Official Panasonic TC-PxxST60 Series thread - Page 346 - AVS Forum | Home Theater Discussions And Reviews
 155Likes
Old 12-14-2013, 06:29 PM
50Kuro80's Avatar
Originally Posted by benz5521 View Post
I'm getting more disappointed with the brightness of the ST60 the more I watch it. I have the brightness on high and it's stil pretty dim in a fairly low light situation.
I agree Totally, I've got the Contrast set at 83, and Panel Brightness set to Low......... The picture definetly seems Dim 75% of the time to me atleast........all my settings seem like there set Properly, I'm Using Cinema setting
50Kuro80 is offline
Old 12-14-2013, 06:33 PM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
For the best brightness and PQ, use the setting of 'Mid', calibrating in Cinema or Custom Mode with regular contrast set to about 85.
RWetmore is offline
Old 12-14-2013, 06:35 PM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
It's less then a week old, it's got a few hours on it. I'm sure it gets better with time but I can't imagine it getting much brighter. I hope Best Buy will take it back because I think I'm going to have to go with a Samsung 8500 or even a sony W850A LED.
Indeed the F8500 is a lot brighter but it also cost a lot more, has inferior black levels and some semblance of floating blacks. I would advise staying the course with the ST60, for I think you will get used to it and it will also improve with 'break in' time.
RWetmore is offline
Old 12-14-2013, 06:38 PM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
Yea, I've been reading settings on here and this is what I have. I've also gone back to mid brightness because it's a much better picture, but overall brightness still seems pretty dim.
Custom
Contrast: 85
Brightness: 0
Color: 50
Tint: 0
Sharpness: 25
Color Temp: warm 2
All the other stuff off.
benz5521 is offline
Old 12-14-2013, 06:41 PM
50Kuro80's Avatar
Watching Ice Age Continental Drift, changing the panel brightness to Mid, Mildly does anything if anything...........I do Believe the Panel is giving me the Best PQ that it can, though the picture could be a touch brighter
50Kuro80 is offline
Old 12-14-2013, 06:44 PM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
Custom
Contrast: 85
Brightness: 0
Color: 50
Tint: 0
Sharpness: 25
Color Temp: warm 2
That's good. I assume you have Power Saving mode set to 'Standard'?
BTW, you definitely want the Sharpness setting at 0, as all it does is add noise to the picture.
RWetmore is offline
50Kuro80's Avatar
Custom
Contrast: 85
Brightness: 0
Color: 50
Tint: 0
Sharpness: 25
Color Temp: warm 2
Just curious and I'm No expert but, why Custom mode?? Try a different mode maybe??
50Kuro80 is offline
Old 12-14-2013, 06:48 PM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
Okay, turned the sharpness to 0 and yes, power saving mode is on standard.
Everyone says to use custom or cinema. Standard is supposedly useless. Custom is brighter then cinema.
benz5521 is offline
comfynumb's Avatar
Liked: 410
It's already at 85.
They aren't as bright as an LCD, just give it some time and darken up the room if possible.
shenaniganz08 likes this.
comfynumb is offline
Old 12-14-2013, 06:50 PM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
I'm coming from a plasma though and it wasn't this dim, a Panasonic TC-P58S1 from 2009.
benz5521 is offline
Old 12-14-2013, 06:52 PM
50Kuro80's Avatar
. Try switching to Home Theater mode, it does add a little more brightness, try it
50Kuro80 is offline
comfynumb's Avatar
Liked: 410
Give it time to break in and adjust it to your taste. I just think it's your settings.
Old 12-14-2013, 07:07 PM
mtrot's Avatar
Quoted: 214 Post(s)
Liked: 68
If you are looking for a brighter picture, you won't get it with Cinema mode, IMO. Try Custom, as it will get a lot brighter. Run the contrast up to 85 or so, after your break in period, of course.
You are quite right that these new Panny plasmas are not as bright as they used to be. IMO, it's because they are trying to compete with LED energy efficiency. I bought my parents a 55" Panny plasma about 4 years ago, and it has a very bright and contrasty image.
FAMILY ROOM SYSTEM--Legacy Signature II tower speakers, PSB Image 5T tower speakers, Denon AVR-X5200W, Krell FPB 400cx, Oppo BDP-83 universal disc player, RCA HD-DVD player, Samsung HL67A 750A TV
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Yamaha RX-V1800 receiver, Sherbourn 5/1500A 5-channel amp, Oppo DV 980H DVD player, Panasonic DMP DT210 Blu-ray player, Panasonic 60-ST60 plasma TV.
mtrot is offline
Old 12-14-2013, 07:08 PM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
What gamma setting are you using and what size set do you have?
RWetmore is offline
Old 12-14-2013, 07:14 PM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
2.4, 50".
benz5521 is offline
Old 12-14-2013, 07:16 PM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
2.4, 50".
Try 2.6 as that should give the bright areas of the screen a bit more 'punch', though you'll have to slightly readjust the brightness (i.e. black level) and greyscale (if you've even done that yet). BTW, pro calibrators have said 2.6 is right setting for the 50 and 55 inch sets.
RWetmore is offline
Old 12-14-2013, 07:19 PM
comfynumb's Avatar
Liked: 410
What gamma setting for a 60"?
Old 12-14-2013, 07:30 PM
changboy's Avatar
Liked: 53
deleted
changboy is offline
Old 12-14-2013, 07:41 PM
fuzzione's Avatar
Liked: 27
I, too was initially a bit dismayed at the brightness level of my 60ST60, particularly in comparison to my other LG plasmas and Sony 900a (excellent set BTW...for an LED). Funny how your eyes ultimately adjust however. I have grown so accustomed to my ST now (2 weeks), that all other sets in my home look 'too bright' to me in similar dim environments and I've actually had to turn their torches down a bit. While I still migrate to the Sony during bright daytime viewing of live sports content and turn it up accordingly, the ST continues to excel in the dimmer light movie nights that comprise most of my viewing.
Give yourself some time to adjust, as in my case, it was worth the wait and I don't feel that sacrificing some brightness was that painful, after all. The ST is not without its issues but every flat panel has them. A properly adjusted ST image however makes up for much.
fuzzione is offline
Old 12-14-2013, 08:44 PM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
2.4
RWetmore is offline
Old 12-15-2013, 01:51 AM
rocksolidaudio's Avatar
So after my first five evenings with my new, broken-in 60" ST60, I'm definitely digging it. Though I have a few nagging issues, by far the biggest of which is the motion/juddering still bothering me. Some of the time watching TV (Comcast box via component), even tonight on Top Chef, but oddly not on basketball. And definitely on Blu-ray via PS3 or PS4 (both HDMI). I've watched the intro of The Dark Knight a dozen times trying different settings, and the motion still bothers me; there's a shot two minutes in where the camera pans past a bed of rocks and the flickering/motion of them is especially bothersome/distracting to me (for example). I love everything else about the picture, but I find myself not getting as immersed in things I'm watching as a result. Slower conversational scenes are fine, but most any serious movement/action just rubs me a bit wrong.
For some context, I'm coming from a 42" PZ85U, an older Panny Plasma. I'm using something close to D-nice's settings, tweaked to minimize input lag (per this thread, I believe). Which also leads me to ask whether Game Mode is affecting things, though I've turned it off on the systems when watching Blu-rays and it doesn't seem to make a noticeable difference. I also don't fully understand the 1080p/24hz thing I've seen discussed, though I've tried it both Auto and Off on both PlayStations, and again don't see much of a difference. Though when Game Mode is on, you get less options. I've also never seen the option for 96hz available.
Anyhow, I'd love any advice/thoughts, and ideally if someone could dumb down the hz situation and what everything should be set at (both TV and PS3/PS4) for the most filmic, smooth motion (short of turning on motion smoothing, which I despise even more). Thanks in advance!
rocksolidaudio is offline
Old 12-15-2013, 04:51 AM
G-Money1572's Avatar
Quoted: 45 Post(s)
Liked: 40
I also just bought a 60ST60 this weekend, based on all the glowing reviews here and other places.  What I'm struggling with is that I lose all detail in the dark areas of the picture.  If it's a bright scene, life's good.  But take something with lots of shadows and darks, and the only thing I can see is where there is light highlighting a character's face, etc.  I know there's more detail there, because I can see it when I watch it on my Sony R550, which is set up side by side.  This happens regardless of light conditions - I've done daytime and nighttime viewing with no light at all.
I'd really like to figure out how to fix this, while the TV is in the return period.  If I can't, I'm going to be taking it back.  My wife was nervous about the plasma, and I sold it on the better picture quality.  We aren't blown away by the quality at all, and it's primarily because of this issue where you lose large parts of the picture when the scene is dark.  During well lit scenes, it does fine.
I keep thinking there's a setting I'm missing, but I don't know where.   I've tried CNET's and DNice's on Custom, and just straight out of the box cinema mode.  Is there anything that would get me better detail on the dark scenes?
G-Money1572 is offline
Old 12-15-2013, 04:59 AM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
Try raising the brightness (i.e. black level) first if you haven't. Do you have a calibration disc of some sort? What gamma setting are you using?
RWetmore is offline
Old 12-15-2013, 05:44 AM
Quoted: 45 Post(s)
Liked: 40
My brightness was on 1.  I popped it up to 5, we'll see how that goes.  Gamma's set at 2.4.   I haven't yet used a calibration disc, but have started to realize the value after reading the forums here.  I'm happy to make the investment in the disc, just wanted to know I was 90% happy with the ST60 before I did.  I guess it's a bit of a chicken and the egg deal too....  Thanks for the input!
Old 12-15-2013, 05:46 AM
benz5521's Avatar
Quoted: 42 Post(s)
Liked: 32
Yea, I just don't have a ton of time to adjust. Best Buy's return policy is 15 days I believe. I don't want to be stuck with something that I don't like.
benz5521 is offline
Old 12-15-2013, 05:47 AM
RWetmore's Avatar
Quoted: 402 Post(s)
Liked: 215
That's the right gamma setting. What content are you watching? Blu-ray? Are you watching in Cinema or Custom Mode?
RWetmore is offline
Old 12-15-2013, 06:04 AM
comfynumb's Avatar
Liked: 410
2.4
Thanks, that's where I have it set and it looks good to me. I have 388 hours on mine but I still feel that the picture is changing somewhat, which tells me it's still aging, so I'm going to wait a bit before I run the S&M disc. What's a little but of time compared to years of enjoyment smile.gif
Old 12-15-2013, 06:19 AM
Poolshark69's Avatar
Quoted: 52 Post(s)
Liked: 58
We have that on BD and find the brightness is plenty fine. I am coming from a 5080 same as you smile.gif I am using the Cnet settings and only have probably 40 hours in on the set. My eyes took a little time to adjust but I am trying not to nitpick too much yet. I will wait until 200-300 hours or get a pro calibration. Which I believe will actually make it darker form what I hear frown.gif
Gamertag: Quicksilver1663
Poolshark69 is online now
Old 12-15-2013, 06:21 AM
comfynumb's Avatar
Liked: 410
That's what I'm hearing, and I'd really hate to pay for a calibration and not like it eek.gif
Old 12-15-2013, 06:45 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2547 Post(s)
Liked: 2787
Originally Posted by RandyWalters View Post
Anybody else notice that the 50" and 55" ST60 has disappeared from Amazon? There are a few new ones from their marketplace sellers and used ones, but Amazon is out of them. I wonder if there is any more units left in the distribution chain to replenish their inventory? We know the end is coming, and i've been concerned that inventory will dry up sooner rather than later but i hope this isn't the case yet.
Many retailers area already out ! I give it less than a month................They will be almost gone and a huge rise in price on the one's left.......
Cleveland Plasma is online now
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
