Official Panasonic TC-PxxST60 Series thread - Page 433 - AVS Forum | Home Theater Discussions And Reviews
 130Likes
post #12961 of 13719 Old 10-12-2014, 05:28 PM
mjnoles1's Avatar
Quoted: 22 Post(s)
Originally Posted by Chere View Post
^^^ I think you might have to go into the service menu to check on that but I think your best course of action is to go to the store itself and have them plug it in to check it out. Take slides with you and if everything looks kosher (no burn in or some other serious screen deformity) buy it
Originally Posted by RandyWalters View Post
Yes A0018 means 18 hours. I think if the main board is replaced, the hours reset to zero so if that's the case, they've put 18 hours on it since the repair. $464 is a good deal for it regardless.
I bought the TV. Question, since it says only 18 hours of usage, but, that is because the main board has been replaced (confirmed by the Sears warehouse manager), do I still need to do the panel break in settings and the slides, or do you think it is not needed. If you still think it is a good idea, then I will run them.
mjnoles1 is offline
post #12962 of 13719 Old 10-13-2014, 10:18 AM
klillevo's Avatar
I have an unusual problem with my 10 month old ST60. The bezel is becoming unglued in both upper corners, and is currently bulging out 4-5mm. I have tried to search for other similar problems, but found none. I started a support case, and they first tried to get out of having to do anything about it by claiming my receipt printed online from sears.com was not good enough.
I could always attempt to glue it back together myself, but it probably wouldn't last, not knowing which type of glue is heat resistant and safe to use.
Is it nitpicking to expect not having to start self-repair projects on a less than a year-old TV that's falling apart from poor manufacturing?
Thoughts?
klillevo is offline
post #12963 of 13719 Old 10-13-2014, 11:08 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Originally Posted by mjnoles1 View Post
Do I need Ferritt core for my HDMI cable on the ST60? My mom has a Panasonic U50 (2012 base model) and it came with two Ferritt core for HDMI cables and 1 for USB cable. The ST60 did not come with any. She only used one Ferritt core, so, she still has one more remaining. Should I put it on my HDMI cable? It is a Monoprice HDMI cable if it helps answer my question.
You should be fine without them unless you are getting some kind of interference that shows up on the screen.
whipit is offline
post #12964 of 13719 Old 10-13-2014, 11:21 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
I'm thinking we really don't know how many hours are on the panel. The slides are for quickly aging the screen to get the most out of a Pro Calibration. I'm guessing you aren't going that route. I like to run full screen material after a letterbox movie to even the panel wear before I shut it off., but that's just me, lol. Just run full screen material that runs all the pixels and you will be fine. Keep the black bar movies to a minimum and run full screen between the movies. Panasonic recommends keeping static images to no more than 15% of the viewing to prevent IR and Burn In. Black bars may be a little easier on the tv than static logos. Of course your mileage may differ.
whipit is offline
post #12965 of 13719 Old 10-13-2014, 04:32 PM
mjnoles1's Avatar
Quoted: 22 Post(s)
Since we really do not know the actual hours. Will it hurt if I do run the slides continuously for 100 or so? Or is it not recommended and can actually do harm, since I do not know the actual hours of the panel?
mjnoles1 is offline
post #12966 of 13719 Old 10-13-2014, 04:45 PM
samijubal's Avatar
Quoted: 35 Post(s)
Liked: 91
There's no need to run slides. Just avoid black bars, static images and channel logos for the first 100-200 hours.
samijubal is offline
post #12967 of 13719 Old 10-14-2014, 11:58 AM
ace54's Avatar
Quoted: 47 Post(s)
are all ST60 T.V. stands interchangeable ?
I need a stand/base for ST60 55" the 50" stand wont fit its too small will the 60/65 stand fit??
ace54 is offline
post #12968 of 13719 Old 10-14-2014, 07:57 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Originally Posted by ace54 View Post
are all ST60 T.V. stands interchangeable? I need a stand/base for ST60 55" the 50" stand wont fit its too small will the 60/65 stand fit??
I think (but i'm not sure) that the 55" ST60 uses the same components as the 60" and 65" ST60 (there are three part numbers that make up the stand assembly).
As you noted the 50" ST60 stand assembly is different and definitely will not fit the larger sizes.
Here's a related thread with lots of stand info.
TC-P50ST60 compatible stand?
And here's another option:
Alternate table top stands for 60" plasma
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
Last edited by RandyWalters; 10-15-2014 at 07:46 AM. Reason: Fixed Link Paste Error LOL
RandyWalters is offline
post #12969 of 13719 Old 10-14-2014, 08:30 PM
ace54's Avatar
Quoted: 47 Post(s)
I don't see the related thread with lots of info
ace54 is offline
post #12970 of 13719 Old 10-15-2014, 08:37 AM
rocktheroad's Avatar
Liked: 0
I couldn't find how to turn-off small Home Screen banner on top of the screen that shows every time when I turn on TV. I think I managed to power TV every time in Full Screen, but that small banner on top stays for few seconds, and while it is on, you can't do anything with remote (Volume Up/Down, change channels/input). I've tried finding on Internet, but there are just tutorials how to remove Banner Ad's.
Anyone have idea how to do that?
rocktheroad is offline
post #12971 of 13719 Old 10-15-2014, 08:43 AM
Marc_G's Avatar
Quoted: 69 Post(s)
Liked: 43
Not possible. No way to turn it off.
Sent from my SGH-M919 using Tapatalk
Sometimes, I see dead pixels...
Marc_G is offline
post #12972 of 13719 Old 10-15-2014, 03:30 PM
ace54's Avatar
Quoted: 47 Post(s)
I think the 50" and 65" stands are different and the 55" and 60" stands are the same Can anyone confirm?
ace54 is offline
post #12973 of 13719 Old 10-15-2014, 08:49 PM
jagerx9's Avatar
Hey guys.. so thanks to some longer than normal gaming sessions in Destiny, I now have a bit of image retention. It didn't go away with screen wipe. I've followed all proper procedures, did 120 hours of break in, never watch in letterbox, etc. I'm sort of shocked as advice on here certainly suggested that it wouldn't be so easy to do. For reference, the longest that the IR'ed area was on the screen was maybe 2.5 hours in which time it had short breaks throughout.
Any advice on what to do about this and how to avoid it in the future? It's still under warranty, is that something that is typically covered?
jagerx9 is offline
post #12974 of 13719 Old 10-15-2014, 09:18 PM
iserum's Avatar
Quoted: 90 Post(s)
Liked: 53
it will take some time but it will go away, the more you pay attention it will freak you out, my ST30 plasma had a stubborn IR of Cartoon Network Logo, it took while but it went Away, i was getting more IR on my ST60 but it improved quite a bit, i have approx 1800 hours on my panel, never did break in or slide, it is calibrated TV though, My ST30 was also calibrated. my advise is use other content on tv and do not use the same game screen until the IR goes away.
iserum is offline
post #12975 of 13719 Old 10-18-2014, 10:46 AM
ace54's Avatar
Quoted: 47 Post(s)
are there any T.V.s better then the ST60? other then the other Panasonic plasmas and OLEDs, 4Ks?
ace54 is offline
post #12976 of 13719 Old 10-18-2014, 12:49 PM
AMartin56's Avatar
Quoted: 1025 Post(s)
Liked: 418
The Samsung F8500 is superior to the ST60 IMO and just had a price drop.
AMartin56 is offline
post #12977 of 13719 Old 10-19-2014, 01:17 PM
ace54's Avatar
Quoted: 47 Post(s)
also comes with a premium price here in Canada cant find one that's under $2000.00 that price is not including tax
ace54 is offline
post #12978 of 13719 Old 10-19-2014, 10:59 PM
Julio Castrejon's Avatar
Quoted: 128 Post(s)
Liked: 24
Has anybody seen the new Godzilla movie on this set yet? I just saw the blu ray, and wow I was very impressed with the dark scenes and the incredible shadow detail it produced. A lot of people across the web have complain that the movie is too dark to see on their sets. That's just sad.
Julio Castrejon is online now
post #12979 of 13719 Old 10-20-2014, 01:22 AM
cajieboy's Avatar
Quoted: 125 Post(s)
Liked: 69
Thanks for the tip. I plan to rent this BR when I return home from my trip. not too long after I had purchased my ST60, I rented Gravity on BR, and my jaw dropped! The dark space scenes were amazing, and I was hooked after that experience. To see the best quality this TV has to offer, I highly recommend BlueRay disks over streaming. I stream a lot too, but nothing compares to the viewing experience of the BR...that is unless it's a BR 3D.
cajieboy is offline
post #12980 of 13719 Old 10-21-2014, 08:54 PM
BD006's Avatar
Hey everyone,
Just bought a house and looking to wall-mount my 60ST60.
I'm looking at the ultra low profile mounts on mo*op*ice, and was wondering if having it that close to the wall may not allow for enough ventilation? The ultra low profile mount says the TV ends up being mounted 0.75" from the wall, while the low profile mount says 1.25" from the wall.
I would prefer to have it as close to the wall as possible, purely for aesthetics, but I'm not going to do if it risks damaging the TV.
Thanks for anyone's help
BD006 is offline
post #12981 of 13719 Old 10-25-2014, 09:52 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2014 Post(s)
Liked: 2183
So I get a call from my shippers warehouse yesterday and they say hey, we think you have a TV of yours. Can you imagine we just found a new TC-P65ST60
Cleveland Plasma is offline
post #12982 of 13719 Old 10-25-2014, 10:18 AM
AMartin56's Avatar
Liked: 418
Pacific Rim is another good one. Looked terrible in the theaters... A lot more shadow detail on a nice plasma.
post #12983 of 13719 Old 10-25-2014, 01:00 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
in my opinion the ST60 still represents the best value in videophile grade TVs. There may be better out there but not by much. Of course they are all but gone from the market though.
The F8500 is better in some ways. Many people would agree with you but I can tell you from experience that the F8500 suffers from fluctuating brightness. I am sensitive to this so it was a no go.
I have had my 60 ST60 for over a year now and couldn't be happier. It still blows away every other tv I have seen in home use. In fact I am sitting in a home right now watching the new top of the line 9000 series Samsung curved LED and it looks downright aweful! Btw it costs $3000! Ha.
wattheF is offline
post #12984 of 13719 Old 10-25-2014, 01:24 PM
AMartin56's Avatar
Liked: 418
I sold my 50ST60 (my first plasma) because the aggressive ABL really bugged me and the F8500 was within reach after the recent price drop. On my Panny (and all the others of the same model I've seen) screen uniformity took a dive when the ABL kicked in.. Leaving a pink blob in the center on bright screens.
I also like how the Samsung seems more resistant to IR.
In some ways the picture on the Panny was better, but I prefer Samsung's compromises over what Panny chose to compromise on. No display is perfect. And I got to try the two best 50 inch TVs made recently so I did the best I could.
post #12985 of 13719 Old 10-25-2014, 01:36 PM
ace54's Avatar
Quoted: 47 Post(s)
What is ABL? I don't think I have ever seen a pink blob anywhere on my screen...maybe yours was defective Only thing I've noticed is motion blur every once in a while doesn't bother me much though
ace54 is offline
post #12986 of 13719 Old 10-25-2014, 02:08 PM
AMartin56's Avatar
Liked: 418
All plasmas use ABL to a certain extent. It's when brightness dims to protect the panel when bright content is displayed. Can result in 'dirty whites '.
And I could have dealt with gray whites but not pink ones. I had two 50ST60s in my house... Both had it to various extents.. As did the two others I saw on display in various stores.
Seems associated with the ABL because the same areas of the screen are pure white with a chess board test pattern with lower peak brightness.
My ST60 was DIY calibrated with cheap meter. My F8500 is not (not enough hours on the panel).
IMO the ST60 had darker blacks and better color. I liked the motion on it better.
But the F8500 appears sharper, has little to no line bleed that I can see (it was very noticeable on the green screen at the start of trailers on the ST60) less rainbow effect, a less aggressive ABL and better uniformity (my Pannys all had DSE as well.. None on the F8500).
So for ME and my concerns I think I ended up with the better set.
post #12987 of 13719 Old 10-25-2014, 02:13 PM
AMartin56's Avatar
Liked: 418
A good torture test is the opening shot of the new Wolverine movie where the camera pans across the sky from the bomber to the guard tower. On my ST60s the sky was pink and you could see DSE streaking on the left of the display as the camera pans. My F8500 displays this scene properly.
post #12988 of 13719 Old 10-25-2014, 03:38 PM
ace54's Avatar
Quoted: 47 Post(s)
This is something the average viewer doesn't notice unless you go looking for it otherwise I would've seen it by now like the motion blur
I hope I don't notice it because then it might bother me every time I see it
ace54 is offline
post #12989 of 13719 Old 10-25-2014, 05:47 PM
AMartin56's Avatar
Liked: 418
Agreed. My friend who has my old Panny now loves the set. I pointed out the 'flaws' prior to selling it and he didn't care.
post #12990 of 13719 Old 10-25-2014, 05:57 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
Nice find.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
