Official Panasonic TC-PxxST60 Series thread - Page 429 - AVS Forum | Home Theater Discussions And Reviews
 145Likes
post #12841 of 13824 Old 08-26-2014, 04:37 AM
chunon's Avatar
Quoted: 2275 Post(s)
Liked: 2012
Originally Posted by MetalMX23 View Post
Much appreciate the information.
With my Australian ST60 there is only one option for the Warm colour temperature which is annoying.
That is too bad, normal may be too blue. Try the white balance adjustment and see if it helps.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #12842 of 13824 Old 08-26-2014, 05:22 AM
MetalMX23's Avatar
Quoted: 14 Post(s)
The Normal colour temperature appears fine while the Warm seems to darken the image too much and highlight the red colour shift to a larger degree to my eyes anyway. Only Cool appears too blue but even in some instances i have found it to improve the look of games.
Do you mean the W/B adjustment within the ST60's picture settings or the S&M HD Benchmark disc?
MetalMX23 is offline
post #12843 of 13824 Old 08-26-2014, 07:48 AM
chunon's Avatar
Liked: 2012
Use the grayscale step ramp on the Spears and Munsil disc, see if you see any red tint, if so use the white balance controls to eliminate the tint if you can.
jmp571 likes this.
65C6 OLED
chunon is offline
post #12844 of 13824 Old 08-26-2014, 07:56 AM
MetalMX23's Avatar
Quoted: 14 Post(s)
Got it!
post #12845 of 13824 Old 08-26-2014, 07:59 AM
chunon's Avatar
Liked: 2012
Got it!
Let me know how it goes
65C6 OLED
chunon is offline
post #12846 of 13824 Old 08-26-2014, 08:47 AM
MetalMX23's Avatar
Quoted: 14 Post(s)
I did see some red tint on that test pattern. I had W/B High R at 5 and W/B Low R at 3. Your right a couple of clicks lower and the picture is more natural/improved. I've placed both high and low R at 0 at the moment. I may have to tweak it a little more.
post #12847 of 13824 Old 08-26-2014, 09:05 AM
chunon's Avatar
Liked: 2012
Excellent! Just keep in mind the High setting affects the lighter shades in the greyscale and the darker shades to a lesser extent, the low setting affects the darker portion and the lighter shades to a lesser extent. The thing most people notice is skin tones, those live in the 40 to 70 ire range. If there is any reference material you are familiar with check skin tones to make sure they don't look to under saturated.
65C6 OLED
chunon is offline
post #12848 of 13824 Old 08-26-2014, 09:17 AM
MetalMX23's Avatar
Quoted: 14 Post(s)
Yes I am and will be checking skin tones.
Solid info
post #12849 of 13824 Old 08-26-2014, 09:20 AM
chunon's Avatar
Liked: 2012
Solid info
I will be re-calibrating my 55" next week perhaps we can compare settings ?
65C6 OLED
chunon is offline
post #12850 of 13824 Old 08-26-2014, 10:19 AM
MetalMX23's Avatar
Quoted: 14 Post(s)
Sounds like a plan. I don't have any calibration tools but S&M HD Benchmark 2nd Edition is as close as it comes in regards to being able to calibrate a panel without equipment.
post #12851 of 13824 Old 08-26-2014, 11:08 AM
Liked: 0
Originally Posted by James Freeman View Post
Yes.
I have swapped European to US mainboard, all went smooth, besides breaking my 5 year warranty on a brand new TV.
And now my European 50" thinks it is a US 55" but its not an inch bigger, although it wishes it was.
And did you change just the mainboard or anything else? How hard is this "operation"? What about firmware? Is it in mainboard already?
Marek_Norway is offline
post #12852 of 13824 Old 08-26-2014, 12:02 PM
Mcguinn's Avatar
So my 55" ST-60 started changing inputs randomly while we were watching the television on HDMI 2 last night. I was not touching the remote. I temporarily stopped it by holding the enter button on the remote but then the Menus started opening as well.
This morning it seemed OK. I left it on for 2 hours and no input switching or menus opening. I believe I have not seen the last of this problem but I would like to be optimistic. Does anyone have any ideas as to what the issue may be? I realize this is very little info on which to work with
This is not a good thing for me since I live in Central America and have limited options for repair and even less for warranty. Of course no more Panny Plasmas either even if I wanted to replace it.
You pays your quarter and you takes your ride but I was hoping the ride would last more than 10 months.
Mcguinn is offline
post #12853 of 13824 Old 08-26-2014, 12:10 PM
Marc_G's Avatar
Quoted: 72 Post(s)
Liked: 43
Could it be some other source of IR commands such as child playing with a smartphone or tablet or if you are in a room with window view commands from some external source? Could it be the remote goes wonky and not the TV itself.... If it happens again take out remote batteries and see if it stops?
Sent from my SGH-M919 using Tapatalk
Sometimes, I see dead pixels...
Marc_G is offline
post #12854 of 13824 Old 08-26-2014, 01:59 PM
Mcguinn's Avatar
Thanks for the reply!
I did take the batteries out of the remote last night while the TV was cycling through the inputs and menus but it continued doing it. I do not think, though I cannot rule out, some sort of electronic interference causing the problem but we are pretty far from any other domicile.
I fired the TV up for another 15 minutes about an hour ago and the problem did not repeat itself. We will find out tonight what the story is. I am trying to determine if it only happens after the TV has been on for awhile.
Mcguinn is offline
post #12855 of 13824 Old 08-26-2014, 04:34 PM
samijubal's Avatar
Quoted: 40 Post(s)
Liked: 93
Sounds like it might have been in demo mode.
samijubal is offline
post #12856 of 13824 Old 08-26-2014, 06:42 PM
Liked: 0
This blows, my 65ST60 is dead. Panel Failure. Panasonic is picking it up and offering me a full refund due to lack of parts. 2 weeks within warranty, thank goodness. Do I go on the hunt for another ST60? LED just isn't doing it for me and OLED is too expensive.
jrobb316 is offline
post #12857 of 13824 Old 08-27-2014, 06:14 AM
Mcguinn's Avatar
I am not familiar with the demo mode. I wonder how it could have slipped into that mode?
I appreciate your input!
Mcguinn is offline
post #12858 of 13824 Old 08-27-2014, 04:00 PM
Julio Castrejon's Avatar
Quoted: 135 Post(s)
Liked: 26
My ST60 has surpassed the 5500 hours mark! It's on at least 16 hours a day because of kids watching it early in the morning. I come home after 8 from work and it is still on, then I watched about 3-4 hours until midnight has passed.
Julio Castrejon is offline
post #12859 of 13824 Old 08-28-2014, 04:17 AM
Bruce2019's Avatar
Quoted: 321 Post(s)
Liked: 188
Hello from europe!
I have my 50 Inch ST60 now for a year, with 3500 hous usage. No problems with IR. I play a lot of Playstation, have played almost 400h Dark souls 2, which is quite shocking, its more than 10% of the whole usage of my tv. :-)
It seems that the plasma gets better after some time, so getting a "used" panel with some hours is not a bad thing, except if the in the store they use movies with cinema bars, which is just a shame.
Anyways. Great TV set, and I am quite shocked about the DSE of the new LG Oleds. So getting a nice Plasma in 2014 is a smart option.
ID:	233034   Click image for larger version
ID:	233042   Click image for larger version
ID:	233050   Click image for larger version
ToonMasterTim likes this.
Bruce2019 is offline
post #12860 of 13824 Old 08-28-2014, 08:15 AM
Liked: 0
Has anyone had an issue with the screen being too dark? I used D-Nice's settings and David Katzmaier's. It seems that there is no definition and the blacks in a dark scene blob together. I also have a 55VT30 and don't have an issue there. Any help would be great, Thanks!
jdon88 is offline
post #12861 of 13824 Old 08-28-2014, 09:56 AM
whipit's Avatar
Quoted: 99 Post(s)
Liked: 84
I had to lower the gamma on my VT60 to 2.0 or 1.8 to loose the black crush I have at times when I watch Uverse through the AVR. It was terrible on network shows and now it looks great and am still getting good minimum black levels and detail down low. There's also the colorspace(wide/narrow) you can switch, there could be a mismatch there.
whipit is offline
post #12862 of 13824 Old 08-28-2014, 11:22 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
That's pretty amusing coming from a Samsung owner
Every plasma I have owned (6) has buzzed. All reports say OLED doesn't have it, which I'm happy to hear.
StinDaWg is offline
post #12863 of 13824 Old 08-29-2014, 08:05 AM
Bruce2019's Avatar
Quoted: 321 Post(s)
Liked: 188
Check your RGB Limited/RGB Full Settings.
post #12864 of 13824 Old 08-30-2014, 06:33 AM
Mcguinn's Avatar
I watched the TV for 4 days with no further issues, then, last night, after about 3 hours, the TV went into what well may be demo mode as Sami Jubal had suggested. Most of the time I watch TV through my laptop connected with an HDMI cable. Once it starts the demo mode it will not stop even if I shut off and unplug the set.
It is very disruptive to our evening entertainment to say the least. I am am very fortunate in that I am renting the home of a friend and he has a Samsung Plasma, albeit 720p, but as most of our programming is streamed at 720p (maybe 720 sometimes) it does not make a huge difference.
So today I am going to start a process of elimination and leave the TV on cable for a few hours and then try the TV's media player, and finally my blu-ray player with both component and HDMI and see if it repeats the problem. I am trying to see if there is any correlation with using a computer connected to the TV through HDMI and the problem we are experiencing.
I also reset the TV to factory settings this morning and made sure I chose "Home Use" rather than "Demo Mode" at the initial setup.
Hopefully, I can narrow this problem down. We love the TV and when playing a blu-ray through HDMI it is like looking at a painting vs a photograph. We will be very disappointed if we cannot resolve this issue.
Mcguinn is offline
post #12865 of 13824 Old 08-31-2014, 12:41 PM
jbs102's Avatar
Quoted: 17 Post(s)
Hi everyone,
How bad is everyone's line bleed with the 60st60? I have researched this and know that its pretty much line bleed... but it just seems crazy to me that this is normal. I know its a common thing of plasams, but I feel like my older 5 year panny was never this bad since I never noticed it. Can anyone else confirm that their 60st60 looks the same way? It may be that now that I have noticed it, I feel like I can't help but notice it every time now. I took a few screenshots with my cell phone and attached them... it does an ok job of showing what I see. I have directv running through my Denon.
ID:	238953   Click image for larger version
jbs102 is offline
post #12866 of 13824 Old 08-31-2014, 01:26 PM
garnettrules21's Avatar
Originally Posted by jbs102 View Post
Hi everyone,
I'd say that's about what my 55ST60 looks like. Interestingly enough when I use High Panel Brightness it isn't quite as bad but still pretty prevalent.
garnettrules21 is offline
post #12867 of 13824 Old 08-31-2014, 03:03 PM
2907Laz's Avatar
Hi everyone,
That looks about the same as the line bleed i get on my 60ST60.
2907Laz is offline
post #12868 of 13824 Old 09-02-2014, 02:34 AM
noom's Avatar
Liked: 0
Sorry for my poor English.
I have Panasonic 50ST60 for a while but i just found magenta and cyan are under saturated.(sometimes images that have cyan color look a bit blue)
As you knew ST60 can't adjust secondary color(yellow, cyan, magenta)
I have CALMAN(newbie) but i still can't reach to the right color.
I just found second hand(in Thailand) 65VT50 2,400 USD and 65VT60 2,812 USD. Is it worth for buying? if can't fix that st60 problem.
Thank you.
My ST60 color gamut
http://image.ohozaa.com/i/f06/LOzBmf.JPG
noom is offline
post #12869 of 13824 Old 09-02-2014, 07:42 AM
grizimes's Avatar
Liked: 29
Hi everyone,
That looks about the same as my TV. The upside that I have with the issue in general, is that I can only notice it on advertisements and such while watching TV with bright solid backgrounds such as in your pictures. Normal watching, gaming, and blu rays, I never see anything.
grizimes is offline
post #12870 of 13824 Old 09-02-2014, 08:00 AM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 144
Thank you.
My ST60 color gamut
That chart is way off. Either your TV or calibration is defective, and as you say you're a Calman newbie, there's a good chance it's the latter. Start by using Custom mode and set everything to defaults. Set Brightness and Contrast per AVS HD 709; you can target a specific light output later using your meter, and 67 gives me 38 fL using 2% windows, excellent for dark room viewing. Set Color Temperature to Warm 2. Set gamma to 2.6. Turn off CATS and all the "enhancements". Here's an excerpt of a message I wrote a week or two ago detailing my procedures and the results I get using just the TV controls, just to show you what is possible.
My approach to my 50ST60 is to adjust the High RGB in the 2 point White balance first, monitoring the effect it has on 70-100%; I don't touch the Low section of the 2 pt WB because it leads to red tinted blacks even after doing 10 point grayscale. Then I use the 10 point grayscale to make the Blue and Red equal to Green at each point. Then I use the 10 point Gamma to adjust the curve shape as a whole. Then I recheck grayscale and gamma and make whatever minor adjustments are needed. Then I do a slightly custom CMS at 75% Stimulus, 75% Saturation and check it over 10 point sweeps at 25%, 50%, 75%, and 100%. I find it's always oversaturated in Red and Green at the 100% saturation points, so if you just do the standard CMS pattern, which is 75% Stimulus, 100% Saturation, you will likely end up under-saturating all the points below 100% saturation, and they're more important by far. This procedure gets me the following results (Avg dE, Max dE) using 2% windows with my i1D3 profiled against a ColorMunki Photo:
10 point grayscale (.4, .69)
21 point grayscale (.47, 1.53)
25% 10 point Saturation Sweep (.61, 1.48)
50% 10 point Saturation Sweep (.61, 1.4)
75% 10 point Saturation Sweep (.59, 1.89)
100% 10 point Saturation Sweep (.95, 2.69)
ColorChecker (.69, 1.94)
ColorChecker Full, the one with a gazillion points (.81, 2.23)
The gamma tracks the BT.1886 curve very, very closely. There is no red tint to blacks, and the picture looks great at all APL levels, without green-tinted skin tones in low APL scenes I observed when using Spears and Munsil Equal Energy patterns. For the Saturation Sweeps, the largest errors are at the 100% Saturation points, and I would definitely sacrifice them a bit if it makes the other points line up better. All the same, my 100% points are far, far closer to their squares than yours as my maximum dEs all less than 3 imply. This includes the secondaries of course, and the inability to control them with CMS is not a huge weakness IMO.
sawfish is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
