What is the best duster to dust the screen of my Panasonic Plasma ST30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-09-2013, 09:37 PM - Thread Starter
redraider1974's Avatar
Is there a "best" duster on the market to safely dust the screen of my Panasonic Plasma ST30. Human hands have yet to touch the screen. Should I also use this duster to dust the black non -screen frame of the Plasma TV?
redraider1974 is offline
post #2 of 4 Old 01-09-2013, 09:56 PM
PeterG's Avatar
Liked: 25
I do not use a swiffer duster as despite the good reports from some experienced posters here, swiffer uses a mineral oil coating. I am almost sure that this is perfectly OK. But why risk it? It may be fine for many wipes but I would simply use a good microfibre cloth, gently stroking the screen and, if you have some stubborn problem, add a bit of distilled water.
PeterG is offline
post #3 of 4 Old 01-09-2013, 09:58 PM
davelanger's Avatar
And if you used distilled water you should spray the cloth not the screen right:?
davelanger is offline
post #4 of 4 Old 01-09-2013, 09:59 PM
PeterG's Avatar
Liked: 25
Yes, just on the cloth and not overly much. That method has never caused any issue at all.
PeterG is offline
