seen charts giving results (charts are meaningless to me.) How are they generated?
2. I see the term SOE or "Soap Opera Effect". What is that?
snidely is offline
Old 07-15-2013, 12:41 AM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
You can read about what calibration is in this forum.
Display Calibration
SOE makes all faces look like they have heavy "pancake" makeup on. It reminds people of the day time Soap Opera programs were everyone seems to be wearing heavy make up.
The goal of calibration is to adjust a display as close as possible to the standards used in the movie industry. Some benefits of professional calibration would be detailed and natural looking skin tones, being able to see the intended detail in dark scenes, and green grass and skies that look natural.
htwaits is offline
Old 07-15-2013, 12:58 AM
cyberbri's Avatar
Liked: 53
I don't think I've heard the soap opera effect ever explained like that. It's basically the "motion smoother" that adds additional video frames and making everything look like soap opera / home video.
http://reviews.cnet.com/8301-33199_7-57569102-221/what-is-the-soap-opera-effect/
If you haven't change the TV settings yet, snidely, be sure to change over to Cinema or Custom (instead of Vivid/Dynamic or Standard). That will get you most of the way there to what the picture should look like.
cyberbri is offline
Old 07-15-2013, 02:24 AM
samijubal's Avatar
Quoted: 37 Post(s)
Liked: 91
Current setup:
Question:
If the receiver has audio return channel, connect the receiver to HDMI 2 on the TV and turn on ARC and HDMI control on the receiver and turn on Viera Link in the TV setup menus. If the receiver doesn't have ARC, use the optical out of the TV to the receiver.
samijubal is offline
Old 07-15-2013, 02:50 AM
Bond 007's Avatar
Quoted: 2378 Post(s)
Liked: 1914
lol Not sure where that came from but you may be thinking of the "oil painting effect" associated with a "soft" picture with little detail that is usually caused by a poor source. Many people complained about this effect with 720p sources on the 50 series.
Licence to Kill
Bond 007 is offline
Old 07-15-2013, 07:21 AM
RodriguezDan's Avatar
Hey guys,
Been searching and this seems to be a rare issue. Was hoping you guys could help me troubleshoot.
I am using ARC over HDMI to send two sources through the TV to my Receiver. I previously had ARC working with Dolby Digital 5.1 without issue. Suddenly, the Receiver is only showing LPCM (PCM) at 48 from my cable box and Xbox (the two sources plugged into the TV).
I checked the receiver - plugging directly in will result in Dolby. The settings on the sources are to output Dolby. The TV digital audio out setting is on "auto" and not "PCM."
What could have happened?
Thanks in advance!
RodriguezDan is offline
Old 07-15-2013, 08:21 AM
wiggindude's Avatar
Hubba!
haha..I'm married but my wife is cool about it, she doesn't really care.
Old 07-15-2013, 08:33 AM
tripleM's Avatar
Appreciate the info. Looks like the latter for my receiver as I don't have ARC unfortunately on the AVR.
tripleM is offline
Old 07-15-2013, 02:40 PM
samijubal's Avatar
Quoted: 37 Post(s)
Liked: 91
Originally Posted by RodriguezDan View Post
Hey guys,
Thanks in advance!
The TV will only send 5.1 from internal sources, tuner, streaming, and USB, all other sources will be 2 channel PCM. If you want 5.1 from other sources they will have to be connected to the receiver, not the TV.
Old 07-15-2013, 02:45 PM
Jack25's Avatar
On my PS3 menu, I now have an Viera ST60 Series icon. But when I click on it, it says access to the media server is not allowed? It is possible that PS3 system has not been registered?
Jack25 is offline
Old 07-15-2013, 02:48 PM
Are you sure? I thought that was only for Optical. I thought HDMI ARC would handle 5.1. And I'm 99% sure it was working in the past.
Old 07-15-2013, 03:17 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Is it possible you mistook Dolby PLii for Dolby passthrough?
sawfish is offline
Old 07-15-2013, 03:20 PM
I'm pretty sure I remember it scrolling 3/2.1 (how my sony shows 5.1). And the reason I noticed it was on PCM is because it sounded different. Can anyone else confirm they are using DD5.1 via HDMI ARC?
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
Well, I certainly didn't explain what causes SOE. Maybe the lack of skin texture and a false smoothness would have been better. Those characteristics used to be attributed to day time soaps back in the CRT days. My experience watching soaps is very limited and over a decade into the past. Even then it would have been from channel hopping. eek.gif
P.S. I think i know where I got that description. The restored version of Singn' In The Rain has no skin tone or texture detail. In that case, at least part of the problem is makeup.
htwaits is offline
Old 07-15-2013, 04:06 PM
cyberbri's Avatar
Liked: 53
There shouldn't be content on the TV you can access from the PS3, unless maybe you have a USB stick or something inserted into the TV. Even then, I'm not sure. It's just showing connected devices. Ie., my TV and iPad are on the same network, and the Netflix app on the iPad recognizes the TV is connected, and I can view the content queued up on the iPad on the TV instead, and use the tablet to browse and play content.
cyberbri is offline
Old 07-15-2013, 04:19 PM
samijubal's Avatar
Quoted: 37 Post(s)
Liked: 91
It's not just optical, it's ARC also. If you were getting 5.1 it was from an internal source or USB. This has been discussed in the thread repeatedly.
Old 07-16-2013, 02:11 PM
Jack25's Avatar
I see. Makes sense.
Jack25 is offline
Old 07-16-2013, 04:44 PM
edgeh2o's Avatar
Quoted: 46 Post(s)
Liked: 35
Watched some Samsara last night; the ST60 just keeps impressing me. I'm noticing the rainbow effect less and less lately, so that's a plus. I finally got some pretty stubborn IR too: left the bluray menu of the Campaign up for about 15-20 minutes while conversing, and the red Campaign logo stuck around for about 20-30 minutes while playing the movie before it faded away. No biggie. That was the first IR I've seen on the ST60. For some reason leaving a Youtube webpage up for the same amount of time leaves no IR, go figure.
Planning to use my free calibration from BB soon, figure I have nothing to lose. Just to confirm, if they calibrate, say, the Custom preset, and they do a crappy job, I can just revert the Custom settings back to default and it will be like it never happened, right?
Office - Onkyo 506, AV123 X-LS Encore Monitors
Living Room - Panasonic 60ST60, Onkyo 707, Ascend Acoustics Sierra-1 LCR
Car - Focal Flax 3-ways; Arc Audio KS 2500.1, 300.4, 300.2; Audison BitOne; Digital Designs 3515
edgeh2o is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
