Official Panasonic TC-PxxST60 Series thread - Page 461 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #13801 of 13822 Old 04-07-2017, 06:46 PM
ace54's Avatar
Quoted: 55 Post(s)
http://www.brainchamber.com/2016/03/...v-blink-codes/
Panasonic TV Blink Codes for All Panasonic Models
Panasonic Plasma TVs have a built in circuit for fault diagnostics. If a fault occurs on one of the internal circuits, the firmware in the TV will detect it and output an error in the form of a blinking LED lite. The exact error is represented by the number of blinks in each series of blinks. By using this fault error code, you can diagnose the problem with the TV without even opening it. First, be sure you are counting the blinks correctly – it is very important to correctly diagnosing the problem. To do that, turn the TV OFF, and then back on and count the number of times the LED blinks. Repeat the process to confirm, and then look up the error code on the table below. This will very quickly diagnose the problem and tell you what board needs to be replaced or repaired.
1blink STV 5v sense DG Board
2blinks 15v SOS D Board
3blinks 3.3v SOS D Board
4blinks Power SOS P Board
5blinks 5v SOS D Board
6blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9blinks Panel Config. SOS
10blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11blinks Fan SOS PB Board
12blinks Sound SOS H Board
13blinks Communication error DG Board with IC8001 (Pesks Lite 2)
ace54 is offline
post #13802 of 13822 Old 04-09-2017, 03:09 PM
snidely's Avatar
Quoted: 156 Post(s)
Liked: 33
Now that plasma is dead - what would you buy now?
I assume most of you, like me, had bought plasma TVs in the past because of the picture quality. What make/model would you buy today?
We have to admit that the new technology avoids having to worry about burn-in. It also uses a lot less electricity. I never hear of anyone having the new screens needing to be professionally calibrated to produce the best results. The older LED based screens required you to sit almost directly in front of the screen. Couldn't really view the picture that anything approaching a sharp angle.
The 50 inch Panny plasma in our main home (seven years old) is working fine, has a perfect picture, and obviously doesn't have the horrible ugly bazel thisST60 does. However, I assume because of age, its days may be numbered. I want to have something in the back of my mind so I don't rush out like I did w. the ST60 and make a mistake winding up with an ugly monstosity on the wall. (It may be ugly - but we can mostly avoid the mirror bezel and enjoy the good pic).
thanks
snidely is offline
post #13803 of 13822 Old 04-09-2017, 06:56 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 513 Post(s)
Liked: 772
I've found the Sony LCDs look more natural and have better colors than all the other brands. My older 55W800B looks probably 90-95% as good as my 55ST60 at night, and actually a little better on a bright afternoon in the man room.
Well with any LCD TV, the off-angle viewing will always be an issue. LCD TVs with a VA panel have better black levels and contrast ratio, but start to lose contrast at like 20 degrees off-center and the image starts to wash out. Alternately, LCD TVs with an IPS panel have poor/lower black levels and contrast ratio, but you can move further off-center before you start to lose contrast and start washing out. So VA panel would be better for watching movies, in the dark, with 2 to 4 people on the couch in front of the screen. An IPS panel would be better for watching broadcast programs or sports in a brighter room or during the daytime, at wider angles more off to the sides.
Here are models i'm considering if i decide to replace my W800B:
Sony XBR-55X700D (IPS panel) $799 http://www.rtings.com/tv/reviews/sony/x700d 7.5
Sony XBR-55X850D (IPS panel) $1,099 http://www.rtings.com/tv/reviews/sony/x850d 7.6
Sony XBR55X930D (Local Dimming, VA Panel) $1,499 http://www.rtings.com/tv/reviews/sony/x930d 8.1
Sony XBR55X900E (Local Dimming, VA Panel) $1,499 http://www.rtings.com/tv/reviews/sony/x900e 8.2
Sony XBR55X930E (Local Dimming, VA Panel) $2,199 http://www.rtings.com/tv/reviews/sony/x930e 8.3
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #13804 of 13822 Old 04-09-2017, 07:09 PM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
thanks
I'd buy a used plasma. Still plenty of them left. I've got a 9 year old Panasonic plasma that still works fine. Picked up a 2013 60" LG plasma for $75 a few months ago. It's just sitting unused right now. Still trying to decide whether to keep it or sell it. I'll probably never get a deal like that again.
You don't see people getting LCDs calibrated because they don't care about the best PQ they can get, if they did they would have bought a plasma.
I just bought a bottom-of-the-line Sony LCD to play games I don't dare play on my plasma. Doesn't look anything like the ST60 to me and is much harder on the eyes but I don't have to worry about burn-in with old games that aren't plasma friendly. Works for what I bought it for.
samijubal is online now
post #13805 of 13822 Old 04-11-2017, 08:41 AM
tanman's Avatar
Quoted: 53 Post(s)
Liked: 34
#RandyWalters: Why not OLED TVs? They are similar to plasmas such that they are emissive displays and Rtings rated them at the top. Maybe waiting for the kinks to be worked out and prices to drop?
tanman is online now
post #13806 of 13822 Old 04-11-2017, 11:14 AM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
They also have the same burn-in issues plasmas have unless they've fixed that.
post #13807 of 13822 Old 04-11-2017, 11:38 AM
tanman's Avatar
Quoted: 53 Post(s)
Liked: 34
All TV technologies have burn in issues with the exception of DLP, but then it doesn't come in the form of a TV anymore only projection!
post #13808 of 13822 Old 04-11-2017, 11:51 AM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
CRTs and LCDs don't, maybe if you leave an image there for a very long time. Projection CRTs did but not conventional CRTs.
post #13809 of 13822 Old 04-11-2017, 12:18 PM
tanman's Avatar
Quoted: 53 Post(s)
Liked: 34
I have seen CRTs and LCDs IR, I guess the image was impressed after a long time.
post #13810 of 13822 Old 04-11-2017, 12:23 PM
Marc_G's Avatar
Quoted: 72 Post(s)
Liked: 43
My old Atari 2600 really did a number on my parents' old TV... Of course that was in 1980...
Sent from my LG-D851 using Tapatalk
Sometimes, I see dead pixels...
Marc_G is online now
post #13811 of 13822 Old 04-11-2017, 12:52 PM
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
My Xbox One has destroyed my ST60 for what it's worth.
cadett is offline
post #13812 of 13822 Old 04-11-2017, 10:50 PM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
I play my PS3 on my ST60 all the time with no problems. I'm careful doing so though, I use different modes and settings to shift the screen around so stuff isn't in the same place all the time and watch TV between sessions.
post #13813 of 13822 Old 04-12-2017, 06:46 PM
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
Consider yourself lucky. I knew my set was gonna give me issues from the jump. Having a image up for 5 mins & it retains it for a while. Like I said, first Panny that's ever been this stubborn.
cadett is offline
post #13814 of 13822 Old 04-12-2017, 07:52 PM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
I keep my contrast as low as possible which definitely helps. I also use zoom, overscan, no overscan, even 4:3 sometimes to keep from having images in the same place on the screen all the time. It was pretty clear back when these were still in production that all the TVs weren't created equal. Some people complained of IR problems and others said there weren't any.
post #13815 of 13822 Old 04-22-2017, 09:47 AM
seabrook's Avatar
Hello, I own a Samsung PN58C550 2010 plasma which I recently got for free a month ago (it needed a firmware update that the owner wasn't aware of so he gave it away). Today on our local Craiglist a Panasonic TC-P60ST60 2013 plasma was listed today for $500/BO. I'm tempted to 'upgrade,' as due to the our set's physical location, we cannot utilize any larger set and I do appreciate the PQ of Panasonic plasmas. Previously we watched a 2006 720p Panasonic plasma which had great PQ. However, putting the two inches larger display improvement aside (due to a thinner bezel), would it be worth it? I don't need any of the Smart Apps nor the 3-D functionality. My wife will think I'm crazy but I'd like to hear from like-minded folks here. I know it's a rare opportunity to upgrade to this make and model. Thanks!
Update: the seller will let it go for $450 after I offered $400. Wife is out so I still have to sell the idea to her.
seabrook is offline
post #13816 of 13822 Old 04-22-2017, 06:19 PM
Quoted: 134 Post(s)
Liked: 35
Originally Posted by seabrook View Post
Hello, I own a Samsung PN58C550 2010 plasma which I recently got for free a month ago (it needed a firmware update that the owner wasn't aware of so he gave it away). Today on our local Craiglist a Panasonic TC-P60ST60 2013 plasma was listed today for $500/BO. I'm tempted to 'upgrade,' as due to the our set's physical location, we cannot utilize any larger set and I do appreciate the PQ of plasma. Previously we watched a 2006 720p Panasonic plasma which had great PQ. However, putting the two inches larger display improvement aside (due to a thinner bezel), would it be worth it? I don't need any of the Smart Apps nor 3-D functionality. My wife will think I'm crazy but I'd like to hear from like-minded folks here. I know it's a rare opportunity to upgrade to this make and model. Thanks!
$450 is a great price for that set. Check the hours. If it is over 8k bargain him down to $400.
Test Ickles is offline
post #13817 of 13822 Old 04-22-2017, 10:35 PM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
The difference between my 2008 Panny and the ST60 is night and day. Definitely a big upgrade from a 2006.
post #13818 of 13822 Old Yesterday, 08:27 AM
seabrook's Avatar
The seller reported the following:
Hours: C6603-0000 6,603
I'm still trying to convince my wife the need to replace a 58" set with a 60" set (which the seller sympathizes with).
My bigger concern is: there are former owners on this thread who have abandon their ST60's due to IR or color 'splotches' issues (most visible on white backgrounds). Our Samsung has both types of problems but then again it was free. I really rather not pay for a set only to encounter those flaws again. Are these issues systematic of 1080p sets (as our 720p Panasonic is problem-free)?
seabrook is offline
post #13819 of 13822 Old Yesterday, 11:35 AM
Quoted: 134 Post(s)
Liked: 35
Very low hours! That things a baby. Just look for any issues and snatch that thing up.
post #13820 of 13822 Old Yesterday, 03:11 PM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
ALL TVs have flaws inherent to the format. There's no such thing as a perfect TV, never has been. Just buy it and enjoy it. I don't see this TV as any worse on IR than my 2008. It will be a huge upgrade from a 2006 TV.
post #13821 of 13822 Old Yesterday, 07:06 PM
seabrook's Avatar
Update: the seller raised his price to $600/BO so I'm going to take a pass. Thanks for all the feedback!
seabrook is offline
post #13822 of 13822 Old Today, 01:45 PM
samijubal's Avatar
Quoted: 39 Post(s)
Liked: 92
Should have snagged it when you had the chance. They are RARELY for sale around here and when they are they are at least $700 for the 50".
Panasonic Tc P55st60 55 Inch 1080p 600hz 3d Smart Plasma Hdtv , Panasonic Tc P60st60 60 Inch 3d Smart Plasma Hdtv , Panasonic Tc P65st60 65 Inch 3d Smart Plasma Hdtv , Panasonic Viera Tc P55vt50 , Sony Bravia Xbr52hx909 52 Lcd Tv Direct Led
