Official Panasonic TC-PxxST60 Series thread - Page 295 - AVS Forum
post #8821 of 12708 Old 10-28-2013, 05:00 PM
Bond 007's Avatar
Quoted: 107 Post(s)
Liked: 823
Originally Posted by SheepNutz View Post
Thanks everyone for the replies regarding the screen height. I believe I may have found an entertainment cabinet that has room for my center channel speaker in it, so it should be a non-issue.
If you have to place the center down low I suggest you pull it forward as far as you can and prop the front up so that its pointing at your head. You dont want it pointing at your feet. This will also help keep sound reflections from the shelf to a minimum.
goldenbear94 and comfynumb like this.
No, Mr. Bond. I expect you to die!
Bond 007 is offline
post #8822 of 12708 Old 10-28-2013, 05:45 PM
grizimes's Avatar
Liked: 26
I use the small rubber doorstops to prop my RC-LCR up a bit. Was surprised enough to find a small improvement for the investment.
grizimes is offline
post #8823 of 12708 Old 10-28-2013, 05:51 PM
iserum's Avatar
are 3d glasses compatible with St30 plasmas? i have 60ST60 on order from BB.
iserum is offline
post #8824 of 12708 Old 10-28-2013, 06:23 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 53 Post(s)
Liked: 444
Originally Posted by beezar View Post
Yes, you can turn HOTEL MODE on and off, and can select the things it puts a limit on. I thought I was stuck buying a universal remote that wouldn't have a "Neflix" button (which I use frequently), but the HOTEL MODE fixed everything. I wish they would just post the thing in the manual...
The Hotel Mode is intentionally hidden to prevent hotel guests from overriding the various restrictions that the hotel had the installer set up (such as limiting the volume to only go up half way so as not to disturb guests in the next room, or locking out all the inputs, disabling the picture settings menus, etc).
There is some danger when going into the Hotel Mode as exploring and activating some of the obscure functions immediately locks out the remote so suddenly you're unable to control the TV or exit the menu. After that happens, you have to have an authorized installer or repair man restore access. It's happened to a few people here a long time ago.
Randy
TC-P55ST60, TC-P50GT50, TC-P46G10, TH-42PZ700U, TH-42PX50U, HP LC2600N, TiVo Series3, TWC Cisco 8742HDC DVR, Onkyo TX-SR605, URC R40 Remote.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8825 of 12708 Old 10-28-2013, 07:00 PM
ryryonline's Avatar
There are two P50ST60's on sale that are open box near me. One has everything for $859 and one is missing the manuals and remote but is only $810. Also, I have been using a 42" Panasonic 720p that I bought in 2004 and it has a one HDMI port that's broken. After measuring my living room, 50" is as large as I can go.
Anyway, would it be worth saving the $50 and not get the remote?
Also, currently, I have an XBMC box and ROKU box hooked up to my current plasma. Do I need to upgrade now or should I wait for this thing to die?
Thanks for any feedback.
Best
ryryonline is offline
post #8826 of 12708 Old 10-28-2013, 07:21 PM
Jack the cat's Avatar
Originally Posted by samijubal View Post
It is not multi voltage or multi system. The only way to get multi voltage or multi system electronics in the U.S. is to have them imported. I don't even see the ST60 anywhere that imports TVs to the U.S., they are all older models.
Having lived in Germany for several years, I used a US model TV for all those years. (As well as all my US audio equipment). Just need to buy a 110 to 220v transformer. The ST65 requires only 463 watts so you need only a small transformer. The ST60 offers a selection for PAL, which is the European standard. The only issue, is you would need to pay import duty, depending on where you live. While there, I received a replacement HP printer at no charge and I still was required to pay German duty on the suggested retail price.
Good luck.
Jack the cat is offline
post #8827 of 12708 Old 10-28-2013, 08:21 PM
shadowinq's Avatar
I just bought a p60st60 and love it. My first plasma. I have probably about 150 hours on it and just started to notice ghosting that goes across the screen in the PLEX menu and in some video game menus. A quick search shows that it's horizontal line bleed. I'm not sure if I just didn't notice it before or if it just started happening after I re-did the wiring in my cabinet. I have not noticed it in normal programming, except on football scores that don't go all the way across the screen.
Is it normal for the ST60 to have this line bleed? Could something with my wiring have caused it to get worse?
shadowinq is offline
post #8828 of 12708 Old 10-28-2013, 08:23 PM
samijubal's Avatar
Liked: 73
Originally Posted by jason22 View Post
Knowing this tv`s high input lag I can refrain from playing on this set. But what i cant live with is out of sync audio i dont think i would able to live with tv channels trailing the audio.
One of my previous tv had 120ms lag and it had noticeable out of sync issue.
Does anyone notice out of sync audio with this one ?
If you're talking about the internal speakers, the TV delays the audio to the internal speakers to compensate for the video lag.
samijubal is online now
post #8829 of 12708 Old 10-28-2013, 08:24 PM
Bond 007's Avatar
Quoted: 107 Post(s)
Liked: 823
Shadowinq
Normal. Some sources will display it worse than others.
Bond 007 is offline
post #8830 of 12708 Old 10-28-2013, 08:24 PM
PlasmaPZ80U's Avatar
Liked: 186
has anyone noticed color banding on the ST60 for smooth gradients (including a continuous grayscale ramp test pattern)? it's there on the S60 and I was wondering if the added shades of gradation on the ST60 reduces or eliminates it
PlasmaPZ80U is online now
post #8831 of 12708 Old 10-28-2013, 08:32 PM
samijubal's Avatar
Liked: 73
Where is this PAL setting? I have never seen any PAL setting on a U.S. Panny plasma.
post #8832 of 12708 Old 10-28-2013, 08:39 PM
RicFlair's Avatar
It's amazing that Panasonic can release a TV so beautiful in 2013 & completely shun the concerns of gamers - the lag on this TV is brutal from everywhere I read.
Has there been a fix?
Panny 55St60
Panny 55St50(gaming)
Sony 55 NX720
Samsung 42 Hpt(Plasma)
Panny 32Viera LCD (TX)
Klipsch surround
Denon HDMI Receiver
Bose Solo
Playstation4(BF4,Madden,Ghosts,NFS,KZ,FIFA)
XBox360
Ipad 1 & 2
Iphone 5S
RicFlair is offline
post #8833 of 12708 Old 10-28-2013, 09:30 PM
AKA
AKA's Avatar
Liked: 31
Shunning gamer's concerns like you shun the search function? tongue.gifwink.gif There is a whole thread on the topic, after it was beaten to death here.
In all seriousness though, it's not an issue for most people. If it is for you, you'll have to give up some PQ in favor of an S64 or S60.
shenaniganz08 likes this.
AKA is offline
post #8834 of 12708 Old 10-29-2013, 01:00 AM
samijubal's Avatar
Liked: 73
The lag has been way overblown by a bunch of people who don't even own the TV repeating what others who don't own the TV have repeated from a few who do actually own the TV. Many of us on here play games without even noticing the lag.
NeilK, fester99 and shenaniganz08 like this.
post #8835 of 12708 Old 10-29-2013, 05:07 AM
chunon's Avatar
Quoted: 76 Post(s)
Liked: 455
The St30 glasses are IR, ST60 ones are RF(BT) so they are not cross compatible.
65VT60
55ST60
Sony BDV-F7 3dbluray/soundbar
Calman Enthusiast
Dish Network with Hopper/Super Joey
chunon is online now
post #8836 of 12708 Old 10-29-2013, 06:06 AM
JerryElbow's Avatar
The only time I notice banding is when booting up my Xbox 360, which has a grey gradient background. Once the games are playing, I don't really see it there anymore. I also don't see it from my DirecTV satellite receiver/DVR or from my Oppo BDP80 BluRay player or from my NetGear NeoTV 550 media player. Not having an S60 to compare it to, I don't know if the banding is the same or improved.
JerryElbow is offline
post #8837 of 12708 Old 10-29-2013, 07:22 AM
shadowinq's Avatar
Dude... if you haven't been playing competitively on a CRT you won't notice the lag. I hit the button, and things happen. It's no worse than my old LCD by my perception. Wii U and PS3 seem just as responsive as they were before. Just turn all the extra processing crap off (you probably should anyway).
post #8838 of 12708 Old 10-29-2013, 07:49 AM
Cleveland Plasma's Avatar
Quoted: 154 Post(s)
Liked: 419
Originally Posted by Bkultra View Post
The ST does not use fans and the number of affected ZT/VT is rather low.
Very low, there are still complaints, in the real world, far and in between.
Cleveland Plasma is offline
post #8839 of 12708 Old 10-29-2013, 08:11 AM
comfynumb's Avatar
Liked: 407
I just received my 60ST60 from the freight company. Obviously Paul's TV knows who to ship with because there wasn't even a mark on the box. What a beautiful panel!
comfynumb is offline
post #8840 of 12708 Old 10-29-2013, 08:20 AM
Liked: 186
the Xbox 360 is a good example of where the banding is at it's worst... however, like you said I don't see it all the time with all sources... mainly just when there are smooth gradients of a single color
for example, I'm currently playing Splinter Cell Blacklist on the PS3 and I don't see banding most of the time while playing
post #8841 of 12708 Old 10-29-2013, 08:56 AM
glantern30's Avatar
What is everyone useing for 3d settings? and there's an option to increase the effect +or- 3, but I don't know which is better? any suggestions would be great!
Oh and what is a good CHEAP pair of 3d glasses to buy for this tv?
glantern30 is offline
post #8842 of 12708 Old 10-29-2013, 10:32 AM
samijubal's Avatar
Liked: 73
The Samsung 5100s at $19. You can also get a 5 pack of batteries on Amazon for $1.88 shipped.
http://www.amazon.com/Samsung-SSG-5100GB-3D-Active-Glasses/dp/B00BIP816Q/ref=sr_1_2?ie=UTF8&qid=1383067711&sr=8-2&keywords=samsung+3d+glasses
http://www.amazon.com/Maxell-Lithium-Batteries-Size-CR2025/dp/B002E0DSBW/ref=sr_1_5?ie=UTF8&qid=1383067711&sr=8-5&keywords=samsung+3d+glasses
post #8843 of 12708 Old 10-29-2013, 12:16 PM
greenythebeast's Avatar
Does anyone know if the P50ST60 outputs 5.1 sound through its optical out port if the cable box is connected via component cable?
greenythebeast is offline
post #8844 of 12708 Old 10-29-2013, 12:19 PM
chunon's Avatar
Quoted: 76 Post(s)
Liked: 455
Optical out only delivers 5.1 for OTA and internal apps, anything external to the tv will be output as 2 channel.
65VT60
55ST60
Calman Enthusiast
post #8845 of 12708 Old 10-29-2013, 12:59 PM
Alright, thanks. Another question: Does anyone know how high the bottom lip of the P50ST60 is? I'm considering getting a soundbar (VIZIO S4251w) that is 3.74" high and 42.32" wide. Will that block the remote sensor or any of the picture?
post #8846 of 12708 Old 10-29-2013, 01:06 PM
shenaniganz08's Avatar
Liked: 53
OK calm down drama queen
Over and over you keep repeating the same thing
The response time for these TVs are easy to find and it's been repeated NUMEROUS times that the lag times on the ST60 is not that bad unless you're some hardcore neckbeard gamer.
You had the choice to get the S60/S64/VT60/ZT60 if you wanted better response times, so stop complain already because the only person you have to blame is yourself!
shenaniganz08 is offline
post #8847 of 12708 Old 10-29-2013, 01:19 PM
RobMueller10's Avatar
It is about 2 1/2 inches from the bottom lip to the tv stand. That soundbar will block the sensor, and maybe even a little bit of the picture.
RobMueller10 is offline
post #8848 of 12708 Old 10-29-2013, 01:21 PM
Here are the measurements from panasonic.com
Without stand 55.0" x 32.4" x 2.0"
with stand. 55.0" x 34.6" x 13.2"
post #8849 of 12708 Old 10-29-2013, 01:28 PM
Grrrr. Do you think it's safe to place the pedestal on a very sturdy large book/box in order to raise it a bit?
post #8850 of 12708 Old 10-29-2013, 02:19 PM
NCCaniac's Avatar
A box...probably not. A book, perhaps if it is larger than the base....but if you need to raise it just a bit, I would recommend instead getting a nice piece of wood at the local hardware store that is wider than the base (front to back) and then cut it to about half the width of the screen itself so you have a nice wide sturdy base. Then either paint it or stain it to match the stand you are putting it on.
NCCaniac is online now
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
