Official Panasonic TC-PxxST60 Series thread - Page 296 - AVS Forum | Home Theater Discussions And Reviews
 152Likes
Old 10-29-2013, 03:06 PM
glantern30's Avatar
Quoted: 20 Post(s)
Thank you!!!! anybody else know about settings? I watched life of pi yesterday and it was great some good scenes that popped out the thing is the glasses make everything so dim. Any assistance would be great!
glantern30 is offline
Old 10-29-2013, 04:02 PM
Alex F.'s Avatar
Quoted: 467 Post(s)
Liked: 239
RE: Fan noise
Thank you for confirming the 65ST60 does not utilize cooling fans. Much appreciated!
Theater room: Panasonic TC-P65S60 plasma television; Yamaha Aventage RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer; Sony BDP-S6500 Blu-ray player.
Music room: McIntosh MA6500 integrated amplifier, Audible Illusions (tube) preamp, Quad 99 preamp, Quad 909 amplifier, Acoustic Research AR9 and Dahlquist Prelude loudspeakers, Onkyo DX-7555 and Melos (tube) CD players, Phase Linear 8000II turntable.
Alex F. is offline
Old 10-29-2013, 04:31 PM
Jack the cat's Avatar
Originally Posted by samijubal View Post
Where is this PAL setting? I have never seen any PAL setting on a U.S. Panny plasma.
I am so sorry. It was another component in my AV system I saw the PAL setting. Very sorry.
Jack the cat is offline
Old 10-29-2013, 04:35 PM
NeilK's Avatar
Originally Posted by The Watcher 911 View Post
I turned my automatic updating off. I now have to find a usb key that is under 2 gigs. I'll try and install the update that way seeing customer support and Panasonic keeps saying to reset the entire tv. Problem is that doesn't reset the firmware version.
GRRRR
No, you do not have to find a usb key under 2 gb, unless your computer limits you to that. I used an 8 GB USB stick to upgrade my firmware on my P60ST60 the first time. The TV had no problem reading the 8 GB stick nor upgrading the firmware from it.
Neil from Southern California
NeilK is offline
Old 10-29-2013, 04:41 PM
I set the picture setting to "Vivid" for 3D viewing.
Old 10-29-2013, 05:39 PM
Bond 007's Avatar
Quoted: 2567 Post(s)
Liked: 2030
Originally Posted by NCCaniac View Post
A box...probably not. A book, perhaps if it is larger than the base....but if you need to raise it just a bit, I would recommend instead getting a nice piece of wood at the local hardware store that is wider than the base (front to back) and then cut it to about half the width of the screen itself so you have a nice wide sturdy base. Then either paint it or stain it to match the stand you are putting it on.
+1 Or he could buy a tv riser for about $50.
Licence to Kill
Bond 007 is offline
Old 10-29-2013, 05:50 PM
cfi on the fly's Avatar
Originally Posted by jason22 View Post
Knowing this tv`s high input lag I can refrain from playing on this set. But what i cant live with is out of sync audio i dont think i would able to live with tv channels trailing the audio.
One of my previous tv had 120ms lag and it had noticeable out of sync issue.
Does anyone notice out of sync audio with this one ?
Its the one thing I can find fault with on my new st60. Bad audio lag using antenna in and the built in speakers. Using the Netflix and bluray through the built in speakers is fine.
This is a big enough problem that it may be sent back.
cfi on the fly is offline
Old 10-29-2013, 06:19 PM
Kurtangletn's Avatar
Originally Posted by shenaniganz08 View Post
OK calm down drama queen
Over and over you keep repeating the same thing
The response time for these TVs are easy to find and it's been repeated NUMEROUS times that the lag times on the ST60 is not that bad unless you're some hardcore neckbeard gamer.
You had the choice to get the S60/S64/VT60/ZT60 if you wanted better response times, so stop complain already because the only person you have to blame is yourself!
Kind of a harsh statement.. on one hand it's kind of annoying that it's discussed so much but on the other it's a real problem that prevents a lot of people from getting the TV or makes a lot of people hesitant.
70ms with game mode is nothing to scoff about, it's tough to really understand how it feels till you really try it though.
My Vizio without game mode is game mode 135-145ms.. with game mode it's about 35-45ms (E3D320VX, did the shutter test thing).
Without game mode everything is floaty, hard to really get a good grip on, it feels "heavy". It's not really impossible to play but man if it's not close. I actually gamed for like 3 years on a Samsung DLP, which I'm not sure what the input lag on it but it had to be around at least 150-250.. I'll be honest, I actually sort of got used to it and forgot about it.. but damn if the few times I used another TV didn't feel like a weight was taken off my controller.
The thing is though, it's frustrating as hell... the ST60 50" version can be had right now with sales/coupons for about $250 more than the 50" S60.. the AR filter, 3D, and increased picture quality is well worth that.. at the same time I can't justify another $650-$700 for the 55" VT60 just so I can get the more manageable input lag.
It just sucks that Panasonic released such a great TV with kind of a major flaw for a lot of people..
Oh well, it is what it is I guess!
Kurtangletn is offline
Old 10-29-2013, 06:20 PM
Robin Bombard's Avatar
Quoted: 14 Post(s)
Liked: 44
Originally Posted by greenythebeast View Post
Alright, thanks. Another question: Does anyone know how high the bottom lip of the P50ST60 is? I'm considering getting a soundbar (VIZIO S4251w) that is 3.74" high and 42.32" wide. Will that block the remote sensor or any of the picture?
MICHIGAN MAPLE BLOCK CUTTING BOARD / BUTCHER BLOCK 18" x 12" x 1 3/4"
http://www.ebay.com/itm/MICHIGAN-MAPLE-BLOCK-CUTTING-BOARD-BUTCHER-BLOCK-AGA01812-/380749690738?pt=Kitchen_Tools_Gadgets&hash=item58a6733772#ht_3333wt_933
This $35.82 w/free shipping maple block will just raise you up just enough to clear the sound bar & the block's dimensions are nearly perfect for the 50ST60 stand. smile.gif
Cheers,
Robin
Robin Bombard is offline
Old 10-29-2013, 06:29 PM
Bond 007's Avatar
Liked: 2030
FWIW I use OTA from time to time and have no audio lag.
Licence to Kill
Bond 007 is offline
Old 10-29-2013, 07:01 PM
Chris NYC's Avatar
There's a separate thread to discuss it. The frustration comes from people spamming this thread with input lag talk at least once every page. Flaw acknowledged but let's not discuss it here.
shenaniganz08 likes this.
Panasonic ST-60 / Denon AVR-S700W
Chris NYC is offline
Old 10-29-2013, 08:08 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 514 Post(s)
Liked: 772
I have no audio lag on my ST60 when using the internal tuner and built in speakers . I don't even think it's possible for a TV's built-in tuner to induce audio lag.
I have noticed a little lag only a few times but i blame that on the broadcast, not the TV. I just checked about a dozen local OTA channels and the dialogue is perfectly in sync with the lips.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 10-29-2013, 09:00 PM
teevman's Avatar
Quoted: 14 Post(s)
So do you actually own an st60 and have gamed on it or are you basing the bad input lag on what others on here are saying? I've read many who say it isn't a big deal so i'm not sure what to thingk.
teevman is offline
Old 10-29-2013, 09:38 PM
Bond 007's Avatar
Liked: 2030
If youve read that many say it isnt a big deal is one person complaining going to completely change your mind?
The fact that hes debating which model to buy would lead me to believe he doesnt own one.
Licence to Kill
Bond 007 is offline
Old 10-29-2013, 10:15 PM
I don't.. I'm considering it more with the S60 being too reflective in my situation and the S64 kind of overpriced (and from eBay, it's only about a $70 difference from the ST60 if I spring for the warranty).
From what I understand about input lag it's more of a threshold.. some people are naturally more sensitive than others.. it may appear to people at 30ms while others won't notice it until the 100s.. I can only really comment on the difference between around 10ms-30ms-and around 132ms right now. I'm doing more tests to get a feel of where my threshold is, I'd do the same as well if you want this TV.
Out of respect for the owners of this TV I Think we should try keeping the input lag discussion in that thread - http://www.avsforum.com/t/1467481/official-st60-input-lag-thread/1080
Old 10-29-2013, 11:55 PM
samijubal's Avatar
Quoted: 41 Post(s)
Liked: 95
Originally Posted by RobMueller10 View Post
It is about 2 1/2 inches from the bottom lip to the tv stand. That soundbar will block the sensor, and maybe even a little bit of the picture.
If all it will block is the sensor just get an IR repeater on ebay for around $20, I use one they work great. Get the one with the block you can connect six repeaters to.
samijubal is offline
Old 10-30-2013, 03:31 AM
Marc_G's Avatar
Quoted: 74 Post(s)
Liked: 43
On the Panasonic Netflix app, is there a way to bypass the "Choose your Netflix Experience" page (where it lets you select regular or kids)?
My kids don't watch on this TV and it would be nice to turn off this one extra step. Obviously not a critical thing, but would be nice...
Sometimes, I see dead pixels...
Marc_G is offline
Old 10-30-2013, 04:54 AM
goldenbear94's Avatar
Same.
goldenbear94 is offline
glantern30's Avatar
Quoted: 20 Post(s)
I always thought using "vivid" wasn't good for your plasma tv that it could increase the likely hood of burn in?
I'll give it a shot, I tried looking through the forum for info on the 3d settings, it seems like it's not too popular on this set not alot of info. If anyone else has any info on this it would be greatly appreicated! I just got avatar in 3d and looking forwrd to checking it out this weekend. There's an option under the 3d settings to increase and decrease the amount the picture will I guess pop of the screen is it good to adjust this??? Will it distort the picture in some way
Old 10-30-2013, 06:53 AM
Thanks for checking yours out. Im going to play around with some different settings and if it doesn't fix the audio lag ill send it back for a replacement. The audio lag using OTA with built in speakers is bad enough my wife said something about it without any prodding from me...and she has a high tolerance for such things.
Hopefully just a bad set.
Old 10-30-2013, 08:39 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2467 Post(s)
Liked: 2733
Cheers,
Robin
If you can not fix it, improvise........
Cleveland Plasma is online now
Old 10-30-2013, 11:00 AM
Astralmind's Avatar
Just got my 60" ST60 2 days ago. For a guy reintegrating the TV world (had been using projectors as my sole display source for over 10 years now!) this was quite a tough decision! I've been used to 92" in a rather dark living room (basically a man cave on a 2nd floor). We are moving into a new condo in a few weeks and the wife wasn't too thrilled about having our few windows covered and a projetor hanging from the ceiling next to the kitchen table (open space).
Anyways, so far, I am totally THRILLED! Outstanding PQ, very happy. Played some Battlefield 4 yesterday and wasn't bother by the supposedly terrible input lag and I consider myself fairly competitive.
A few observations/rethoric questions so far:
- What the heck were they thinking about the "Standard mode" ? Why even have a mode like this one !? Dim, boring blerh! Running it in custom mode with very little tweak and a lowered contrast to avoid issues right now.
- Why are manufacturers insisting on using their own UI/OS as opposed to something like Android/Google TV ? As far as I know, android is a free OS... My cheap Chinese dual core stick (40$) works much better than the built in software...
- Is 3D supposed to be considered usable ? Don't get me wrong, the 3D effect can be quite convincing and even impressive. But the dimming is really pronounced and the flickering is beyond annoying (in my case at least).
Astralmind is offline
Old 10-30-2013, 11:19 AM
Syradil's Avatar
Have you updated the firmware at all yet? I know one of the updates was supposed to improve 3D performance.
I've never used the 3D on mine.
Astralmind likes this.
Syradil is offline
Old 10-30-2013, 01:39 PM
Astralmind's Avatar
hmm I believe I checked for sofware update the minute I turned it on but it could be that the firmware is a seperate update, I'll give it a shot.
Regardless, 3D is really a novelty and not the reason why I bought the TV but still I wondered if 3D was just bad in general or if it was particular to this TV.
Old 10-30-2013, 05:30 PM
dannov's Avatar
Would like to see a' Calibrator' post complete settings in Cinema mode! Custom mode to me does not seem to have much HD depth!.... Source is cable/U Verse...which folks do not acknowledge or may not need to:rolleyes:
dannov is offline
dannov's Avatar
ST60 50"
dannov is offline
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
Custom Mode
Contrast at 100
Brightnes at +4
Panel Brightness at High
Gamma at 2.2 or 2.4( I prefer 2.4)
cadett is offline
Old 10-30-2013, 05:35 PM
Quoted: 14 Post(s)
Liked: 44
http://forums.cnet.com/7723-19410_102-590736/panasonic-tc-p55st60-picture-settings/
dannov likes this.
Old 10-30-2013, 10:51 PM
Indy60's Avatar
I use Sound and Vision's (formerly Home theater) settings for 3D:
http://www.soundandvision.com/content/panasonic-viera-tc-p60st60-3d-plasma-hdtv-settings
bhavinjo likes this.
Indy60 is offline
Old 10-30-2013, 10:55 PM
Indy60's Avatar
Check out my post. I include an Excel file with all the known settings from different websites. Some are in custom, some in cinema.
http://www.avsforum.com/t/1466472/2013-panasonic-settings-issues-thread/1620#post_23690564
bhavinjo and dannov like this.
Indy60 is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
