Official Panasonic TC-PxxST60 Series thread - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 156Likes
post #7561 of 13871 Old 08-13-2013, 02:32 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 145
Originally Posted by cyberbri View Post
There should be a standard headphone jack on the TV, by the card slot.
Looks like only the Europeans rate a headphone jack.
sawfish is offline
post #7562 of 13871 Old 08-13-2013, 02:32 PM
samijubal's Avatar
Quoted: 41 Post(s)
Liked: 95
Originally Posted by ricardoht View Post
Is there a way to turn off the speakers? I'm planning on using a Onkyo AVR.
I think if you go to the "Viera Link" app and change it to "home theater" it turns off the TV speakers. You need ARC to use the app.
michaelmadiganj likes this.
samijubal is offline
post #7563 of 13871 Old 08-13-2013, 02:44 PM
Snafu68's Avatar
Quoted: 17 Post(s)
that's right, and it has own volume settings in menu.
just turn down speakers volume.
Snafu68 is online now
post #7564 of 13871 Old 08-13-2013, 02:46 PM
snidely's Avatar
Quoted: 168 Post(s)
Liked: 37
My speakers are completely off when turned down to "zero"". We play thru a JBL soundbar in a smallish condo LR.
snidely is offline
post #7565 of 13871 Old 08-13-2013, 03:25 PM
samijubal's Avatar
Quoted: 41 Post(s)
Liked: 95
Does anyone know why I can't get uncompressed audio when watching a 3D movie on a PS3? If I switch to 2D I get uncompressed audio. Is it just a setting or do 3D movies not have uncompressed audio?
post #7566 of 13871 Old 08-13-2013, 03:28 PM
cyberbri's Avatar
Liked: 54
Is the PS3 hooked to your receiver directly over HDMI? Watching 3D, maybe there's a different default audio setting, so you have to manually change it? Or maybe it's limited bandwidth over the HDMI cable, because of the 3D? I don't think the last one should be an issue with the HDMI 1.4 rated cables/equipment, though.
Maybe that's a question for the PS3 thread probably, unless someone here knows.
cyberbri is offline
post #7567 of 13871 Old 08-13-2013, 03:35 PM
samijubal's Avatar
Quoted: 41 Post(s)
Liked: 95
Everything is connected HDMI with 1.4 cables. I changed audio settings to get TrueHD but it only works in 2D.
post #7568 of 13871 Old 08-13-2013, 06:34 PM
adrian s's Avatar
Quoted: 38 Post(s)
Liked: 65
I may be off on this, but if I remember correctly the ps3 can't do 3D and lossless at the same time
consider the source
adrian s is offline
post #7569 of 13871 Old 08-13-2013, 06:43 PM
cyberbri's Avatar
Liked: 54
cyberbri is offline
post #7570 of 13871 Old 08-13-2013, 06:48 PM
malolo's Avatar
Received my 50st60 a couple days ago (about 60 hours into slides). Cant comment much on PQ yet, but I must say I was a bit anxious about all the reports of buzzing in these PDPs. So far, no matter how hard I try, I cannot hear any buzz what-so-ever. Am I just fortunate, or did I attend a few too many rock concerts? This is my second Panny plasma and the first was dead silent as well. I do utilize a lower-end Panamax unit for surge protection which also purports to "condition" AC supply, so maybe that helps as well.
malolo is offline
post #7571 of 13871 Old 08-13-2013, 07:20 PM
Latinoheat's Avatar
Quoted: 1113 Post(s)
Liked: 887
Too many rock concerts, just kidding, all plasmas buzz to some extent but some can be louder than others. My GT50 is pretty much silent as well. Consider yourself one of the lucky ones. biggrin.gif
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #7572 of 13871 Old 08-13-2013, 07:32 PM
Coyote Waits
htwaits's Avatar
Quoted: 947 Post(s)
Liked: 2099
Can it do 3D and PCM, if it decodes and sends PCM instead of lossless?
LPCM is lossless, if it's the result of decompressing a lossless bit stream.
htwaits is offline
post #7573 of 13871 Old 08-13-2013, 09:17 PM
samijubal's Avatar
Quoted: 41 Post(s)
Liked: 95
From what I found on the internet the PS3 can't do 3D and Dolby TrueHD at the same time. I guess it's time to buy a 3D Blu-ray player.
post #7574 of 13871 Old 08-13-2013, 09:34 PM
tripleM's Avatar
Quoted: 12 Post(s)
How do I find out what the Panel Setting is when the Pro Setting option is grayed out under the Standard?
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #7575 of 13871 Old 08-14-2013, 01:34 AM
samijubal's Avatar
Quoted: 41 Post(s)
Liked: 95
Pro settings are only available in cinema and custom modes.
post #7576 of 13871 Old 08-14-2013, 03:02 AM
edgeh2o's Avatar
Quoted: 46 Post(s)
Liked: 35
I haven't been on AVS in a while, but I'm still loving my 60ST60. Watched Cloud Atlas 2 nights ago, Looper last night, 2 great movies and PQ was top notch. That said, up until recently, I never had any IR, and it's not a big deal, but I'm hoping in time it will go back to being the zero IR display that it used to be. Not exactly sure how many hours I have on it, but I would guess somewhere around 400. I mean, I just did the software update about 15 minutes ago, and I can still see the 'updating software' text on a light background. Besides this weird IR phase, I love the display, much more than the F8500 I had before and all the LED/LCDs I had before that. It's simply an amazing display, and I have no inkling, not even an inkling of an inkling, to upgrade anytime soon or far.
Office - Onkyo 506, AV123 X-LS Encore Monitors
Living Room - Panasonic 60ST60, Onkyo 707, Ascend Acoustics Sierra-1 LCR
Car - Focal Flax 3-ways; Arc Audio KS 2500.1, 300.4, 300.2; Audison BitOne; Digital Designs 3515
edgeh2o is offline
post #7577 of 13871 Old 08-14-2013, 06:08 AM
paulpogo's Avatar
Originally Posted by Bond 007 View Post
Whats your source? Many cable boxes have audio settings. Look for an audio "Range" setting. Mine has Normal, Narrow and Wide that will affect the volume on the tv.
Brilliant! I'll check. Thanks for posting.
paulpogo is offline
post #7578 of 13871 Old 08-14-2013, 06:17 AM
paulpogo's Avatar
Found the setting, changed it to "wide" and problem solved. Thanks so much!
paulpogo is offline
post #7579 of 13871 Old 08-14-2013, 06:18 AM
ozzzie3's Avatar
Reflections???
Trying to get an idea how relfective this set is. Hard to tell in Best Buy. My living room is not real bright but has a kitchen behind with overhead recessed lighting.
Coming from a LCD with matte screen. Tried a new Sony 550 with semi matte that is still very relfective. Sony going back due to clouding. Would the ST be similar to the Sony?
I tried a Panasonic S1 a few years ago and the glare was too much. Looking at the 65" ST.
Thanks in advance.
Ozzzie3
ozzzie3 is offline
post #7580 of 13871 Old 08-14-2013, 06:26 AM
Kermit26.2's Avatar
In the Pro Settings submenu: Panel Brightness, C-net suggests Low. Hometheater.com suggests Mid for 2D, and High for 3D.
Is there a consensus in this forum regarding the Panel Brightness setting?
Kermit26.2 is offline
post #7581 of 13871 Old 08-14-2013, 07:26 AM
Emma1420's Avatar
Originally Posted by ozzzie3 View Post
Reflections???
Thanks in advance.
Ozzzie3
I think the screen is quite reflective. I purchased the Visio M series before my st60 and the screen reflectiveness is about the same. Even with the filter its a glossy screen, but its so glossy you feel like you are looking into a mirror (which is how i felt with the s60). My tv is in the living room with 3 windows including a large picture window and they don't cause me any issues.
Emma1420 is offline
post #7582 of 13871 Old 08-14-2013, 07:46 AM
Bond 007's Avatar
Quoted: 2594 Post(s)
Liked: 2056
YW glad it worked.
Licence to Kill
Bond 007 is offline
post #7583 of 13871 Old 08-14-2013, 08:03 AM
chunon's Avatar
Quoted: 2444 Post(s)
Liked: 2195
Mid for 2d and High for 3d is usually the correct panel brightness
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #7584 of 13871 Old 08-14-2013, 08:37 AM
Urga's Avatar
Quoted: 28 Post(s)
Liked: 367
Mid is too bright on 50 ST60 Eu ...
Pioneer LX 5090H + Démo G5  C+ Csat HD + DD et la TNT + Pioneer LX58 + Sony BD-S790 ... Pana 50 ST60 + PS3 BD + Pioneer BD320 ... CRT Philips 32 PW 9520 P+2 DNM + TNT Thomson DTI 652 + Pioneer DV 380 ... BR 137 .
Urga is offline
post #7585 of 13871 Old 08-14-2013, 09:00 AM
mrranger's Avatar
Anyone having success playing MKV files via the DLNA server?
mrranger is offline
post #7586 of 13871 Old 08-14-2013, 09:04 AM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
I haven't been around much lately either (too busy enjoying my ST60!). I remember when you were contumplating the F8500 and other options. Glad to see you are happy with the ST60. As am I.
I don't want to scare you and I'm sure it varies by panel, but as my panel ages the IR has gotten progressivly worse. At first it was fairly ressistant to IR, now with about 6 mo. under its belt it gets IR VERY easily. Literally within seconds of having a still font on screen can cause it. I am not at all worried about it though because it ALWAYS goes away very quickly. Usually within seconds or at least minutes any traces of IR are totally gone.
So it has short term IR and no issues with long term or persistent IR.
This is just my experience and I'm not sure how it compares to others. I naturally vary my viewing content. It does not at all prevent me from recommending this TV to anyone (with exception to maybe hardcore gamers or those who keep their TV on ESPN all day). Loving it!
edgeh2o likes this.
wattheF is offline
post #7587 of 13871 Old 08-14-2013, 09:18 AM
Bklynblaze's Avatar
Quoted: 102 Post(s)
Liked: 36
So I've narrowed my purchase decision between the 60" ST60 and the 60" Samsung 8500. I am aware of the roughly $1,000 price difference between the two and that certainly is a factor. My only concern with the ST60 is that the picture may be to dim and coming from an LCD it may take some getting used to. A lot of reviews point out how the 8500 is comparable to LCD's in terms of brightness. I remember one reviewer on amazon pointing out that the only thing that takes getting used to on the ST60 is that sports seem a little dim. I guess he's comparing to an LCD.
So my question would be to owners of the ST60 is...do you ever feel, when viewing the ST60 that the picture is slightly dim and can use some "punch" (particularly when viewing sports) or do you feel it's just right and accurate? Thanks a lot!
Bklynblaze is offline
post #7588 of 13871 Old 08-14-2013, 09:32 AM
Syradil's Avatar
Once you get the ST60 and adjust the settings I think you'll find its perfectly fine in most conditions and that many LCD's are painfully bright in comparison.
goldenbear94 likes this.
Syradil is offline
post #7589 of 13871 Old 08-14-2013, 09:43 AM
Bklynblaze's Avatar
Quoted: 102 Post(s)
Liked: 36
Thanks for the quick response. What settings would you (or anyone) recommend OOB for optimal picture and brightness without a professional calibration?
post #7590 of 13871 Old 08-14-2013, 10:02 AM
tedcousens's Avatar
Quoted: 28 Post(s)
Painfully bright? Of course you could tune the LED down, which might also improve blacks. I had my heart set on a 65ST60 but finances are causing me to back off. What comparable LED65 would others consider?
Sent from my SPH-L710 using Tapatalk 2
I've seen things you people wouldn't believe...
Roi Batty
tedcousens is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
